Kernel dies when running my code
Hi everyone,
I have written a code which solves for a transient heat conduction equation with neumann and robin boundary conditions. I am trying to save the simulation to a gif file but the kernel dies automatically, every time I run the code. Can someone tell me what’s wrong? I guess the problem is in the last 5 lines of the code when I am updating the gif. The code runs without an issue when I comment out those lines
I am running the code on Windows installation via docker!
Also, there are no dirichlet boundary conditions for my problem. When I apply lifting on the b vector, I have written it as apply_lifting(b, [a], [[]]). Is that correct?
from dolfinx.fem import (Constant,  Function, FunctionSpace, assemble_scalar, form, locate_dofs_topological)
from dolfinx.fem.petsc import (LinearProblem, assemble_vector, assemble_matrix, create_vector,
                               apply_lifting, set_bc)
from dolfinx.mesh import create_rectangle, locate_entities, locate_entities_boundary, meshtags, CellType
from ufl import (FacetNormal, Measure, SpatialCoordinate, TestFunction, TrialFunction, div, dot, dx, grad,
                 inner, lhs, rhs)
import matplotlib as mpl
import pyvista
nx, ny = 50, 50
mesh = create_rectangle(MPI.COMM_WORLD, [np.array([0,0]),np.array([5,5])], [nx, ny], CellType.triangle)
V = FunctionSpace(mesh, ("Lagrange",1))
t = 0     # Start time
t_end = 20     # End time
num_steps = 50    # Number of time steps
dt = (t_end-t)/num_steps   # Time step size
x = SpatialCoordinate(mesh)
T_n = Function(V)
T_n.interpolate(lambda x: np.full((x.shape[1],), 323))
T_h = Function(V)
T_h.interpolate(lambda x: np.full((x.shape[1],), 323))
T_inf = Constant(mesh,default_scalar_type(298))    # Ambient temperature
Q_gen = Constant(mesh,default_scalar_type(100))    # Heat generation inside CV
q_tabs = Constant(mesh,default_scalar_type(10))    # Heat flux to tabs
rho = Constant(mesh,default_scalar_type(2500))     # Density
C_p = Constant(mesh,default_scalar_type(900))      # Specific heat capacity of the cell
k = Constant(mesh,default_scalar_type(25))         # Thermal conductivity
h = Constant(mesh,default_scalar_type(8))          # Convection coefficient
boundaries = [(1, lambda x: np.isclose(x[0],0)),
              (2, lambda x: np.isclose(x[1],5)),
              (3, lambda x: np.logical_and(np.isclose(x[0],5),np.greater_equal(x[1],4),np.less_equal(x[1],5))),
              (4, lambda x: np.logical_and(np.isclose(x[0],5),np.greater_equal(x[1],3),np.less(x[1],4))),
              (5, lambda x: np.logical_and(np.isclose(x[0],5),np.greater_equal(x[1],2),np.less(x[1],3))),
              (6, lambda x: np.logical_and(np.isclose(x[0],5),np.greater_equal(x[1],1),np.less(x[1],2))),
              (7, lambda x: np.logical_and(np.isclose(x[0],5),np.greater_equal(x[1],0),np.less(x[1],1))),
              (8, lambda x: np.isclose(x[1],0))]
fdim = mesh.topology.dim - 1
    facets = locate_entities(mesh, fdim, locator)
    facet_indices.append(facets)
facet_tag = meshtags(mesh, fdim, facet_indices[sorted_facets], facet_markers[sorted_facets])
ds = Measure("ds", domain=mesh, subdomain_data=facet_tag)
a = form(rho * C_p * u * v * dx + dt * inner(k * grad(u), grad(v)) * dx +
     dt * h * u * v * (ds(1) + ds(2) + ds(3) + ds(5) + ds(7) + ds(8)))
L = form((rho * C_p * T_n + dt * Q_gen) * v * dx - dt * q_tabs * v * (ds(4) + ds(6)) +
     dt * h * T_inf * v * (ds(1) + ds(2) + ds(3) + ds(5) + ds(7) + ds(8)))
A = assemble_matrix(a, bcs=[])
b = create_vector(L)
solver.setOperators(A)
grid = pyvista.UnstructuredGrid(*vtk_mesh(V))
plotter = pyvista.Plotter()
plotter.open_gif("heat_equation.gif")
grid.point_data["T_h"] = T_h.x.array
# warped = grid.warp_by_scalar("T_h", factor=1)
grid.set_active_scalars("T_h")
viridis = plt.cm.get_cmap("viridis", 25)
sargs = dict(title_font_size=25, label_font_size=20, fmt="%.2e", color="black",
             position_x=0.1, position_y=0.8, width=0.8, height=0.1)
renderer = plotter.add_mesh(grid, show_edges=True, lighting=False,
                            cmap=viridis, scalar_bar_args=sargs,
                            clim=[0, max(T_h.x.array)])
for i in range(num_steps):
    with b.localForm() as loc_b:
        loc_b.set(0)
    assemble_vector(b, L)
    set_bc(b, [])
    # Solve linear problem
    solver.solve(b, T_h.vector)
    T_h.x.scatter_forward()
    T_n.x.array[:] = T_h.x.array
    # Update plot
    plotter.update_coordinates(grid.points.copy(), render=False)
    plotter.update_scalars(T_h.x.array, render=False)
    plotter.write_frame()
plotter.close()
