Probably a straightforward question, but a quick Google search didn’t yield any results so I’m asking it here.
How would one create a rectangular mesh with one of the axis logarithmically spaced?
For example, I want the nodes on the x-axis to be separated linearly with, e.g., np.linspace(0, 100, 21); meanwhile, the y-axis nodes to be at locations that are separated as if they are on a log-axis np.logspace(np.log10(1), np.log10(1000), 21)
Hi, I made the custom mesh using Expression() like this -
# Define the number of intervals and the range of the x-axis
num_intervals_x = 20
x_start = 0.0
x_end = 100.0
# Define the number of intervals and the range of the y-axis
num_intervals_y = 20
y_start = 1.0
y_end = 1000.0
# Create the linearly spaced mesh for the x-axis
mesh_x = IntervalMesh(num_intervals_x, x_start, x_end)
# Create the logarithmically spaced mesh for the y-axis
log_space = Expression("exp(log_start + (log_end - log_start)*x[0]/L)", degree=1,
log_start=np.log(y_start), log_end=np.log(y_end), L=x_end)
# Function space on the x-axis mesh
V = FunctionSpace(mesh_x, "CG", 1)
mesh_y = interpolate(log_space, V)
# Get the coordinates of the mesh for the x-axis
coords_x = mesh_x.coordinates()
# Create the rectangular mesh using the product of the x and y meshes
mesh = RectangleMesh(Point(coords_x.min(), y_start),
Point(coords_x.max(), y_end),
num_intervals_x, num_intervals_y)
You can also verify the coordinates of the mesh -
print(mesh.coordinates())
@violetus Thanks, but the code still seems to create a mesh with a linearly spaced y-axis. The output of the y mesh coordinates is:
>>> print(mesh.coordinates()[:, 1][::21])
[ 1. 50.95 100.9 150.85 200.8 250.75 300.7 350.65 400.6
450.55 500.5 550.45 600.4 650.35 700.3 750.25 800.2 850.15
900.1 950.05 1000. ]
Would it be wrong to just edit the mesh coordinates after creating them with something as simple as:
mesh = RectangleMesh(Point(0, 0), Point(100, 4), 20, 20)
for i_point in range(len(mesh.coordinates())):
mesh.coordinates()[i_point] = [mesh.coordinates()[i_point][0],
10**mesh.coordinates()[i_point][1]]
Hi @DrKorvin, thanks for correcting me, I misunderstood the question and thought that what I did is correct. I ran your code and visualized it -
Looks fine to me.
@violetus Sounds good. Many thanks for the help!
