Kernel appears to be dead when tried to execute solve() command
Hi, I am having difficulty in executing the following block of my code -
# Compute solution
u = Function(V, name = "Displacement")
solve(a == L, u, bcs, solver_parameters={'linear_solver':'mumps'})
MWE is -
tol = 1e-5
#Making a geometry
cylinder = Cylinder(Point(0.5, 0.5, 0), Point(0.5, 0.5, 2), 0.25, 0.25)
cube = Box(Point(0, 0, 0),Point(1, 1, 1))
domain = cube - cylinder
# Making Mesh (40 corresponds to the mesh density)
mesh = generate_mesh(domain, 40)
V = VectorFunctionSpace(mesh, 'CG', 2)
tol = 1E-8
def bottom(x, on_boundary):
    return near(x[0], 0., tol)
def top(x, on_boundary):
    return near(x[0], 1., tol)
bcbot = DirichletBC(V,  Constant((0, 0, 0)), bottom)
bctop = DirichletBC(V.sub(0),  Constant(0.1), top)
bcs = [bcbot, bctop]
E = Constant(200e3) #E = 200 GPa
nu = Constant(0.3)
model = "plane_stress"
mu = E/2/(1+nu)
lmbda = E*nu/(1+nu)/(1-2*nu)
if model == "plane_stress":
    lmbda = 2*mu*lmbda/(lmbda+2*mu)
# Define strain and stress
    return sym(grad(u))
def sigma(u):
    return lmbda*tr(epsilon(u))*Identity(d) + 2*mu*epsilon(u)
d = u.geometric_dimension()  # space dimension
f = Constant((0, 0, 0))
T = Constant((0, 0, 0))
L = dot(f, v)*dx + dot(T, v)*ds
# Compute solution
It’s is working fine for a unit cube mesh but when I try to change the domain like here a cube with a cylindrical cavity in it, it takes too long before showing kernel died.
I hope to know what mistake I am making and looking forward to solve it.
Thank You
Have you tried on a coarser (less dense mesh) generated by mshr?
I would guess you run out of memory.
Thanks @dokken for this information, it works fine till mesh density = 35 and beyond that the kernel dies, but what alternative should I use if I don’t want to make my mesh coarser and execute as it is ?
Use an iterative solver.
As you are solving what appears to be an elasticity problem, using CG with a GAMG preconditioner is usually efficient.
You could alternatively use the setup from Bitbucket
Hi @dokken, thanks for the suggestion, I tried to use the code from Bitbucket after some modifications but ran into error while executing this cell -
# Assemble system, applying boundary conditions and preserving
# symmetry)
A, b = assemble_system(a, L, bcs)
Error -
/tmp/ipykernel_739/3299545883.py in <module>
      1 # Assemble system, applying boundary conditions and preserving
      2 # symmetry)
----> 3 A, b = assemble_system(a, L, bcs)
/usr/lib/petsc/lib/python3/dist-packages/dolfin/fem/assembling.py in assemble_system(A_form, b_form, bcs, x0, form_compiler_parameters, add_values, finalize_tensor, keep_diagonal, A_tensor, b_tensor, backend)
    428         assembler.assemble(A_tensor, b_tensor, x0)
    429     else:
--> 430         assembler.assemble(A_tensor, b_tensor)
    431
    432     return A_tensor, b_tensor
RuntimeError:
*** Error:   Unable to match boundary condition to function space.
*** Reason:  Function space on axis 0 does not contain BC space.
*** Where:   This error was encountered inside SystemAssembler.cpp.
*** Process: 0
*** Git changeset:  ubuntu
Minimum working example which I’m using -
# Test for PETSc
if not has_linear_algebra_backend("PETSc"):
    print("DOLFIN has not been configured with PETSc. Exiting.")
    exit()
# Set backend to PETSC
parameters["linear_algebra_backend"] = "PETSc"
def build_nullspace(V, x):
    """Function to build null space for 3D elasticity"""
    # Create list of vectors for null space
    nullspace_basis = [x.copy() for i in range(6)]
    # Build translational null space basis
    V.sub(0).dofmap().set(nullspace_basis[0], 1.0);
    V.sub(1).dofmap().set(nullspace_basis[1], 1.0);
    V.sub(2).dofmap().set(nullspace_basis[2], 1.0);
    for x in nullspace_basis:
        x.apply("insert")
    # Create vector space basis and orthogonalize
    basis = VectorSpaceBasis(nullspace_basis)
    basis.orthonormalize()
    return basis
#Making a cylindrical geometry
# Stress and strain computation
nu = Constant(0.3)
mu = E/2/(1+nu)
    return sym(grad(u))
def sigma(u):
    return lmbda*tr(epsilon(u))*Identity(3) + 2*mu*epsilon(u)
# Create function space
L = inner(f, v)*dx
# Set up boundary condition
class left(SubDomain):
        return on_boundary and near(x[0], 0., 0.1)
class right(SubDomain):
        return on_boundary and near(x[0], 1., 0.1)
boundaries = MeshFunction("size_t", mesh, mesh.geometry().dim() - 1)
left().mark(boundaries, 1)
right().mark(boundaries, 2)
bc_left = DirichletBC(V, Constant((0., 0., 0.)), boundaries, 1)
bc_right = DirichletBC(V.sub(0), Constant(.1) , boundaries, 2)
bcs = [bc_left, bc_right]
# symmetry)
Please note that this is not a minimal example, as:
  1. You are not using a built in mesh, which you could for this demo.
  2. You are missing the definition of f.
Additionally, I do not get an error when running this code.
However, I do think it is strange that you redefine V in
as this could cause issues, as V is not the same object as the V define previously
