Hello everyone,
I would like to implement a problem that could be written like this (\Omega is a volumic domain and \Gamma is a surface of \Omega):
(p, q)\in\Omega\times\Gamma
(v, u)\in\Omega\times\Gamma
\begin{cases}\int_\Omega p \cdot vd\Omega + \int_\Gamma q\cdot v d\Gamma = 0 \\ \int_\Gamma p \cdot \frac{du}{dx}d\Omega + \int_\Gamma q\cdot u d\Gamma = 0\end{cases}
The mathematical meaning of this formulation is not relevant, but this formulation illustrates my issue, and more important, the code that comes below.
The following code :
from dolfinx.io import gmshio
from ufl import (TestFunction, TrialFunction, TestFunctions, TrialFunctions,
Measure,
FacetNormal, CellNormal,
inner, grad, div,
Dn,
MixedFunctionSpace,
extract_blocks)
from basix.ufl import element
from dolfinx.fem import functionspace, form, petsc
import dolfinx.io.gmshio as gmshio
import dolfinx.mesh as dmesh
def generate_cube_gmshio(side_length=1.0, filename="cube.msh"):
Generate a cube with side length `side_length`,
export the mesh to `filename`, and return:
- final_mesh (full mesh)
- cell_tags (tags for volume)
- facet_tags (tags for surfaces)
- submesh (mesh of one face)
- entity_map (relation between submesh entities and parent mesh)
# Initialize the Gmsh API
comm = MPI.COMM_WORLD
model_rank = 0
model = gmsh.model
model.add("cube")
# Create the cube
box_tag = model.occ.addBox(0, 0, 0, side_length, side_length, side_length)
model.occ.synchronize()
# Retrieve surfaces (dim=2)
surfaces = model.occ.getEntities(dim=2)
# Identify the face at z=0
face_z0 = None
for s in surfaces:
com = model.occ.getCenterOfMass(s[0], s[1])
if abs(com[2]) < 1e-8: # z=0 face
face_z0 = s[1]
break
if face_z0 is None:
raise RuntimeError("Face at z=0 not found!")
# Add physical groups
model.addPhysicalGroup(3, [box_tag], tag=1) # volume
model.addPhysicalGroup(2, [face_z0], tag=10) # surface z=0
# Mesh options
gmsh.option.setNumber("Mesh.ElementOrder", 2)
gmsh.option.setNumber("Mesh.HighOrderOptimize", 2)
model.mesh.generate(3)
# Save mesh
gmsh.write(filename)
# Convert to FEniCSx
final_mesh, cell_tags, facet_tags = gmshio.model_to_mesh(
model, comm, model_rank
gmsh.finalize()
# --- Create submesh of face z=0 ---
# Extract entities of the facet with tag=10
facets = facet_tags.find(10)
# Create the submesh (dim=2 since we want a surface)
submesh, entity_map = dmesh.create_submesh(
final_mesh, dim=2, entities=facets
)[0:2]
tdim = final_mesh.topology.dim
fdim = tdim - 1
submesh_tdim = submesh.topology.dim
submesh_fdim = submesh_tdim - 1
# Create the entity maps and an integration measure
mesh_facet_imap = final_mesh.topology.index_map(fdim)
mesh_num_facets = mesh_facet_imap.size_local + mesh_facet_imap.num_ghosts
extract = np.array([entity_map.tolist().index(entity) if entity in entity_map else -1 for entity in range(mesh_num_facets)])
entity_maps_mesh = {submesh: extract}
return final_mesh, cell_tags, facet_tags, submesh, entity_maps_mesh
# Example usage:
if __name__ == "__main__":
# Generate a cube mesh and retrieve mesh data
final_mesh, cell_tags, facet_tags, submesh, entity_maps_mesh = generate_cube_gmshio(1.0, "cube.msh")
# Define volume (dx) and surface (ds) measures
dx = Measure("dx", domain=final_mesh)
ds = Measure("ds", domain=final_mesh, subdomain_data=facet_tags)
dx1 = Measure("dx", domain=submesh)
# Define a Lagrange element of degree 3
P1 = element("Lagrange", final_mesh.basix_cell(), 2)
P = functionspace(final_mesh, P1)
Q1 = element("Lagrange", submesh.basix_cell(), 2)
Q = functionspace(submesh, Q1)
p, v = TrialFunction(P), TestFunction(P)
q, u = TrialFunction(Q), TestFunction(Q)
# Define the weak form
a_00 = inner(p, v) * dx
a_01 = inner(q, v) * ds(10)
a_10 = inner(p, u.dx(0)) * ds(10)
a_11 = inner(q, u) * dx1
# Assemble the total form
A_00 = form(a_00)
A_01 = form(a_01, entity_maps=entity_maps_mesh)
A_10 = form(a_10, entity_maps=entity_maps_mesh)
A_11 = form(a_11)
print("end")
provides this error :
libffcx_forms_9b64614a007c2a27dc174c07011f9d15d75b6f69.c:2489:10: error: redefinition of 'J_c3'
2489 | double J_c3 = 0.0;
libffcx_forms_9b64614a007c2a27dc174c07011f9d15d75b6f69.c:2487:10: note: previous definition is here
2487 | double J_c3 = 0.0;
libffcx_forms_9b64614a007c2a27dc174c07011f9d15d75b6f69.c:2490:10: error: redefinition of 'J_c4'
2490 | double J_c4 = 0.0;
libffcx_forms_9b64614a007c2a27dc174c07011f9d15d75b6f69.c:2486:10: note: previous definition is here
2486 | double J_c4 = 0.0;
libffcx_forms_9b64614a007c2a27dc174c07011f9d15d75b6f69.c:2491:10: error: redefinition of 'J_c5'
2491 | double J_c5 = 0.0;
libffcx_forms_9b64614a007c2a27dc174c07011f9d15d75b6f69.c:2488:10: note: previous definition is here
2488 | double J_c5 = 0.0;
libffcx_forms_9b64614a007c2a27dc174c07011f9d15d75b6f69.c:2495:10: error: redefinition of 'J_c0'
2495 | double J_c0 = 0.0;
libffcx_forms_9b64614a007c2a27dc174c07011f9d15d75b6f69.c:2484:10: note: previous definition is here
2484 | double J_c0 = 0.0;
libffcx_forms_9b64614a007c2a27dc174c07011f9d15d75b6f69.c:2496:10: error: redefinition of 'J_c1'
2496 | double J_c1 = 0.0;
libffcx_forms_9b64614a007c2a27dc174c07011f9d15d75b6f69.c:2483:10: note: previous definition is here
2483 | double J_c1 = 0.0;
libffcx_forms_9b64614a007c2a27dc174c07011f9d15d75b6f69.c:2497:10: error: redefinition of 'J_c2'
2497 | double J_c2 = 0.0;
libffcx_forms_9b64614a007c2a27dc174c07011f9d15d75b6f69.c:2485:10: note: previous definition is here
2485 | double J_c2 = 0.0;
6 errors generated.
File "/opt/anaconda3/envs/clean777/lib/python3.10/site-packages/setuptools/_distutils/spawn.py", line 87, in spawn
subprocess.check_call(cmd, env=_inject_macos_ver(env))
File "/opt/anaconda3/envs/clean777/lib/python3.10/subprocess.py", line 369, in check_call
raise CalledProcessError(retcode, cmd)
subprocess.CalledProcessError: Command '['/opt/anaconda3/envs/clean777/bin/arm64-apple-darwin20.0.0-clang', '-ftree-vectorize', '-fPIC', '-fstack-protector-strong', '-O2', '-pipe', '-isystem', '/opt/anaconda3/envs/clean777/include', '-D_FORTIFY_SOURCE=2', '-isystem', '/opt/anaconda3/envs/clean777/include', '-I/opt/anaconda3/envs/clean777/lib/python3.10/site-packages/ffcx/codegeneration', '-I/opt/anaconda3/envs/clean777/include/python3.10', '-c', 'libffcx_forms_9b64614a007c2a27dc174c07011f9d15d75b6f69.c', '-o', './libffcx_forms_9b64614a007c2a27dc174c07011f9d15d75b6f69.o', '-std=c17', '-O2', '-g0']' returned non-zero exit status 1.
The above exception was the direct cause of the following exception:
File "/opt/anaconda3/envs/clean777/lib/python3.10/site-packages/setuptools/_distutils/compilers/C/unix.py", line 221, in _compile
self.spawn(compiler_so + cc_args + [src, '-o', obj] + extra_postargs)
File "/opt/anaconda3/envs/clean777/lib/python3.10/site-packages/setuptools/_distutils/compilers/C/base.py", line 1158, in spawn
spawn(cmd, dry_run=self.dry_run, **kwargs)
File "/opt/anaconda3/envs/clean777/lib/python3.10/site-packages/setuptools/_distutils/spawn.py", line 93, in spawn
raise DistutilsExecError(
distutils.errors.DistutilsExecError: command '/opt/anaconda3/envs/clean777/bin/arm64-apple-darwin20.0.0-clang' failed with exit code 1
File "/opt/anaconda3/envs/clean777/lib/python3.10/site-packages/cffi/ffiplatform.py", line 48, in _build
dist.run_command('build_ext')
File "/opt/anaconda3/envs/clean777/lib/python3.10/site-packages/setuptools/dist.py", line 1104, in run_command
super().run_command(command)
File "/opt/anaconda3/envs/clean777/lib/python3.10/site-packages/setuptools/_distutils/dist.py", line 1021, in run_command
cmd_obj.run()
File "/opt/anaconda3/envs/clean777/lib/python3.10/site-packages/setuptools/command/build_ext.py", line 99, in run
_build_ext.run(self)
File "/opt/anaconda3/envs/clean777/lib/python3.10/site-packages/setuptools/_distutils/command/build_ext.py", line 368, in run
self.build_extensions()
File "/opt/anaconda3/envs/clean777/lib/python3.10/site-packages/setuptools/_distutils/command/build_ext.py", line 484, in build_extensions
self._build_extensions_serial()
File "/opt/anaconda3/envs/clean777/lib/python3.10/site-packages/setuptools/_distutils/command/build_ext.py", line 510, in _build_extensions_serial
self.build_extension(ext)
File "/opt/anaconda3/envs/clean777/lib/python3.10/site-packages/setuptools/command/build_ext.py", line 264, in build_extension
_build_ext.build_extension(self, ext)
File "/opt/anaconda3/envs/clean777/lib/python3.10/site-packages/setuptools/_distutils/command/build_ext.py", line 565, in build_extension
objects = self.compiler.compile(
File "/opt/anaconda3/envs/clean777/lib/python3.10/site-packages/setuptools/_distutils/compilers/C/base.py", line 655, in compile
self._compile(obj, src, ext, cc_args, extra_postargs, pp_opts)
File "/opt/anaconda3/envs/clean777/lib/python3.10/site-packages/setuptools/_distutils/compilers/C/unix.py", line 223, in _compile
raise CompileError(msg)
distutils.compilers.C.errors.CompileError: command '/opt/anaconda3/envs/clean777/bin/arm64-apple-darwin20.0.0-clang' failed with exit code 1
File "/Users/pierremariotti/Documents/PhD/FEniCSx/new_try2/root/ABC_FEniCSx_classical/mwe_FEniCSx.py", line 135, in <module>
File "/opt/anaconda3/envs/clean777/lib/python3.10/site-packages/dolfinx/fem/forms.py", line 337, in form
return _create_form(form)
File "/opt/anaconda3/envs/clean777/lib/python3.10/site-packages/dolfinx/fem/forms.py", line 331, in _create_form
return _form(form)
File "/opt/anaconda3/envs/clean777/lib/python3.10/site-packages/dolfinx/fem/forms.py", line 254, in _form
ufcx_form, module, code = jit.ffcx_jit(
File "/opt/anaconda3/envs/clean777/lib/python3.10/site-packages/dolfinx/jit.py", line 62, in mpi_jit
File "/opt/anaconda3/envs/clean777/lib/python3.10/site-packages/dolfinx/jit.py", line 212, in ffcx_jit
File "/opt/anaconda3/envs/clean777/lib/python3.10/site-packages/ffcx/codegeneration/jit.py", line 225, in compile_forms
raise e
File "/opt/anaconda3/envs/clean777/lib/python3.10/site-packages/ffcx/codegeneration/jit.py", line 205, in compile_forms
impl = _compile_objects(
File "/opt/anaconda3/envs/clean777/lib/python3.10/site-packages/ffcx/codegeneration/jit.py", line 380, in _compile_objects
ffibuilder.compile(tmpdir=cache_dir, verbose=True, debug=cffi_debug)
File "/opt/anaconda3/envs/clean777/lib/python3.10/site-packages/cffi/api.py", line 725, in compile
return recompile(self, module_name, source, tmpdir=tmpdir,
File "/opt/anaconda3/envs/clean777/lib/python3.10/site-packages/cffi/recompiler.py", line 1564, in recompile
outputfilename = ffiplatform.compile('.', ext,
File "/opt/anaconda3/envs/clean777/lib/python3.10/site-packages/cffi/ffiplatform.py", line 20, in compile
outputfilename = _build(tmpdir, ext, compiler_verbose, debug)
File "/opt/anaconda3/envs/clean777/lib/python3.10/site-packages/cffi/ffiplatform.py", line 54, in _build
raise VerificationError('%s: %s' % (e.__class__.__name__, e))
cffi.VerificationError: CompileError: command '/opt/anaconda3/envs/clean777/bin/arm64-apple-darwin20.0.0-clang' failed with exit code 1
The problem occurs when I have an coupled integral term that presents a spatial derivative of the test function.
The line a_10 = inner(p, u.dx(0)) * ds(10) leads to an error but the lines :
a_10 = inner(p, u) * ds(10)
a_10 = inner(p,dx(0), u) * ds(10)
doesn’t.
I know more or less why I have this problem, but my question is : Do you have any idea how I could implement this problematic term ?
Thank you,
Pierre.
