Mpi_comm not working for mesh in dolfin 2019.1
I have a fenics installation version 2019.1 in a remote machine.
I have a parallelized code which I have ran before in 2017.1 version.
comm = MPI.COMM_WORLD
mesh = Mesh(mpi_comm(),mpath)
mpath is the path to .xml meshes
I keep on ending up with the error,
NameError: name ‘mpi_comm’ is not defined
Is this a known error ? Am i doing something wrong ?
There was a change in the API. The following runs in 2019.1:
mesh = UnitIntervalMesh(MPI.comm_world,10)
I have tried the change as you suggested, but I feel that the MPI wrapper from Fenics and MPI from mpi4py are conflicting. I made a python file just to see at what point it fails. After creating the mesh it fails again at creating function space.
from mpi4py import MPI as mpi
comm = mpi.COMM_WORLD
ip = comm.Get_rank()
print("Hello I am process ",ip)
V = VectorFunctionSpace(mesh, “CG”, 1)
Hello I am process 0
Hello I am process 1
File “trial_elasticity.py”, line 10, in
File “/scinet/niagara/software/2018a/opt/intel-2018.2-intelmpi-2018.2/fenics/2017.2.0/lib/python3.6/site-packages/dolfin/function/functionspace.py”, line 222, in VectorFunctionSpace
return FunctionSpace(mesh, element, constrained_domain=constrained_domain)
File “/scinet/niagara/software/2018a/opt/intel-2018.2-intelmpi-2018.2/fenics/2017.2.0/lib/python3.6/site-packages/dolfin/function/functionspace.py”, line 31, in init
self._init_from_ufl(*args, **kwargs)
File “/scinet/niagara/software/2018a/opt/intel-2018.2-intelmpi-2018.2/fenics/2017.2.0/lib/python3.6/site-packages/dolfin/function/functionspace.py”, line 43, in _init_from_ufl
mpi_comm=mesh.mpi_comm())
File “/scinet/niagara/software/2018a/opt/intel-2018.2-intelmpi-2018.2/fenics/2017.2.0/lib/python3.6/site-packages/dolfin/jit/jit.py”, line 82, in mpi_jit
raise RuntimeError(error_msg)
RuntimeError: [Errno 30] Read-only file system: ‘/home/a/asarkar/sudhipv/.cache/dijitso’
Could you look in to this ?
It works perfectly fine for me:
>>> msh = UnitIntervalMesh(mpi.COMM_WORLD,10)
>>> VectorFunctionSpace(msh,'CG',1)
FunctionSpace(Mesh(VectorElement(FiniteElement('Lagrange', interval, 1), dim=1), 0), VectorElement(FiniteElement('Lagrange', interval, 1), dim=1))
Although I am using dolfin-2019.1.0 as opposed to 2017.2 and intel_mpi-2018.
Could try with printing the rank too ??
To get the rank you would need to call mpi from mpi4py right ?
But I am confused as to which mpi to use for the Mesh function call. mpi4py imported mpi or the MPI wrapper from dolfin ?
In my case I almost always use the MPI wrapper in dolfin and haven’t had to face any issues. You can use the inbuilt function has_mpi4py() to check if dolfin was correctly configured with mpi4py in case if you built it from source. For most standard installations this should not be an issue.
