Marking surfaces with pygmsh 3D
I would like to create a simple cube with a sphere cut out from it.
For some reason I’m not able to assign a physical entity to the boolean difference. I also didn’t find how to marking the surface of the sphere.
"""http://jsdokken.com/converted_files/tutorial_pygmsh.html
import pygmsh
size_box = 1e-3
radius_bubble = 0.1e-3
geom = pygmsh.occ.Geometry()
model3D = geom.__enter__()
box = model3D.add_box(x0=(0-size_box/2, 0-size_box/2, 0-size_box/2), extents=(size_box, size_box, size_box))
bubble = model3D.add_ball(center=(0, 0, 0), radius=radius_bubble)
difference = model3D.boolean_difference(box, bubble)
model3D.synchronize()
model3D.add_physical(difference, "salt")
# mark the surface
geom.generate_mesh()
pygmsh.write("mesh.msh")
    out_mesh = meshio.Mesh(points=points, cells={cell_type: cells}, cell_data={"name_to_read":[cell_data]})
    return out_mesh
mesh_from_file = meshio.read("mesh.msh")
meshio.write("mesh.xdmf", mesh_from_file)
boundary_mesh = create_mesh(mesh_from_file, "triangle")
meshio.write("mesh_bubble_surfaces.xdmf", boundary_mesh)
volume_mesh = create_mesh(mesh_from_file, "tetra")
meshio.write("mesh_bubble_volumes.xdmf", volume_mesh)
This is the error
  File "d:/Projets/MIT/FESTIM/mesh_bubble_pygmsh.py", line 40, in <module>
  File "d:/Projets/MIT/FESTIM/mesh_bubble_pygmsh.py", line 31, in create_mesh
  File "C:\Users\user\AppData\Local\Programs\Python\Python38\lib\site-packages\meshio\_mesh.py", line 178, in get_cell_data
    return np.concatenate(
  File "<__array_function__ internals>", line 180, in concatenate
ValueError: need at least one array to concatenate
I would strongly suggest using the gmsh python interface, as it gives you more freedom to do marking of boundaries.
See for instance: Test problem 2: Flow past a cylinder (DFG 2D-3 benchmark) — FEniCSx tutorial
Thanks for the answer!
Do you even recommend it in 3D?
Yes, I do. It has alot more functionality than pygmsh (as pygmsh is simply a wrapper around the GMSH python API).
You can of course mix the two of them, you can start creating your geometry with pygmsh, and then use the gmsh python API to fetch boundaries so you can mark them.
