Error: Unable to orthonormalize vector basis. Reason: Vector space has linear dependency. Where: This error was encountered inside Vector Space Basis.cpp
Hello, I am having difficulty in understanding the following error -
/tmp/ipykernel_3949/1105952868.py in <module>
      5 # AMG). The solution vector is passed so that it can be copied to
      6 # generate compatible vectors for the nullspace.
----> 7 null_space = build_nullspace(V, u.vector())
      8
      9 # Attach near nullspace to matrix
/tmp/ipykernel_3949/3298775566.py in build_nullspace(V, x)
     15     # Create vector space basis and orthogonalize
     16     basis = VectorSpaceBasis(nullspace_basis)
---> 17     basis.orthonormalize()
     18
     19     return basis
RuntimeError:
*** Error:   Unable to orthonormalize vector basis.
*** Reason:  Vector space has linear dependency.
*** Where:   This error was encountered inside VectorSpaceBasis.cpp.
*** Process: 0
*** Git changeset:  ubuntu
I was running out of memory when using linear solver so in this post @dokken suggested me to use CG with a GAMG preconditioner which is available on Bitbucket.
Here is the minimum working example to reproduce the above error -
if not has_linear_algebra_backend("PETSc"):
    print("DOLFIN has not been configured with PETSc. Exiting.")
    exit()
parameters["linear_algebra_backend"] = "PETSc"
def build_nullspace(V, x):
    nullspace_basis = [x.copy() for i in range(6)]
    V.sub(0).dofmap().set(nullspace_basis[0], 1.0);
    V.sub(1).dofmap().set(nullspace_basis[1], 1.0);
    V.sub(2).dofmap().set(nullspace_basis[2], 1.0);
    for x in nullspace_basis:
        x.apply("insert")
    return basis
cylinder = Cylinder(Point(0.5, 0.5, 0), Point(0.5, 0.5, 2), 0.25, 0.25)
cube = Box(Point(0, 0, 0),Point(1, 1, 1))
domain = cube - cylinder
mesh = generate_mesh(domain, 40)
E = Constant(200e3)
nu = Constant(0.3)
mu = E/2/(1+nu)
lmbda = E*nu/(1+nu)/(1-2*nu)
    return sym(grad(u))
def sigma(u):
    return lmbda*tr(epsilon(u))*Identity(3) + 2*mu*epsilon(u)
f = Constant((0., 0., 0.))
L = inner(f, v)*dx
class left(SubDomain):
        return on_boundary and near(x[0], 0., 0.1)
class right(SubDomain):
        return on_boundary and near(x[0], 1., 0.1)
boundaries = MeshFunction("size_t", mesh, mesh.geometry().dim() - 1)
left().mark(boundaries, 1)
right().mark(boundaries, 2)
bc_left = DirichletBC(V, Constant((0., 0., 0.)), boundaries, 1)
bc_right = DirichletBC(V.sub(0), Constant(1.) , boundaries, 2)
bcs = [bc_left, bc_right]
A, b = assemble_system(a, L, bcs)
as_backend_type(A).set_near_nullspace(null_space)
pc = PETScPreconditioner("petsc_amg")
PETScOptions.set("mg_levels_ksp_type", "chebyshev")
PETScOptions.set("mg_levels_pc_type", "jacobi")
PETScOptions.set("mg_levels_esteig_ksp_type", "cg")
PETScOptions.set("mg_levels_ksp_chebyshev_esteig_steps", 50)
solver = PETScKrylovSolver("cg", pc)
solver.parameters["monitor_convergence"] = True
solver.set_operator(A);
solver.solve(u.vector(), b);
Any help regarding the above would be highly appreciated.
Thank You.
Your nullspace is wrong, see Bitbucket
Yeah, that actually was the issue, I replaced def build_nullspace(V, x) function according to your suggestion by this and it worked -
    """Function to build null space for 3D elasticity"""
    # Get geometric dim
    gdim = V.mesh().geometry().dim()
    assert gdim == 2 or gdim == 3
    # Set dimension of nullspace
    dim = 3 if gdim == 2 else 6
    # Create list of vectors for null space
    nullspace_basis = [x.copy() for i in range(dim)]
    # Build translational null space basis
    for i in range(gdim):
        V.sub(i).dofmap().set(nullspace_basis[i], 1.0);
    # Build rotational null space basis
    if gdim == 2:
        V.sub(0).set_x(nullspace_basis[2], -1.0, 1);
        V.sub(1).set_x(nullspace_basis[2], 1.0, 0);
    elif gdim == 3:
        V.sub(0).set_x(nullspace_basis[3], -1.0, 1);
        V.sub(1).set_x(nullspace_basis[3],  1.0, 0);
        V.sub(0).set_x(nullspace_basis[4],  1.0, 2);
        V.sub(2).set_x(nullspace_basis[4], -1.0, 0);
        V.sub(2).set_x(nullspace_basis[5],  1.0, 1);
        V.sub(1).set_x(nullspace_basis[5], -1.0, 2);
        x.apply("insert")
    return VectorSpaceBasis(nullspace_basis)
But still one issue is when I am using this Gmsh generated .msh file, in the post-processing step, when I am saving stress field by projection into VTK format, it somehow ran out of memory and the kernel dies when try to implement the below code -
# Project and write stress field to post-processing file
W = TensorFunctionSpace(mesh, "Discontinuous Lagrange", 0)
stress = project(sigma(u), V=W)
File("stress_2.pvd", "compressed") << stress
Here is the minimal working example to reproduce the issue -
# Test for PETSc
    exit()
# Set backend to PETSC
    if gdim == 2:
    elif gdim == 3:
        x.apply("insert")
msh = meshio.read("3dmesh.msh")
    out_mesh = meshio.Mesh(points=points, cells={cell_type: cells})
    return out_mesh
tetra_mesh = create_mesh(msh, "tetra")
triangle_mesh = create_mesh(msh, "triangle")
meshio.write("tri.xdmf", triangle_mesh)
meshio.write("tetra.xdmf", tetra_mesh)
mesh = Mesh()
with XDMFFile("tetra.xdmf") as infile:
    infile.read(mesh)
E = Constant(200e3) #E = 200 GPa
nu = Constant(0.3)
mu = E/2/(1+nu)
    return sym(grad(u))
def sigma(u):
L = inner(f, v)*dx
        return on_boundary and near(x[0], -35.3, 0.1)
        return on_boundary and near(x[0], 29.69, 0.1)
bc_left = DirichletBC(V.sub(0), Constant(1.) , boundaries, 1)
bc_right = DirichletBC(V , Constant((0., 0., 0.)), boundaries, 2)
Thanks for the guidance.
Because projection requires a linear solver and legacy DOLFIN defaults to a direct solver.
See Where to find 'project'-function in dolfinx? - #2 by nate or something like project(*args, solver_type="cg").
Change the projection to use an iterative solver, ref: Out of memory error - #4 by dokken as the default is LU
EDIT: Didn’t see @nate’s reply when I posted this. Same idea different post
Thanks @nate and @dokken for suggesting to change the solver_type to an iterative solver, I changed the code to -
stress = project(sigma(u), W, solver_type="cg")
File("stress_2.pvd") << stress
But still the same error of running out of memory persists.
I found an alternative to visualize stress using -
s = sigma(u) - (1./3)*tr(sigma(u))*Identity(3)  # deviatoric stress
von_Mises = sqrt(3./2*inner(s, s))
vm = project(von_Mises, V, solver_type="cg")
File("von_Mises.pvd") << vm
It worked fine due to same continous Function Space, so yeah, but I am still curious why even using iterative solver is not able to project that stress tensor.
Thanks for the help.
You should not put the stresses in CG, 1, as They are not in that space. Consider using DG,0 and a local projection, as shown in the last cell of SSCP_2023_lectures/L12 (FEniCS Intro)/L03_FEniCS_Darcy.ipynb at main · Simula-SSCP/SSCP_2023_lectures · GitHub
I tried using local_project but the same error of running out of memory exists, I used this which led to dead kernel -
elem_v = VectorElement("DG", mesh.ufl_cell(), 0)
W_v = FunctionSpace(mesh, elem_v)
stress = local_project(sigma(u), W_v)
But in The equations of linear elasticity tutorial, the author is projecting von_Mises stress on CG, 1 and plotting it. Why is it inaccurate ?
Because the tutorial is very out of date.
Local project shouldn’t consume alot of memory, as it only assembles local matrices, and does local inversions, Which should be quicker and less expensive than a normal projection.
I cannot reproduce any of your errors, as you haven’t supllied the msh file that you are using. Here is a version with the original mesh you posted:
    if gdim == 2:
    elif gdim == 3:
        x.apply("insert")
nu = Constant(0.3)
mu = E/2/(1+nu)
    return sym(grad(u))
def sigma(u):
L = inner(f, v)*dx
def local_project(f, V):
    a_proj = inner(u, v)*dx
    b_proj = inner(f, v)*dx
    solver.factorize()
    solver.solve_local_rhs(u)
    return u
stress = local_project(sigma(u), W)
with XDMFFile("stress.xdmf") as xdmf:
    xdmf.write(stress)
Here is my .msh file. Yeah, this code works fine on the original inbuilt mesh but I think due to finer mesh that I gave in my .msh file it keeps running out of memory.
Any solution regarding this or do I have to use a relatively coarser mesh ?
EDIT: You can reproduce the same error by setting mesh density to 60 that is -
mesh = generate_mesh(domain, 60)
EDIT2: I made the mesh coarser, now its’ working.
Thanks.
How do I make sure to select sigma_xx, sigma_yy, sigma_zz, or other stresses from these ?
 stress_tensor1 = [[0, 1, 2],
                  [3, 4, 5],
                  [6, 7, 8] ]
 stress_tensor2 = [[sigma_xx, sigma_xy, sigma_xz],
                  [sigma_yx, sigma_yy, sigma_yz],
                  [sigma_zx, sigma_zy, sigma_zz] ]
Are stress_tensor1 and stress_tensor2 equivalent ?
