Mixed grad over mixed formulation
Dear community,
I face a problem that I cannot explain scientifically, so either I’m wrong (highly possible) or something is wrong in my implementation. My problem is quite large to provide a relevant MWE, so I’m going to start small by a non-physical problem that includes my concern.
Let \Omega be a domain and \Gamma the boundary closed boundary of \Omega, e.g \Omega is a sphere. Let suppose the following weak formulation
(p,q)\in(\Omega\times\Gamma)
(v,u)\in(L_2(\Omega)\times L_2(\Gamma))
\begin{cases} \int_{\Omega}\nabla p\cdot \nabla vd\Omega +\int_\Gamma q\cdot vd\Gamma = \int_\Omega g\cdot vd\Omega \\ \int_{\Gamma}\nabla p\cdot \nabla ud\Gamma+\int_\Gamma q\cdot u d\Gamma=0 \end{cases}
My concern is about the implementation of the term \int_{\Gamma}\nabla p\cdot \nabla ud\Gamma.
Here is my full implementation leading to no error, followed by my configuration :
from dolfinx.io import gmshio
import dolfinx.mesh as msh
from ufl import (TestFunction, TrialFunction, TestFunctions, TrialFunctions,
                 Measure,
                 FacetNormal, CellNormal,
                 inner, grad, div,
                 Dn,
                 MixedFunctionSpace,
                 extract_blocks)
from basix.ufl import element
from dolfinx.fem import functionspace, form, petsc
def create_sphere_mesh(R=0.3, lc=0.03):
    model_name = "sphere"
    comm = MPI.COMM_WORLD
    model_rank = 0
    model = gmsh.model()
    gmsh.model.add(model_name)
    # Create a sphere of radius R centered at the origin
    gmsh.model.occ.addSphere(0, 0, 0, R)
    gmsh.model.occ.synchronize()
    # Physical groups: volume (3D) and external surface (2D)
    gmsh.model.addPhysicalGroup(3, [1], tag=1)
    gmsh.model.addPhysicalGroup(2, [1], tag=2)  # external surface
    # Mesh generation settings
    # gmsh.option.setNumber("Mesh.CharacteristicLengthMin", lc)  # optional
    gmsh.option.setNumber("Mesh.CharacteristicLengthMax", lc)
    gmsh.model.mesh.generate(3)
    # Save the mesh to file
    gmsh.write(model_name + ".msh")
    # Import mesh into DOLFINx
    mesh_data = gmshio.model_to_mesh(model, comm, model_rank)
    final_mesh = mesh_data.mesh
    cell_tags = mesh_data.cell_tags
    facet_tags = mesh_data.facet_tags
    print(f'facet_tags.indices : {facet_tags.indices}')  # boundary entity indices
    print(f'facet_tags.values : {facet_tags.values}')    # corresponding tags
    # Close gmsh
    gmsh.finalize()
    tdim = final_mesh.topology.dim
    fdim = tdim - 1
    #xref = [-0.07, 0.007, 0.007]
    xref = [0.0, 0.2, 0.0]
    submesh, entity_map = msh.create_submesh(final_mesh, fdim, facet_tags.find(2))[0:2]
    entity_maps_mesh = [entity_map]
    mesh_info = [final_mesh, cell_tags, facet_tags, xref] # this line is new
    submesh_info = [submesh, entity_maps_mesh]
    return mesh_info, submesh_info
mesh_info, submesh_info = create_sphere_mesh(R=0.3, lc=0.03)
final_mesh, cell_tags, facet_tags, xref = mesh_info
submesh, entity_maps_mesh = submesh_info
dx = Measure("dx", domain=final_mesh)
ds = Measure("ds", domain=final_mesh, subdomain_data=facet_tags)
dx1 = Measure("dx", domain=submesh)
# Define a Lagrange element of degree 2
P1 = element("Lagrange", final_mesh.basix_cell(), 2)
P = functionspace(final_mesh, P1)
Q1 = element("Lagrange", submesh.basix_cell(), 2)
Q = functionspace(submesh, Q1)
p, v = TrialFunction(P), TestFunction(P)
q, u = TrialFunction(Q), TestFunction(Q)
# Define the weak form
a_00 = inner(p, v) * dx
a_01 = inner(q, v) * ds(2)
a_10 = inner(grad(p), grad(u)) * ds(2)
a_11 = inner(q, u) * dx1
# Assemble the total form
A_00 = form(a_00)
A_01 = form(a_01, entity_maps=entity_maps_mesh)
A_10 = form(a_10, entity_maps=entity_maps_mesh)
A_11 = form(a_11)
If it’s relevant this is my configuration (installed with spack) :
========== Versions FEniCSx ==========
dolfinx version : 0.10.0.0
ufl version     : 2025.2.0.dev0
basix version   : 0.10.0.0
mpi4py version  : 4.0.1
I don’t really know how to present you the results I face without giving you thousands of lines of code, but it looks like the line
leads to a term equals to 0…
Would that trigger anything from you ? have you ever faced something like this ? would it be possible that the following line is wrongly expressed ?
Do not hesitate to ask for any details.
Thank you,
Pierre.
Perhaps you can run your code in a simple domain to determine if the error (which should be logged, at least in part) is originating from the difference between final_mesh and submesh.
I will try so. The problem is that I don’t have any compiling error. It’s just that computing the gradient of a function defined on the mesh, is different than computing the grad of the function defined on the submesh. Because of that, when they are both under the same integral, I suppose that the term is just uncomputed and lead to a zero term. When I run my full code with and without the problematic term
inner(grad(p), grad(u)) *ds(2)
I obtain similar results.
I will try to provide a more explicit MWE.
First of all, I don’t understand how you can be running DOLFINx 0.10 with the `
import.
Secondly, running this with 0.10 (stable docker image), i do not get zeros in this matrix:
from dolfinx.io import gmsh as gmshio
from ufl import (
    TestFunction,
    TrialFunction,
    Measure,
    inner,
    grad,
    model_rank = 0
    print(f"facet_tags.indices : {facet_tags.indices}")  # boundary entity indices
    print(f"facet_tags.values : {facet_tags.values}")  # corresponding tags
    # Close gmsh
    gmsh.finalize()
    fdim = tdim - 1
    # xref = [-0.07, 0.007, 0.007]
A = petsc.assemble_matrix(A_10)
print(A[:, :])
parts of output:
Info    : Done optimizing mesh (Wall 0.0445447s, CPU 0.039008s)
Info    : 4052 nodes 23284 elements
Info    : Writing 'sphere.msh'...
Info    : Done writing 'sphere.msh'
facet_tags.indices : [    0     2     4 ... 41775 41776 41777]
facet_tags.values : [2 2 2 ... 2 2 2]
[[ 0.01108774  0.19918193 -0.09863124 ...  0.          0.
   0.        ]
 [ 0.18408635  0.87914159  0.19346853 ...  0.          0.
   0.        ]
 [ 0.19004592  0.19480287 -0.86592515 ...  0.          0.
   0.        ]
 [ 0.          0.          0.         ...  2.36342212 -0.81277819
  -0.79519326]
 [ 0.          0.          0.         ... -0.81277819  2.28266852
  -0.70365804]
 [ 0.          0.          0.         ... -0.79519326 -0.70365804
   1.15484162]]
