Hello everyone,
I greatly appreciate the assistance provided in this discussion—it has been quite helpful. Thank you for that! However, I am still encountering a related issue that I am unable to resolve on my own.
My objective is to compute the volume integral of a tensor-valued function within a mixed function space. I am considering three approaches, all of which, in my opinion, should yield similar results:
- Utilizing the divergence theorem and performing a surface integral over the boundary of the domain.
- Conducting a volume integral and initially applying the
ufl.div operation to the tensor.
- Calculating the nodal forces as previously discussed and summing them up.
My preference lies with the third option, but I am unable to achieve the anticipated results (which I obtain for options 1 and 2). Additionally, I am struggling to properly configure option 3 so that the results are at least unaffected by the number of processes.
I have also prepared a minimal working example for which it is feasible to compute the correct result. The setup involves a 1x1x1 cube with relatively straightforward fields, from which I derive the tensor-valued function and subsequently attempt to compute the integral using all three options.
My primary concern pertains to how to correctly establish option 3. Any insights you could provide would be greatly appreciated.
Best regards, Alex
import dolfinx as dlfx
import os
from dolfinx.cpp.la import InsertMode
script_path = os.path.dirname(__file__)
comm = MPI.COMM_WORLD
N = 16
domain = dlfx.mesh.create_unit_cube(comm,N,N,N,cell_type=dlfx.mesh.CellType.hexahedron)
Ve = ufl.VectorElement("Lagrange", domain.ufl_cell(), 1)
Te = ufl.FiniteElement("Lagrange", domain.ufl_cell(), 1)
W = dlfx.fem.FunctionSpace(domain, ufl.MixedElement([Ve, Te]))
w = dlfx.fem.Function(W)
w.sub(0).sub(0).interpolate(lambda x: x[0])
w.sub(0).sub(1).interpolate(lambda x: x[1])
w.sub(0).sub(2).interpolate(lambda x: x[2])
w.sub(1).interpolate(lambda x: x[0])
u,s = w.split()
def tensor_function_of_u_s(u,s):
return ufl.as_tensor([[u[0]*s, 0, 0],
[u[1], 0, 0],
[u[2], 0, 0]
tensor = tensor_function_of_u_s(u,s)
##1. from surface integral ###############################
# returns the expected value 1 and is independent on number of processes
def surface_integral_of_tensor(tensor, n: ufl.FacetNormal, ds: ufl.Measure = ufl.ds):
Jx = (tensor[0,0]*n[0]+tensor[0,1]*n[1]+tensor[0,2]*n[2])*ds
Jxa = dlfx.fem.assemble_scalar(dlfx.fem.form(Jx))
Jy = (tensor[1,0]*n[0]+tensor[1,1]*n[1]+tensor[1,2]*n[2])*ds
Jya = dlfx.fem.assemble_scalar(dlfx.fem.form(Jy))
Jz = (tensor[2,0]*n[0]+tensor[2,1]*n[1]+tensor[2,2]*n[2])*ds
Jza = dlfx.fem.assemble_scalar(dlfx.fem.form(Jz))
return Jxa, Jya, Jza
n = ufl.FacetNormal(domain)
Jx_s, Jy_s, Jz_s = surface_integral_of_tensor(tensor,n)
##2. from volume integral ###############################
def volume_integral_of_tensor(tensor, dx: ufl.Measure = ufl.dx):
Jxa = dlfx.fem.assemble_scalar(dlfx.fem.form( ( ( ufl.div(tensor)[0] ) * dx ) ))
Jya = dlfx.fem.assemble_scalar(dlfx.fem.form( ( ( ufl.div(tensor)[1] ) * dx ) ))
Jza = dlfx.fem.assemble_scalar(dlfx.fem.form( ( ( ufl.div(tensor)[2] ) * dx )))
Jx_v, Jy_v, Jz_v = volume_integral_of_tensor(tensor)
##3. from nodal values ###############################
# fails to return the expected value 1 and is dependent on number of processes
dw = ufl.TestFunction(W)
du, dv = ufl.split(dw)
J_nodal_vector : dlfx.la.Vector = dlfx.fem.assemble_vector(dlfx.fem.form( ufl.inner(-tensor, ufl.grad(du))*ufl.dx ))
# J_nodal_vector.scatter_reverse(InsertMode.add)
# cast into function
temp = dlfx.fem.Function(W)
temp.sub(0).x.array[:] = J_nodal_vector.array
J_nodal_function = temp.sub(0).collapse()
Jx_from_sum_of_nodal_vectors = np.sum(J_nodal_function.sub(0).x.array)
print('Jx from surface integral: {0:.4e}\nJx from volume integral: {1:.4e}\nJx from nodal vectors: {2:.4e}'.format(Jx_s, Jx_v, Jx_from_sum_of_nodal_vectors))
