Mesh.locate_entities_boundary() does not seem to work if importing mesh nodes and cells
When I generate a mesh using dolfinx, I can do the following and it generates the right boundary condition:
# Function to mark noslip bc
def noslip_boundary2(x):
    return np.isclose(x[2], z_val)
# No slip boundary condition 2
noslip  = fem.Function(V)
facets2 = mesh.locate_entities_boundary(msh, fdim, noslip_boundary2)
dofs2   = fem.locate_dofs_topological((W.sub(0), V), fdim, facets2)
bc1     = fem.dirichletbc(noslip, dofs2, W.sub(0))
But when I import a mesh using meshio, using the same above two functions does not work. Am I missing a line to generate boundary facets? How is that done?
How can I generate the cell-node connectivity matrix vol_mesh.cells[1].data from msh? (to make a running example)?
vol_mesh = meshio.read('mesh.vtk')
points = vol_mesh.points
cells  = vol_mesh.cells[1].data
c_el = ufl.Mesh(basix.ufl.element("Lagrange", "tetrahedron", 1, shape=(points.shape[1],)))
msh = mesh.create_mesh(MPI.COMM_WORLD, cells, points, c_el)
fdim = msh.topology.dim - 1
msh.topology.create_connectivity(fdim, fdim+1)
Thank you,
Alex
Could you be more specific? Does it throw an error or are you getting an unexpected result?
Either way, we would need a reproducible example with the full error trace to help you further
Hi, sure, I am importing a vtk mesh:
I tried the same code using a box generated by dolfinx and the code works. If I use the mesh I get this for the velocity magnitude:
The boundary conditions should be no slip at the cone and top cylinder (not the top cap) boundary facets, and at the bottom cap (which is not working at all)
Thank you for your time,
Alex
This is the running code:
# Geometry variables
h_array_1 = 0.02
h_array_2 = 0.035
h_gap     = 0.03
rho_air = fem.Constant(msh, 1.225)
mu_air  = fem.Constant(msh, 1.8e-3)
def noslip_boundary1(x):
    return np.logical_and(x[2] < h_array_2, x[2] > -h_array_1)
    return np.isclose(x[2], (h_array_2 + h_gap))
# the same as old ufl.VectorElement
# the same as old ufl.FiniteElement
P2 = basix.ufl.element("Lagrange", msh.topology.cell_name(), 2, shape=(msh.geometry.dim, ))
P1 = basix.ufl.element("Lagrange", msh.topology.cell_name(), 1)
V, Q = fem.functionspace(msh, P2), fem.functionspace(msh, P1)
# Create the function space
TH = basix.ufl.mixed_element([P2, P1])
W = fem.functionspace(msh, TH)
W0, _ = W.sub(0).collapse()
# No slip boundary condition 1
facets1 = mesh.locate_entities_boundary(msh, fdim, noslip_boundary1)
dofs1   = fem.locate_dofs_topological((W.sub(0), V), fdim, facets1)
bc0     = fem.dirichletbc(noslip, dofs1, W.sub(0))
# Since for this problem the pressure is only determined up to a constant, we pin it at a point
zero = fem.Function(Q)
zero.x.array[:] = 0
dofs = fem.locate_dofs_geometrical(
    (W.sub(1), Q), lambda x: np.isclose(x.T, [0.0, 0.0, -h_array_1], atol=0.01).all(axis=1))
bc2 = fem.dirichletbc(zero, dofs, W.sub(1))
def body_force_fun(x):
    F_max    = 2.0e-2
    z_offset = 0.02
    r_xy = np.sqrt(x[0]**2 + x[1]**2)
    a = 0.005
    max_val = a * np.exp(-0.5)
    Fr_val  = np.exp(-r_xy**2/(2*a**2)) / max_val
    b = 0.005
    Fz_val = np.exp(-(x[2]-z_offset)**2/(2*b**2))
    F_mag  = F_max * Fr_val * Fz_val
    # -ve sign to get clockwise rotation from array top
    return -F_mag * np.vstack((x[1], -x[0], np.zeros_like(x[2])))
Force_per_unit_vol = fem.Function(V)
Force_per_unit_vol.interpolate(lambda x: body_force_fun(x))
bcs = [bc0, bc1, bc2]
w = fem.Function(W)
(u, p) = ufl.split(w)
(v, q) = ufl.TestFunctions(W)
# Tentative velocity step
# https://github.com/bragostin/Fenics/blob/main/HTC_SquareDuct_Steady_Neumann_Minimal_Pub.py
# https://math.stackexchange.com/questions/1952588/
# weak-form-of-steady-navier-stokes-equations-with-special-boundary-condition
F = rho_air*inner(grad(u)*u, v)*dx + \
    mu_air*inner(grad(u), grad(v))*dx + \
    inner(Force_per_unit_vol, v)*dx - \
    inner(p, div(v))*dx - \
    div(u)*q*dx
dw = ufl.TrialFunction(W)
dF = ufl.derivative(F, w, dw)
problem = NonlinearProblem(F, w, bcs=bcs, J=dF)
solver.rtol   = 1e-6
#solver.max_it = 2
solver.report = True
solver.error_on_nonconvergence = False
# Custom solver options (not needed for code readibility but makes code 9x faster)
opts = PETSc.Options()  # type: ignore
ksp = solver.krylov_solver
ksp.setFromOptions()
# Compute the solution
start = time.time()
solver.solve(w)
end   = time.time()
print('\n')
print(msh.topology.index_map(msh.topology.dim).size_local)
print((end - start) / 60)
u = w.sub(0).collapse()
p = w.sub(1).collapse()
# Write the solution to file
with io.XDMFFile(MPI.COMM_WORLD, "pressure.xdmf", "w") as pfile_xdmf:
    p.x.scatter_forward()
    pfile_xdmf.write_mesh(msh)
    pfile_xdmf.write_function(p)
with io.XDMFFile(MPI.COMM_WORLD, "velocity.xdmf", "w") as ufile_xdmf:
    u.x.scatter_forward()
    P1 = basix.ufl.element("Lagrange", msh.basix_cell(), 1, shape=(msh.geometry.dim,))
    u1 = fem.Function(fem.functionspace(msh, P1))
    u1.interpolate(u)
    ufile_xdmf.write_mesh(msh)
    ufile_xdmf.write_function(u1)
with io.XDMFFile(MPI.COMM_WORLD, "body_force.xdmf", "w") as ufile_xdmf:
    Force_per_unit_vol.x.scatter_forward()
    u1.interpolate(Force_per_unit_vol)
I sorted it out, I was not considering the meshing program is not placing the facets very accurately on the surfaces, the marking functions should be as follows:
mark_eps = 2.0e-3
    return np.logical_and(x[2] < (h_array_2 + mark_eps), np.sqrt(x[0]**2 + x[1]**2) > (r2-mark_eps))
    return np.isclose(x[2], (h_array_2 + h_gap), mark_eps)
