Following the example for MFEM and Poisson’s equation here, I am trying to solve the following system
where K is a spatially varying constant. I’m testing my code on a simple problem: square domain with the boundary conditions given as
and a discontinuous K field
When I run this problem with a structured mesh, the solution for q is smooth and well behaved at the K discontinuity, so long as a string of edges matches the location of the discontinuity. Here is a plot of q overlaid with streamlines zoomed in on the K interface -
However, when I run the same problem with an unstructured mesh, the solution for q shows unphysical, sporadic oscillations. Of course, I have ensured that a string of edges in the unstructured mesh runs along the discontinuity in K, just as I did for the structure mesh. Here is the same plot, but for the unstructured mesh -
The solutions for h are essentially identical in both cases. They are smooth and well behaved.
My question may be more about FEM in general rather than FEniCS specific: Does anyone know why MFEM would have difficulties solving this system with an unstructured mesh (even with a string of mesh edges running along the discontinuity)? Can MFEM handle a heterogenous parameter space such as K in this formulation? Any comments are welcomed! Thank you in advance!
Here is a basic working code:
import mshr
# Sturctured mesh
mesh = RectangleMesh(Point(0.0,0.0),Point(10.0,10.0),100,100)
# Unstructured mesh
# domain = mshr.Polygon([Point(0.0,0.0),Point(10.0,0.0),Point(10.0,10.0),Point(0.0,10.0)])
# domain.set_subdomain(1,mshr.Polygon([Point(0.0,0.0),Point(10.0,0.0),Point(10.0,5.0),Point(0.0,5.0)]))
# res = 200
# mesh = mshr.generate_mesh(domain,res)
ele_h = FiniteElement("DG", mesh.ufl_cell(), 0)
ele_q = FiniteElement("BDM", mesh.ufl_cell(), 1)
W = MixedElement([ele_h, ele_q])
W = FunctionSpace(mesh, W)
def K1():
K_1_val = Constant(1.0)
return K_1_val
def K2():
K_2_val = Constant(100.0)
return K_2_val
class h_boundary(SubDomain):
return on_boundary
h_Boundary = h_boundary()
boundaries = MeshFunction('size_t',mesh,1)
boundaries.set_all(0)
h_Boundary.mark(boundaries,1)
Boundary_head = Expression('sin(x[0]) + sin(x[1])',degree = 5)
class Upper(SubDomain):
return x[1] >= 5.0
upper = Upper()
domains = MeshFunction('size_t',mesh,2)
domains.set_all(2)
upper.mark(domains,1)
norm = as_vector([n[0], n[1]])
Xf = Function(W)
dx = Measure('dx')(subdomain_data = domains)
ds = Measure('ds')(subdomain_data = boundaries)
U = TrialFunction(W)
V = TestFunction(W)
h, q = split(U)
Ht, Qt = split(V)
a = div(q)*Ht*dx(1) + div(q)*Ht*dx(2) + inner(q,Qt)/K1()*dx(1) + inner(q,Qt)/K2()*dx(2) - h*div(Qt)*dx(1) - h*div(Qt)*dx(2)
L = - Boundary_head*inner(Qt,norm)*ds(1)
A, b = assemble_system(a,L)
solve(A, Xf.vector(), b, 'umfpack')
h, q = Xf.split(True)
h_file = XDMFFile('h.xdmf')
q_file = XDMFFile('q.xdmf')
h_file.write(h)
q_file.write(q)
