Lattice structure Beam element
Hello !
I’m relatively new to using DOLFINx and am currently working on a project involving the modeling of a lattice structure using Timoshenko beam elements. I’ve been trying to simulate the displacement of the structure under a compressive force applied to the top surface. However, I’m encountering an issue where the displacement results in infinity, and I’m unsure where I might be going wrong.Here’s a brief overview of what I’ve done so far:
I have successfully read the vertices and edges from an input file and created a mesh for the lattice structure.
I’ve defined the function space for displacement and rotation using appropriate finite element types.
The stiffness matrix (K) and load vector have been formulated using variational forms, taking into account both bending and shear deformations.
I’ve applied Dirichlet boundary conditions to fix the bottom nodes of the structure.
A compressive force of 100N has been applied to the top nodes, and I’ve attempted to solve the linear system to find the displacement field.
Despite these efforts, the displacement values are resulting in infinity. I suspect there might be an issue with the application of point forces or the assembly of the system, but I’m not sure how to resolve it. I would appreciate any advice on how to solve this issue .
import basix
from dolfinx.mesh import create_mesh, locate_entities_boundary, create_interval
from dolfinx.fem import functionspace, Function, Constant, dirichletbc, locate_dofs_topological, form, apply_lifting, set_bc
from dolfinx.fem.petsc import assemble_matrix, assemble_vector
from ufl import TrialFunction, TestFunction, dot, inner, grad, dx, split
# Define the vertices of the cube
vertices = np.array([
    [-1, -1, -1],
    [1, -1, -1],
    [1, 1, -1],
    [-1, 1, -1],
    [-1, -1, 1],
    [1, -1, 1],
    [1, 1, 1],
    [-1, 1, 1]
# Define the edges of the cube
edges = [
    (0, 1),
    (1, 2),
    (2, 3),
    (3, 0),
    (4, 5),
    (5, 6),
    (6, 7),
    (7, 4),
    (0, 4),
    (1, 5),
    (2, 6),
    (3, 7)
# Define the cell type and degree, including the shape
cell_type = basix.ufl.element("Lagrange", "interval", degree=1, shape=(3,))
# Create the mesh
domain = create_mesh(MPI.COMM_WORLD, edges, vertices, cell_type)
# Verify the mesh
print("Mesh created successfully.")
# Define the function space for displacement (w) and rotation (theta)
U = basix.ufl.element("Lagrange", domain.topology.cell_name(), 2)  # Displacement
T = basix.ufl.element("Lagrange", domain.topology.cell_name(), 1)  # Rotation
V = functionspace(domain, basix.ufl.mixed_element([U, T]))
print("Function space defined successfully.")
(w, theta) = split(u)
(dw, dtheta) = split(v)
print("Trial and test functions defined successfully.")
# Material properties
E = 70e3  # Young's modulus in MPa
nu = 0.3  # Poisson's ratio
G = E / (2 * (1 + nu))  # Shear modulus in MPa
r = 0.05  # Radius of the circular cross-section
A = np.pi * r**2  # Cross-sectional area
I = np.pi * r**4 / 4  # Second moment of area
kappa = 5 / 6  # Shear correction factor
# Define the stiffness matrix (K) bilinear form
k_form = (E * I * inner(grad(theta), grad(dtheta)) * dx +
          kappa * G * dot(grad(w)[0] - theta, grad(dw)[0] - dtheta) * dx)
print("Stiffness matrix bilinear form defined successfully.")
# Define linear form for assembling the stiffness matrix
constant = Constant(domain, PETSc.ScalarType(1.0))
l_form = constant * w * dx
print(" linear form defined successfully.")
# Locate boundary vertices based on minimum z-coordinate
z_min = np.min(vertices[:, 2])
boundary_facets = locate_entities_boundary(domain, domain.topology.dim - 1, lambda x: np.isclose(x[2], z_min))
# Apply Dirichlet boundary condition (e.g., w = 0 on the boundary)
bc = dirichletbc(PETSc.ScalarType(0), locate_dofs_topological(V.sub(0), domain.topology.dim - 1, boundary_facets), V.sub(0))
# Assemble the stiffness matrix (K)
a = form(k_form)
K = assemble_matrix(a, bcs=[bc])
K.assemble()
print("Stiffness matrix assembled successfully.")
# Locate the top nodes based on maximum z-coordinate
z_max = np.max(vertices[:, 2])
top_nodes = locate_entities_boundary(domain, domain.topology.dim - 1, lambda x: np.isclose(x[2], z_max))
# Map the top nodes to DOFs
top_dofs = locate_dofs_topological(V.sub(0), domain.topology.dim - 1, top_nodes)
# Define the force vector (f) with a point load of 100N applied to the top nodes
f = Function(V)
f.vector.set(0.0)
for dof in top_dofs:
    f.vector.array[dof] += 100.0
# Apply boundary conditions to the force vector
apply_lifting(f.vector, [a], bcs=[[bc]], scale=1.0)
f.vector.ghostUpdate(addv=PETSc.InsertMode.ADD, mode=PETSc.ScatterMode.REVERSE)
set_bc(f.vector, [bc])
# Solve the linear system K * u = f
solver.setOperators(K)  # K is already a PETSc Mat
solver.solve(f.vector, u.vector)
u.vector.ghostUpdate()
print("Displacement solution obtained successfully.")
# Print the results
print("Displacement solution:")
for i, displacement in enumerate(u.vector.array):
    print(f"Node {i}: {displacement}")
If someone could help, I would really appreciate
i realized that the boundary condition was not set properly so i modiffied the code , but i still get infinity
here is the updated code
from dolfinx.fem import functionspace, Function, dirichletbc, locate_dofs_topological, form, apply_lifting, set_bc
import basix
    [-1, -1, -1],
    [1, -1, -1],
    [1, 1, -1],
    [-1, 1, -1],
    [-1, -1, 1],
    [1, -1, 1],
    [1, 1, 1],
    [-1, 1, 1]
edges = [
    (0, 1),
    (1, 2),
    (2, 3),
    (3, 0),
    (4, 5),
    (5, 6),
    (6, 7),
    (7, 4),
    (0, 4),
    (1, 5),
    (2, 6),
    (3, 7)
# Create the mesh
# Ensure entity-to-cell connectivity is computed
domain.topology.create_connectivity(domain.topology.dim - 1, domain.topology.dim)
# Verify the mesh
r = 0.5  # Radius of the circular cross-section
# Locate the bottom and top nodes
z_coordinates = domain.geometry.x[:, 2]
min_z = np.min(z_coordinates)
max_z = np.max(z_coordinates)
bottom_nodes = np.where(z_coordinates == min_z)[0]
top_nodes = np.where(z_coordinates == max_z)[0]
# Print the nodes selected for boundary conditions and forces
print("Bottom nodes selected for Dirichlet boundary condition:", bottom_nodes)
print("Top nodes selected for compressive force:", top_nodes)
# Apply Dirichlet boundary condition to fix the bottom nodes
u_bc = Function(V)
with u_bc.vector.localForm() as loc:
    loc.set(0.0)
bc = dirichletbc(u_bc, locate_dofs_topological(V, 0, bottom_nodes))
a = form(k_form)
K.assemble()
# Define the compressive force on the top nodes
force_magnitude = -100.0  # Compressive force in Newtons (negative for compression)
# Create a point source function to apply the force at the top nodes
f = Function(V)
with f.vector.localForm() as loc:
    loc.set(0.0)
    for node in top_nodes:
        loc[node] = force_magnitude / len(top_nodes)
# Print the results
can someone please help :cry:
I am not quite sure how the point source setup is correct (among other things).
In what space exactly do you want the point source?
Do you want a point source for each displacement node and for each rotation node?
Additionally, note that top_nodes and bottom_nodes are not correctly defined wrt. your mixed space, which is why you might be getting unphysical solutions.
Here is a code that updates some aspects of your code, but I cannot give furhter advice without the questions above being addressed:
import basix
    [-1, -1, -1],
    [1, -1, -1],
    [1, 1, -1],
    [-1, 1, -1],
    [-1, -1, 1],
    [1, -1, 1],
    [1, 1, 1],
    [-1, 1, 1]
], dtype=np.float64)
edges = np.array([
    [0, 1],
    [1, 2],
    [2, 3],
    [3, 0],
    [4, 5],
    [5, 6],
    [6, 7],
    [7, 4],
    [0, 4],
    [1, 5],
    [2, 6],
    [3, 7]
], dtype=np.int32)
# Create the mesh
with XDMFFile(MPI.COMM_WORLD, "cube.xdmf", "w") as file:
    file.write_mesh(domain)
# Verify the mesh
from dolfinx.mesh import locate_entities
bottom_nodes = locate_entities(domain, 0, lambda x: np.isclose(x[2], min_z))
top_nodes = locate_entities(domain, 0, lambda x: np.isclose(x[2], max_z))
u_bc = Function(V)
    loc.set(0.0)
print(bc._cpp_object.dof_indices())
a = form(k_form)
K.assemble()
f = Function(V)
    loc.set(0.0)
print(f.x.array)
print(f.x.array)
print(solver.getConvergedReason())
# Print the results
As far as I can tell, you want a compressive force only in z-direction (negative)
Thank you very much for your response.
To answer your question, I want to apply the point load only to the displacement nodes, specifically those located at the top surface of the structure, which are the nodes with the maximum z coordinates. I’m not intending to apply the point source to the rotation nodes
Should the load by applied in all directions or just the z-direction?
The load be applied just z direction
I thought that there might be a problem with the mesh setup, as for this type of problem, each edge of the structure is typically treated as a 1D element in the mesh. Could you please confirm if the mesh creation is correct?
I do not think there is an issue with the mesh creation itself. I think you have misunderstood something when it comes to defining your variational problem (and your finite element spaces) as your spaces are scalar valued, while I would assume that they should be vector valued. See for instance: Elastic 3D beam structures — Computational Mechanics Numerical Tours with FEniCSx
