ModuleNotFoundError when using Dolfinx_MPC Docker Image
I am trying to use DOLFINx_MPC via Docker image, running
docker run -ti -v $(pwd):/root/shared -w /root/shared ghcr.io/jorgensd/dolfinx_mpc:v0.9.0
as suggested in the docs
My script starts with some imports
from dolfinx import fem, io
import dolfinx.fem.petsc
from dolfinx.io.gmshio import model_to_mesh
import dolfinx_mpc.utils
from dolfinx_mpc import LinearProblem
and the next from last triggers the error
  File "/root/shared/periodic_elasticity.py", line 97, in <module>
  File "/usr/local/dolfinx-real/lib/python3.12/dist-packages/dolfinx_mpc/utils/__init__.py", line 20, in <module>
    from .test import (
  File "/usr/local/dolfinx-real/lib/python3.12/dist-packages/dolfinx_mpc/utils/test.py", line 24, in <module>
    import pytest
ModuleNotFoundError: No module named 'pytest'
I installed pytest (and next, scipy) to get going, and it worked but I am wondering if I am doing anything wrong, I understand very little Docker, thanks
I’d watch a quick docker tutorial on youtube. In 30 minutes you’ll understand most of it.
Essentially, the docker image is a stand-alone linux machine with pre-specified installs. The image ghcr.io/jorgensd/dolfinx_mpc:v0.9.0 apparently does not have pytest installed.
You can manually install it when you have the container running, but that is not very useful; each time you create a new container it spins up a blank version of ghcr.io/jorgensd/dolfinx_mpc:v0.9.0 (that is precisely the point).
Luckily, though. It is incredibly easy to create your own container images building on top of others. In an empty folder, you’d create a Dockerfile looking something like:
FROM ghcr.io/jorgensd/dolfinx_mpc:v0.10.0
# Pip installs side-packages
RUN python3 -m pip install pytest
RUN python3 -m pip install scipy
# Working directory
WORKDIR /app
# Creates a non-root user with an explicit UID and adds permission to access the /app folder
RUN chown -R ubuntu /app
USER ubuntu
Or maybe with some additional supporting packages:
RUN python3 -m pip install pytest-cov
# Pip installs dolfinx packages
RUN python3 -m pip install adios4dolfinx
RUN python3 -m pip install scifem --no-build-isolation
RUN python3 -m pip install pyvista4dolfinx
# Default visualization variables
ENV XDG_RUNTIME_DIR=/tmp
ENV PYVISTA_OFF_SCREEN=true
# Working directory
WORKDIR /app
USER ubuntu
Then, with terminal command while in that empty folder you’d run docker build . -t <my_image_name>.
Then you can run with docker run -ti -v $(pwd):/app <my_image_name>
