Solving for a 3D vector field over a 2D mesh with N1curl elements
Hi all,
I would like to use fenics for solving this electromagnetic problem: finding the scattered field due to an electromagnetic plane wave (linearly polarized along an arbitrary axis) that hits a metallic cylinder, whose axis of symmetry is perpendicular to the propagation direction of the field.
The problem can be considered as a 2D problem, due to symmetry. For this reason, I was thinking of implementing a 2D mesh and using a 3D vector electric field defined over the 2D mesh.
Before of implementing this kind of simulation, I tried to solve a simpler problem (the propagation of an electromagnetic plane wave) with this code:
mesh = UnitSquareMesh(12, 12)
V = FunctionSpace(mesh, 'N1curl', 2)
# Define k-vector
k_x = Constant(2*pi)
k_y = Constant(0)
k_z = Constant(0)
k = Constant((k_x, k_y, k_z))
# Define phase
phi = 0
# Define Field Polarization
u_x = 0
u_y = 1
u_z = 1
# Define the vector n normal on the boundary
# Define where to apply boundary conditions
def boundary(x, on_boundary):
    return on_boundary
# Define the expression for the field on the boundary
u_D = Expression(('u_x*cos(k_x*x[0]+k_y*x[1]+phi)',
                'u_y*cos(k_x*x[0]+k_y*x[1]+phi)',
                'u_z*cos(k_x*x[0]+k_y*x[1]+phi)'),
                 degree=2, u_x=u_x, u_y=u_y, u_z=u_z,
                 k_x=k_x, k_y=k_y, phi=phi, domain = mesh)
# Define the Dirichlet boundary condition
F = dot(k, k)*inner(u, v)*dx - inner(curl(u), curl(v))*dx
a, L = lhs(F), rhs(F)
# Compute solution
solve(a == L, u, bc)
That gives me this error:
keyTraceback (most recent call last):
  File "plane_wave.py", line 36, in <module>
  File "/usr/lib/petsc/lib/python3/dist-packages/dolfin/fem/dirichletbc.py", line 131, in __init__
    super().__init__(*args)
RuntimeError:
*** Error:   Unable to create Dirichlet boundary condition.
*** Reason:  Illegal value dimension (3), expecting (2).
*** Where:   This error was encountered inside DirichletBC.cpp.
*** Process: 0
*** Git changeset:  unknown
This error maybe can be solved easily, but it let me think about the feasibility of what I want to do: solving for a 3D vector field over a 2D geometry in fenics, especially when N1curl elements are involved.
Is this possible? Or are there any issues in doing that?
Thanks.
One should carefully consider the meaning of the H(\mathrm{curl};\Omega) conforming Nédélec element in the 2D and 3D setting. If you wish include some kind of slab symmetry, I expect the infinite axial component would belong to another space. You would then need to redefine the div, grad and curl UFL operators to accommodate this formulation.
I believe these techniques are investigated in Jian-Ming Jin’s book in the context of waveguides. For analysis I’d consult Peter Monk’s book. I vaguely recall it’s common practice when discretising waveguide models.
