Okay, thank you a lot! I’ll do that!
def solve_flow(*args, **kwargs):
# Handle optional arguments
mesh_file = kwargs.get('mesh_file', 'shape.xml')
output = kwargs.get('output', False)
final_time = kwargs.get('final_time', 15.0)
reynolds = kwargs.get('reynolds', 10.0)
pts_x = kwargs.get('pts_x', np.array([]))
pts_y = kwargs.get('pts_y', np.array([]))
cfl = kwargs.get('cfl', 0.5)
xmin = kwargs.get('xmin', -15.0)
xmax = kwargs.get('xmax', 30.0)
ymin = kwargs.get('ymin', -15.0)
ymax = kwargs.get('ymax', 15.0)
# Parameters
v_in = 1.0
mu = 1.0/reynolds
rho = 1.0
tag_shape = 5
x_shape = 4.0
y_shape = 4.0
sol_file = 'shape.pvd'
# Create subdomain containing shape boundary
class Obstacle(SubDomain):
return (on_boundary and
(-x_shape < x[0] < x_shape) and
(-y_shape < x[1] < y_shape))
# Define symmetric gradient
return sym(nabla_grad(u))
# Define stress tensor
def sigma(u, p):
return 2.0*mu*epsilon(u) - p*Identity(len(u))
# Compute drag and lift
def compute_drag_lift(u, p, mu, normal, gamma):
eps = 0.5*(nabla_grad(u) + nabla_grad(u).T)
sigma = 2.0*mu*eps - p*Identity(len(u))
traction = dot(sigma, normal)
forceX = traction[0]*gamma
forceY = traction[1]*gamma
fX = assemble(forceX)
fY = assemble(forceY)
return (fX, fY)
# Create mesh
# Ugly hack : change dim=3 to dim=2 in xml mesh file
os.system("sed -i 's/dim=\"3\"/dim=\"2\"/g' "+mesh_file)
mesh = Mesh(mesh_file)
h = mesh.hmin()
# Compute timestep and max nb of steps
dt = cfl*h/v_in
timestep = dt
T = final_time
num_steps = math.floor(T/dt)
# Define output solution file
vtkfile = File(sol_file)
# Define function spaces
Q = FunctionSpace (mesh, 'P', 1)
# Define boundaries
inflow = 'near(x[0], '+str(math.floor(xmin))+')'
outflow = 'near(x[0], '+str(math.floor(xmax))+')'
wall1 = 'near(x[1], '+str(math.floor(ymin))+')'
wall2 = 'near(x[1], '+str(math.floor(ymax))+')'
shape = 'on_boundary && x[0]>(-'+str(x_shape)+') && x[0]<'+str(x_shape)+' && x[1]>(-'+str(y_shape)+') && x[1]<('+str(y_shape)+')'
# Define boundary conditions
bcu_inflow = DirichletBC(V, Constant((v_in, 0.0)), inflow)
bcu_wall1 = DirichletBC(V.sub(1), Constant(0.0), wall1)
bcu_wall2 = DirichletBC(V.sub(1), Constant(0.0), wall2)
bcu_aile = DirichletBC(V, Constant((0.0, 0.0)), shape)
bcp_outflow = DirichletBC(Q, Constant(0.0), outflow)
bcu = [bcu_inflow, bcu_wall1, bcu_wall2, bcu_aile]
bcp = [bcp_outflow]
# Tag shape boundaries for drag_lift computation
obstacle = Obstacle()
boundaries = MeshFunction('size_t', mesh, mesh.topology().dim()-1)
boundaries.set_all(0)
obstacle.mark(boundaries, tag_shape)
ds = Measure('ds', subdomain_data=boundaries)
gamma_shape = ds(tag_shape)
p, q = TrialFunction(Q), TestFunction(Q)
# Define functions for solutions at previous and current time steps
u_n, u_, u_m = Function(V), Function(V), Function(V)
p_n, p_ = Function(Q), Function(Q)
# Define initial value
global n_call
global u_0
if (n_call != 0):
u_0.set_allow_extrapolation(True)
u_n = project(u_0, V)
show = True
show = False
# Define expressions and constants used in variational forms
U = 0.5*(u_n + u)
f = Constant((0, 0))
dt = Constant(dt)
mu = Constant(mu)
rho = Constant(rho)
# Set BDF2 coefficients for 1st timestep
bdf2_a = Constant( 1.0)
bdf2_b = Constant(-1.0)
bdf2_c = Constant( 0.0)
# Define variational problem for step 1
# Using BDF2 scheme
F1 = dot((bdf2_a*u + bdf2_b*u_n + bdf2_c*u_m)/dt, v)*dx + dot(dot(u_n, nabla_grad(u)), v)*dx + inner(sigma(u, p_n), epsilon(v))*dx + dot(p_n*n, v)*ds - dot(mu*nabla_grad(u)*n, v)*ds - dot(f, v)*dx
a1 = lhs(F1)
L1 = rhs(F1)
a2 = dot(nabla_grad(p), nabla_grad(q))*dx
L2 = dot(nabla_grad(p_n), nabla_grad(q))*dx - (bdf2_a/dt)*div(u_)*q*dx
a3 = dot(u, v)*dx
L3 = dot(u_, v)*dx - (dt/bdf2_a)*dot(nabla_grad(p_ - p_n), v)*dx
# Assemble A3 matrix since it will not need re-assembly
A3 = assemble(a3)
# Initialize drag and lift
drag = 0.0
lift = 0.0
lfdr = 0.0
drag_inst = np.array([])
lift_inst = np.array([])
lfdr_inst = np.array([])
drag_avg = np.array([])
lift_avg = np.array([])
lfdr_avg = np.array([])
# Time-stepping loop
try:
k = 0
t = 0.0
t_arr = np.array([])
for m in range(num_steps):
# Update current time
t += timestep
A1 = assemble(a1)
b1 = assemble(L1)
[bc.apply(A1) for bc in bcu]
[bc.apply(b1) for bc in bcu]
solve(A1, u_.vector(), b1, 'bicgstab', 'hypre_amg') #gmres
A2 = assemble(a2)
b2 = assemble(L2)
[bc.apply(A2) for bc in bcp]
[bc.apply(b2) for bc in bcp]
solve(A2, p_.vector(), b2, 'bicgstab', 'hypre_amg')
b3 = assemble(L3)
solve(A3, u_.vector(), b3, 'cg', 'sor')
# Update previous solution
u_m.assign(u_n)
u_n.assign(u_)
p_n.assign(p_)
# Compute and store drag and lift
avg_start_it = math.floor(num_steps/2)
if (m > avg_start_it):
(fX,fY) = compute_drag_lift(u_, p_, mu, n, gamma_shape)
drag_inst = np.append(drag_inst, fX)
lift_inst = np.append(lift_inst, fY)
lfdr_inst = np.append(lfdr_inst, fY/fX)
drag += fX
lift += fY
lfdr += fY/fX
drag_avg = np.append(drag_avg, drag/(k+1))
lift_avg = np.append(lift_avg, lift/(k+1))
lfdr_avg = np.append(lfdr_avg, lfdr/(k+1))
t_arr = np.append(t_arr, t)
# Increment local counter
k += 1
# Set BDF2 coefficients for m>1
bdf2_a.assign(Constant( 3.0/2.0))
bdf2_b.assign(Constant(-2.0))
bdf2_c.assign(Constant( 1.0/2.0))
# # Check execution time
# end = time.time()
# elapsed = end - start
# if (elapsed > max_time):
# return 0.0, 0.0, False
# Ouput field maps if necessary
if (output):
start_it = 0
uu = interpolate(u_n, V)
pp = interpolate(p_n, Q)
u = uu.sub(0)
v = uu.sub(1)
but if you have other smart ideas, don’t hesitate to share
