In the following code I have a growing material that grows with a growth tensor g_i. Now my code is supposed to minimize the energy with respect to displacement and growth tensor entries. But it breaks with a jit.py error. Here is a simplified version of my code:
#Upload the mesh
mesh = UnitCubeMesh(8, 8, 8) #imports the converted mesh
#define function space
V1 = VectorElement('P', tetrahedron,1) #Vector elements for the mixed space
V2 = FiniteElement('R', tetrahedron,0) #Real line elements for the mixed space
element = MixedElement([V1,V2,V2])
Z = FunctionSpace(mesh,element) #mixed space
#Define functions
du = TrialFunction(Z) # Incremental displacement
v = TestFunction(Z) # Test function
Sol = Function(Z) # Solution function
#Breaking the solution
u , alpha, beta = split(Sol)
#Elasticity parameter for the Hopzafel cylinder (intima)
mu_i, nu_i, beta_i, eta_i, rho_i= 27.9, 0.49, 170.88, 263.66, 0.51
#Fibers direction
b_i = Constant((1,0,0))
#looping prameters
epsilon = 0.001
deps= 0.001
epsmax = 3.0
#Loop
while epsilon<=3.0:
#Building the Growth tensor
gamma = (((1+2.7*epsilon)/((1+alpha*epsilon)*(1+beta*epsilon))-1)/epsilon)
PARS2 = as_tensor([[alpha,0,0],[0,beta,0],[0,0,gamma]])
g_i = Identity(3)+epsilon*PARS2 #this is y growth tensor with unknowns alpha and beta
G_i = det(g_i)
ginv_i = inv(g_i)
# Kinematics
II = Identity(3) # Identity tensor
F =II + grad(u) # Deformation gradient
J = det(F)
Fe_i= F*ginv_i
Fe_i = Fe_i
Ce_i= Fe_i.T*Fe_i #elastic response right cauchy-green tensor
Ie_i=tr(Ce_i)
J_i = det(Fe_i) #Jacobian Fe
#Stiffness
I4_i = conditional(lt(dot(b_i, Ce_i*b_i),Constant(1)),1,dot(b_i, Ce_i*b_i))
#printing the current loop variables
print(epsilon)
# Stored strain energy density (neo-Hookean Hopzafel model for growing material)
psi_i = G_i*((mu_i/2)*(Ie_i - 3)+(eta_i/beta_i)*(exp(beta_i*(rho_i*(I4_i-1)**2+(1-rho_i)*(Ie_i-3)**2))- 1)+((mu_i*nu_i)/(1-2*nu_i))*(J_i-1)**2- mu_i*ln(J_i))
#The energy form
Pi = psi_i*dx
#Gateaux derivatives
Fac = derivative(Pi, Sol, v)
Jac = derivative(Fac, Sol, du)
##In here we have no boundary conditions
bcs= []
#solve
solve(Fac == 0, Sol, J=Jac,
solver_parameters={"newton_solver": {"relative_tolerance": 9e-10,
"absolute_tolerance": 9e-10,"maximum_iterations": 80}})
#Break the solution into components
u, alpha = split(Sol)
epsilon+=deps
I use Dolfin version 2017.2.0 on linux mint and below is the error I receive:
I have done this on a hpc cluster and still get the same error. I use Dolfin version 2017.2.0 on Linux mint. Also this code works fine in 2D.
*** Error: Unable to perform just-in-time compilation of form.
*** Reason: ffc.jit failed with message:
File "/usr/lib/python2.7/dist-packages/dolfin/compilemodules/jit.py", line 142, in jit
result = ffc.jit(ufl_object, parameters=p)
File "/usr/lib/python2.7/dist-packages/ffc/jitcompiler.py", line 218, in jit
module = jit_build(ufl_object, module_name, parameters)
File "/usr/lib/python2.7/dist-packages/ffc/jitcompiler.py", line 134, in jit_build
generate=jit_generate)
File "/usr/lib/python2.7/dist-packages/dijitso/jit.py", line 167, in jit
header, source, dependencies = generate(jitable, name, signature, params["generator"])
File "/usr/lib/python2.7/dist-packages/ffc/jitcompiler.py", line 67, in jit_generate
prefix=module_name, parameters=parameters, jit=True)
File "/usr/lib/python2.7/dist-packages/ffc/compiler.py", line 143, in compile_form
prefix, parameters, jit)
File "/usr/lib/python2.7/dist-packages/ffc/compiler.py", line 190, in compile_ufl_objects
ir = compute_ir(analysis, prefix, parameters, jit)
File "/usr/lib/python2.7/dist-packages/ffc/representation.py", line 186, in compute_ir
for (form_id, fd) in enumerate(form_datas)]
File "/usr/lib/python2.7/dist-packages/ffc/representation.py", line 463, in _compute_integral_ir
parameters)
File "/usr/lib/python2.7/dist-packages/ffc/uflacs/uflacsrepresentation.py", line 139, in compute_integral_ir
parameters)
File "/usr/lib/python2.7/dist-packages/ffc/uflacs/build_uflacs_ir.py", line 353, in build_uflacs_ir
rtol=p["table_rtol"], atol=p["table_atol"])
File "/usr/lib/python2.7/dist-packages/ffc/uflacs/elementtables.py", line 565, in build_optimized_tables
unique_table_ttypes = analyse_table_types(unique_tables, rtol=rtol, atol=atol)
File "/usr/lib/python2.7/dist-packages/ffc/uflacs/elementtables.py", line 544, in analyse_table_types
for uname, table in unique_tables.items() }
File "/usr/lib/python2.7/dist-packages/ffc/uflacs/elementtables.py", line 544, in <dictcomp>
File "/usr/lib/python2.7/dist-packages/ffc/uflacs/elementtables.py", line 517, in analyse_table_type
elif is_quadrature_table(table, rtol=rtol, atol=atol):
File "/usr/lib/python2.7/dist-packages/ffc/uflacs/elementtables.py", line 493, in is_quadrature_table
Id = numpy.eye(num_points)
File "/usr/lib/python2.7/dist-packages/numpy/lib/twodim_base.py", line 233, in eye
m = zeros((N, M), dtype=dtype)
MemoryError
Thank you in advance for your help.
