Discontinuity at interface using mixed domains
Hi all,
Exactly like in this topic I am trying to impose a discontinuity at an interface between two subdomains. This time having two subdomains with only CG elements and coupling them with a dS term.
@dokken published this gist that I am trying to adapt in order to have:
\frac{u(-)}{K(-)} = \frac{u(+)}{K(+)}
\nabla u(-) - \nabla u(+) = 0
However I am struggling to adapt the interface terms to achieve the desired result.
This is the DG formulation we had earlier:
# Interface
F += - dot(avg(grad(v)), n('-'))*(u('-')*(K1/K2-1))*dS(2)
F += alpha/avg(h)*dot(jump(v,n),n('-'))*(u('-')*(K1/K2-1))*dS(2)
# symmetry
F += - dot(avg(grad(v)), jump(u, n))*dS(2)
# coercivity
F += + alpha/avg(h)*dot(jump(v, n), jump(u, n))*dS(2)
I think this is the variational form that you would like:
# SPDX-License-Identifier: MIT
import dolfinx.fem.petsc
class NewtonSolver:
    max_iterations: int
    bcs: list[dolfinx.fem.DirichletBC]
    A: PETSc.Mat
    b: PETSc.Vec
    J: dolfinx.fem.Form
    b: dolfinx.fem.Form
    dx: PETSc.Vec
    def __init__(
        self,
        F: list[dolfinx.fem.form],
        J: list[list[dolfinx.fem.form]],
        w: list[dolfinx.fem.Function],
        bcs: list[dolfinx.fem.DirichletBC] | None = None,
        max_iterations: int = 5,
        petsc_options: dict[str, str | float | int | None] = None,
        problem_prefix="newton",
        self.max_iterations = max_iterations
        self.bcs = [] if bcs is None else bcs
        self.b = dolfinx.fem.petsc.create_vector_block(F)
        self.F = F
        self.J = J
        self.A = dolfinx.fem.petsc.create_matrix_block(J)
        self.dx = self.A.createVecLeft()
        self.w = w
        self.x = dolfinx.fem.petsc.create_vector_block(F)
        # Set PETSc options
        opts = PETSc.Options()
        if petsc_options is not None:
            for k, v in petsc_options.items():
                opts[k] = v
        # Define KSP solver
        self._solver = PETSc.KSP().create(self.b.getComm().tompi4py())
        self._solver.setOperators(self.A)
        self._solver.setFromOptions()
        # Set matrix and vector PETSc options
        self.A.setFromOptions()
        self.b.setFromOptions()
    def solve(self, tol=1e-6, beta=1.0):
        i = 0
        while i < self.max_iterations:
            dolfinx.cpp.la.petsc.scatter_local_vectors(
                self.x,
                [si.x.petsc_vec.array_r for si in self.w],
                        si.function_space.dofmap.index_map,
                        si.function_space.dofmap.index_map_bs,
                    for si in self.w
            self.x.ghostUpdate(
                addv=PETSc.InsertMode.INSERT, mode=PETSc.ScatterMode.FORWARD
            # Assemble F(u_{i-1}) - J(u_D - u_{i-1}) and set du|_bc= u_D - u_{i-1}
            with self.b.localForm() as b_local:
                b_local.set(0.0)
            dolfinx.fem.petsc.assemble_vector_block(
                self.b, self.F, self.J, bcs=self.bcs, x0=self.x, scale=-1.0
            self.b.ghostUpdate(
                PETSc.InsertMode.INSERT_VALUES, PETSc.ScatterMode.FORWARD
            # Assemble Jacobian
            self.A.zeroEntries()
            dolfinx.fem.petsc.assemble_matrix_block(self.A, self.J, bcs=self.bcs)
            self.A.assemble()
            self._solver.solve(self.b, self.dx)
            # self._solver.view()
            assert (
                self._solver.getConvergedReason() > 0
            ), "Linear solver did not converge"
            offset_start = 0
            for s in self.w:
                num_sub_dofs = (
                    s.function_space.dofmap.index_map.size_local
                    * s.function_space.dofmap.index_map_bs
                s.x.petsc_vec.array_w[:num_sub_dofs] -= (
                    beta * self.dx.array_r[offset_start : offset_start + num_sub_dofs]
                s.x.petsc_vec.ghostUpdate(
                offset_start += num_sub_dofs
            # Compute norm of update
            correction_norm = self.dx.norm(0)
            print(f"Iteration {i}: Correction norm {correction_norm}")
            if correction_norm < tol:
                break
            i += 1
    def __del__(self):
        self.A.destroy()
        self.b.destroy()
        self.dx.destroy()
        self._solver.destroy()
        self.x.destroy()
def transfer_meshtags_to_submesh(
    mesh, entity_tag, submesh, sub_vertex_to_parent, sub_cell_to_parent
    Transfer a meshtag from a parent mesh to a sub-mesh.
    tdim = mesh.topology.dim
    cell_imap = mesh.topology.index_map(tdim)
    num_cells = cell_imap.size_local + cell_imap.num_ghosts
    mesh_to_submesh = np.full(num_cells, -1)
    mesh_to_submesh[sub_cell_to_parent] = np.arange(
        len(sub_cell_to_parent), dtype=np.int32
    sub_vertex_to_parent = np.asarray(sub_vertex_to_parent)
    submesh.topology.create_connectivity(entity_tag.dim, 0)
    num_child_entities = (
        submesh.topology.index_map(entity_tag.dim).size_local
        + submesh.topology.index_map(entity_tag.dim).num_ghosts
    submesh.topology.create_connectivity(submesh.topology.dim, entity_tag.dim)
    c_c_to_e = submesh.topology.connectivity(submesh.topology.dim, entity_tag.dim)
    c_e_to_v = submesh.topology.connectivity(entity_tag.dim, 0)
    child_markers = np.full(num_child_entities, 0, dtype=np.int32)
    mesh.topology.create_connectivity(entity_tag.dim, mesh.topology.dim)
    p_f_to_v = mesh.topology.connectivity(entity_tag.dim, 0)
    p_f_to_c = mesh.topology.connectivity(entity_tag.dim, mesh.topology.dim)
    sub_to_parent_entity_map = np.full(num_child_entities, -1, dtype=np.int32)
    for facet, value in zip(entity_tag.indices, entity_tag.values):
        facet_found = False
        for cell in p_f_to_c.links(facet):
            if facet_found:
                break
            if (child_cell := mesh_to_submesh[cell]) != -1:
                for child_facet in c_c_to_e.links(child_cell):
                    child_vertices = c_e_to_v.links(child_facet)
                    child_vertices_as_parent = sub_vertex_to_parent[child_vertices]
                    is_facet = np.isin(
                        child_vertices_as_parent, p_f_to_v.links(facet)
                    ).all()
                    if is_facet:
                        child_markers[child_facet] = value
                        facet_found = True
                        sub_to_parent_entity_map[child_facet] = facet
    tags = dolfinx.mesh.meshtags(
        submesh,
        entity_tag.dim,
        np.arange(num_child_entities, dtype=np.int32),
        child_markers,
    tags.name = entity_tag.name
    return tags, sub_to_parent_entity_map
def bottom_boundary(x):
    return np.isclose(x[1], 0.0)
def top_boundary(x):
    return np.isclose(x[1], 1.0)
def half(x):
    return x[1] <= 0.5 + 1e-14
mesh = dolfinx.mesh.create_unit_square(MPI.COMM_WORLD, 10, 10, dolfinx.mesh.CellType.triangle)
# Split domain in half and set an interface tag of 5
gdim = mesh.geometry.dim
fdim = tdim - 1
top_facets = dolfinx.mesh.locate_entities_boundary(mesh, fdim, top_boundary)
bottom_facets = dolfinx.mesh.locate_entities_boundary(mesh, fdim, bottom_boundary)
num_facets_local = (
    mesh.topology.index_map(fdim).size_local + mesh.topology.index_map(fdim).num_ghosts
facets = np.arange(num_facets_local, dtype=np.int32)
values = np.full_like(facets, 0, dtype=np.int32)
values[top_facets] = 1
values[bottom_facets] = 2
bottom_cells = dolfinx.mesh.locate_entities(mesh, tdim, half)
num_cells_local = (
    mesh.topology.index_map(tdim).size_local + mesh.topology.index_map(tdim).num_ghosts
cells = np.full(num_cells_local, 4, dtype=np.int32)
cells[bottom_cells] = 3
ct = dolfinx.mesh.meshtags(
    mesh, tdim, np.arange(num_cells_local, dtype=np.int32), cells
all_b_facets = dolfinx.mesh.compute_incident_entities(
    mesh.topology, ct.find(3), tdim, fdim
all_t_facets = dolfinx.mesh.compute_incident_entities(
    mesh.topology, ct.find(4), tdim, fdim
interface = np.intersect1d(all_b_facets, all_t_facets)
values[interface] = 5
mt = dolfinx.mesh.meshtags(mesh, mesh.topology.dim - 1, facets, values)
submesh_b, submesh_b_to_mesh, b_v_map = dolfinx.mesh.create_submesh(
    mesh, tdim, ct.find(3)
)[0:3]
submesh_t, submesh_t_to_mesh, t_v_map = dolfinx.mesh.create_submesh(
    mesh, tdim, ct.find(4)
)[0:3]
parent_to_sub_b = np.full(num_facets_local, -1, dtype=np.int32)
parent_to_sub_b[submesh_b_to_mesh] = np.arange(len(submesh_b_to_mesh), dtype=np.int32)
parent_to_sub_t = np.full(num_facets_local, -1, dtype=np.int32)
parent_to_sub_t[submesh_t_to_mesh] = np.arange(len(submesh_t_to_mesh), dtype=np.int32)
# We need to modify the cell maps, as for `dS` integrals of interfaces between submeshes, there is no entity to map to.
# We use the entity on the same side to fix this (as all restrictions are one-sided)
# Transfer meshtags to submesh
ft_b, b_facet_to_parent = transfer_meshtags_to_submesh(
    mesh, mt, submesh_b, b_v_map, submesh_b_to_mesh
ft_t, t_facet_to_parent = transfer_meshtags_to_submesh(
    mesh, mt, submesh_t, t_v_map, submesh_t_to_mesh
t_parent_to_facet = np.full(num_facets_local, -1)
t_parent_to_facet[t_facet_to_parent] = np.arange(len(t_facet_to_parent), dtype=np.int32)
# Hack, as we use one-sided restrictions, pad dS integral with the same entity from the same cell on both sides
f_to_c = mesh.topology.connectivity(fdim, tdim)
for facet in mt.find(5):
    cells = f_to_c.links(facet)
    assert len(cells) == 2
    b_map = parent_to_sub_b[cells]
    t_map = parent_to_sub_t[cells]
    parent_to_sub_b[cells] = max(b_map)
    parent_to_sub_t[cells] = max(t_map)
entity_maps = {submesh_b: parent_to_sub_b, submesh_t: parent_to_sub_t}
#entity_maps = {submesh_b._cpp_object: parent_to_sub_b, submesh_t._cpp_object: parent_to_sub_t}
def define_interior_eq(mesh,degree,  submesh, submesh_to_mesh, value):
    # Compute map from parent entity to submesh cell
    codim = mesh.topology.dim - submesh.topology.dim
    ptdim = mesh.topology.dim - codim
    num_entities = (
        mesh.topology.index_map(ptdim).size_local
        + mesh.topology.index_map(ptdim).num_ghosts
    mesh_to_submesh = np.full(num_entities, -1)
    mesh_to_submesh[submesh_to_mesh] = np.arange(len(submesh_to_mesh), dtype=np.int32)
    V = dolfinx.fem.functionspace(submesh, ("Lagrange", degree))
    u = dolfinx.fem.Function(V)
    ct_r = dolfinx.mesh.meshtags(mesh, mesh.topology.dim, submesh_to_mesh, np.full_like(submesh_to_mesh, 1, dtype=np.int32))
    val = dolfinx.fem.Constant(submesh, value)
    dx_r = ufl.Measure("dx", domain=mesh, subdomain_data=ct_r, subdomain_id=1)
    F = ufl.inner(ufl.grad(u), ufl.grad(v)) * dx_r - val * v * dx_r
    return u, F, mesh_to_submesh
u_0, F_00, m_to_b = define_interior_eq(mesh, 2, submesh_b, submesh_b_to_mesh, 0.0)
u_1, F_11, m_to_t = define_interior_eq(mesh, 1, submesh_t, submesh_t_to_mesh, 0.0)
u_0.name = "u_b"
u_1.name = "u_t"
# Add coupling term to the interface
# Get interface markers on submesh b
dInterface = ufl.Measure("dS", domain=mesh, subdomain_data=mt, subdomain_id=5)
b_res = "+"
t_res = "-"
v_b = ufl.TestFunction(u_0.function_space)(b_res)
v_t = ufl.TestFunction(u_1.function_space)(t_res)
u_b = u_0(b_res)
u_t = u_1(t_res)
def mixed_term(u, v, n):
    return ufl.dot(ufl.grad(u), n) * v
W_0 = dolfinx.fem.functionspace(submesh_b, ("DG", 0))
K_0 = dolfinx.fem.Function(W_0)
K_0.x.array[:] = 1
W_1 = dolfinx.fem.functionspace(submesh_t, ("DG", 0))
K_1 = dolfinx.fem.Function(W_1)
K_1.x.array[:] = 1.5
n = ufl.FacetNormal(mesh)
n_b = n(b_res)
n_t = n(t_res)
K_b = K_0(b_res)
K_t = K_1(t_res)
cr = ufl.Circumradius(mesh)
h_b = 2 * cr(b_res)
h_t = 2 * cr(t_res)
gamma = 50.0
F_0 = (
    -0.5 * mixed_term((u_b + u_t), v_b, n_b) * dInterface
    - 0.5 * mixed_term(v_b, (u_b/K_b - u_t/K_t), n_b) * dInterface
F_1 = (
    +0.5 * mixed_term((u_b + u_t), v_t, n_b) * dInterface
    - 0.5 * mixed_term(v_t, (u_b/K_b - u_t/K_t), n_b) * dInterface
F_0 += 2 * gamma / (h_b + h_t) * (u_b/K_b - u_t/K_t) * v_b * dInterface
F_1 += -2 * gamma / (h_b + h_t) * (u_b/K_b - u_t/K_t) * v_t * dInterface
F_0 += F_00
F_1 += F_11
jac00 = ufl.derivative(F_0, u_0)
jac01 = ufl.derivative(F_0, u_1)
jac10 = ufl.derivative(F_1, u_0)
jac11 = ufl.derivative(F_1, u_1)
J00 = dolfinx.fem.form(jac00, entity_maps=entity_maps)
J01 = dolfinx.fem.form(jac01, entity_maps=entity_maps)
J10 = dolfinx.fem.form(jac10, entity_maps=entity_maps)
J11 = dolfinx.fem.form(jac11, entity_maps=entity_maps)
J = [[J00, J01], [J10, J11]]
F = [
    dolfinx.fem.form(F_0, entity_maps=entity_maps),
    dolfinx.fem.form(F_1, entity_maps=entity_maps),
b_bc = dolfinx.fem.Function(u_0.function_space)
b_bc.x.array[:] = 0.2
submesh_b.topology.create_connectivity(
    submesh_b.topology.dim - 1, submesh_b.topology.dim
bc_b = dolfinx.fem.dirichletbc(
    b_bc, dolfinx.fem.locate_dofs_topological(u_0.function_space, fdim, ft_b.find(2))
t_bc = dolfinx.fem.Function(u_1.function_space)
t_bc.x.array[:] = 0.05
submesh_t.topology.create_connectivity(
    submesh_t.topology.dim - 1, submesh_t.topology.dim
bc_t = dolfinx.fem.dirichletbc(
    t_bc, dolfinx.fem.locate_dofs_topological(u_1.function_space, fdim, ft_t.find(1))
bcs = [bc_b, bc_t]
solver = NewtonSolver(
    F,
    J,
    [u_0, u_1],
    bcs=bcs,
    max_iterations=2,
    petsc_options={
        "ksp_type": "preonly",
        "pc_type": "lu",
solver.solve(1e-5)
bp = dolfinx.io.VTXWriter(mesh.comm, "u_b.bp", [u_0], engine="BP4")
bp.write(0)
bp.close()
bp = dolfinx.io.VTXWriter(mesh.comm, "u_t.bp", [u_1], engine="BP4")
bp.write(0)
bp.close()
Yes it works thank you so much!
Just a typo
F_0 = (
    - 0.5 * mixed_term(v_b, (u_b / K_b - u_t / K_t), n_b) * dInterface
F_1 = (
    - 0.5 * mixed_term(v_t, (u_b / K_b - u_t / K_t), n_b) * dInterface
F_0 += 2 * gamma / (h_b + h_t) * (u_b / K_b - u_t / K_t) * v_b * dInterface
F_1 += -2 * gamma / (h_b + h_t) * (u_b / K_b - u_t / K_t) * v_t * dInterface
Right, I was a bit too fast :slight_smile: Corrected in post now:)
It would be nice to have a demo somewhere to be able to arrive to this by hand
For anyone interested this is the produced field
In the referenced gist, I’ve written out all the different ways of writing up the DG coupling for general DG, which kind of explains the evolution of it.
I’ll talk to @jpdean about making an official demo out of this (or the linear version of it) when I see him early July:)
Have you written a preprint on the variation formulation in this gist or is the prescription of discontinuity by that method supposed to be obvious?
It is a «standard» DG coupling scheme of a Poisson equation (see the dg.py file for a similar DG formulation).
Thanks for the gist - symmetric interior penalty DG (SIPDG) extra DoFs were becoming a bottleneck for a problem I am solving. Reviewing the gist, I can see the similarities with SIPDG. Do you think the penalty parameter gamma would be affected by mesh quality far away from the interface? I’m trying to ascertain whether I can use bounds on the penalty parameters already proved by Epshteyn and Riviere. Regardless, I’ll most likely get away with using a “large-enough” penalty term by trial and error if the bounds for this DG are not contained in the bounds by Epshteyn and Riviere.
I would be suprised if far-away bad cells would affect the DG coupling at the interface itself.
However, i am aware of cases where boundary effects reduce global convergence (in fluid flow), so there might be similarities.
I modified the gist by:
  1. importing gmsh
  2. defining a function that creates a mesh and saves to file “mesh.msh”
  3. loading the mesh from file using dolfinx.io.gmshio
When I run the problem, clear the cache rm -r ~/.cache/fenics and rerun the problem, I get segmentation error.
=   BAD TERMINATION OF ONE OF YOUR APPLICATION PROCESSES
=   PID 142239 RUNNING AT lmolel-thinkpad-t15-gen-2i
=   EXIT CODE: 139
=   CLEANING UP REMAINING PROCESSES
=   YOU CAN IGNORE THE BELOW CLEANUP MESSAGES
YOUR APPLICATION TERMINATED WITH THE EXIT STRING: Segmentation fault (signal 11)
This typically refers to a problem with your application.
Please see the FAQ page for debugging suggestions
Is this supposed to happen, and how do I go about debugging it?
Here’s the function creating mesh:
def create_mesh():
    points_left = [
        (0, 0, 0),
        (0, 0.5, 0),
        (0, 1, 0),
    points_right = [
        (1, 0, 0),
        (1, 0.5, 0),
        (1, 1, 0)
    gmsh.model.add('2d')
    left_points = [gmsh.model.occ.addPoint(*p) for p in points_left]
    right_points = [gmsh.model.occ.addPoint(*p) for p in points_right]
    lines_left = [gmsh.model.occ.addLine(left_points[i], left_points[i+1]) for i in range(2)]
    lines_right = [gmsh.model.occ.addLine(right_points[i], right_points[i+1]) for i in range(2)]
    line_top = gmsh.model.occ.addLine(left_points[-1], right_points[-1])
    line_middle = gmsh.model.occ.addLine(left_points[1], right_points[1])
    line_bottom = gmsh.model.occ.addLine(left_points[0], right_points[0])
    loop_top = gmsh.model.occ.addCurveLoop([lines_left[-1], line_middle, lines_right[-1], line_top])
    top_surf = gmsh.model.occ.addPlaneSurface([loop_top])
    loop_bottom = gmsh.model.occ.addCurveLoop([lines_left[0], line_bottom, lines_right[0], line_middle])
    bottom_surf = gmsh.model.occ.addPlaneSurface([loop_bottom])
    gmsh.model.occ.synchronize()
    gmsh.model.addPhysicalGroup(1, [line_top], 1, "top")
    gmsh.model.addPhysicalGroup(1, [line_bottom], 2, "bottom")
    gmsh.model.addPhysicalGroup(1, [line_middle], 5, "interface")
    gmsh.model.addPhysicalGroup(2, [bottom_surf], 3, "bottom")
    gmsh.model.addPhysicalGroup(2, [top_surf], 4, "top")
    gmsh.model.mesh.generate(2)
    gmsh.write("mesh.msh")
    gmsh.finalize()
In the gist, I commented out lines 196-230 and inserted the following snippet at line 231
# load mesh from file
comm = MPI.COMM_WORLD
partitioner = dolfinx.mesh.create_cell_partitioner(dolfinx.mesh.GhostMode.shared_facet)
mesh, ct, mt = dolfinx.io.gmshio.read_from_msh("mesh.msh", comm, partitioner=partitioner)
fdim = tdim - 1
I encounter the issue in conda for fenics-dolfinx==0.8.0.0 and not for local build of development fenics-dolfinx==0.9.0.0.
Please note that I have addresses several issues Since the 0.8 release when it comes to submeshes,
