Parallelisation of topology optimisation
Good morning,
I have a few questions about parallel programming in FEniCSx related to my need of topology optimisation. I got more familiar with MPI Communication with this tutorial, but these details are not clear:
1 - mesh.topology.create_connectivity: do you need to gather the mesh to one process in order for it to work?
2 - these krylov solver options do not work in parallel:
OPTIONS["ksp_type"]="cg"
OPTIONS["pc_type"]="ilu"
what is a suitable replacement in parallel, especially for linear elasticity?
3 - assemble_matrix : is there any operation to do thereafter for parallel process like ghost values updates?
4 - do you need to update ghost values when setting the values of DG0 functions?
I thank you a lot for all these answers, and my code, if needed, is given below :
#IMPORTS
from dolfinx import fem, cpp, io, mesh
#PARAMETERS
NITER_TOTAL=3
PENAL=38
WEIGHT=1
LAMBDA=0.6
MU=0.4
L, W, H=0.303, 0.19, 0.064
EMP=0.06
AXE=0.025
NX, NY, NZ = 60, 38, 12
#MESH CREATION
points=[np.array([0, 0, 0]), np.array([L, W, H])]
domain=mesh.create_box(
    MPI.COMM_WORLD,
    points,
    [NX,NY,NZ],
    cell_type=cpp.mesh.CellType.hexahedron,
    ghost_mode=mesh.GhostMode.shared_facet
dim=domain.topology.dim
#BOUNDARY MARKERS
def axes(x):
    return np.logical_and(
               np.logical_or(np.sqrt( (x[0]-EMP)**2 + (x[2]-H/2)**2 ) <=AXE,
                             np.sqrt( (x[0]-L+EMP)**2 + (x[2]-H/2)**2 ) <=AXE),
               np.logical_or(np.isclose(x[1], 0, atol=1e-6),
                             np.isclose(x[1], W, atol=1e-6))
def bottom(x):
    return np.isclose(x[2], 0, atol=1e-6)
bottom_facets=mesh.locate_entities(domain, dim-1, bottom)
axes_facets=mesh.locate_entities(domain, dim-1, axes)
facet_indices=np.array(np.hstack([bottom_facets, axes_facets]), dtype=np.int32)
facet_markers=[np.full(len(bottom_facets), 1, dtype=np.int32),
               np.full(len(axes_facets), 2, dtype=np.int32)]
facet_markers=np.hstack(facet_markers)
sorted_facets=np.argsort(facet_indices)
facet_tag=mesh.meshtags(
    domain,
    dim-1,
    facet_indices[sorted_facets],
    facet_markers[sorted_facets]
domain.topology.create_connectivity(dim-1, dim)#not sure about this in parallel
#LOADS AND BC
U=fem.VectorFunctionSpace(domain, ("CG", 1))
u=fem.Function(U, name="Déplacement")
bcdofs=fem.locate_dofs_geometrical(U, axes)
u_0=np.array((0,)*dim, dtype=PETSc.ScalarType)
bc=fem.dirichletbc(u_0, bcdofs, U)
ds= ufl.Measure("ds", domain=domain, subdomain_data=facet_tag)
bottom_surf=MPI.COMM_WORLD.allreduce(
                fem.assemble_scalar(fem.form(fem.Constant(domain, 1.)*ds(1))),
                op=MPI.SUM
def eps(v):
    return ufl.sym(ufl.grad(v))
def sigma(v):
    return (LAMBDA*ufl.nabla_div(v)*ufl.Identity(dim)+2*MU*eps(v))
def dE(u, v):
    return ufl.inner(sigma(u), eps(v))/2
#DENSITY SET UP
T=fem.FunctionSpace(domain, ("DG", 0))
density_old=fem.Function(T)
density=fem.Function(T, name="Density")
def homogenous(x):
    return np.full(len(x[0]), 0.3)
density.interpolate(homogenous)
VOL=MPI.COMM_WORLD.allreduce(
        fem.assemble_scalar(fem.form(fem.Constant(domain, 1.)*ufl.dx)),
        op=MPI.SUM
frac_init=MPI.COMM_WORLD.allreduce(
              fem.assemble_scalar(fem.form(density*ufl.dx))/VOL,
              op=MPI.SUM
#VARIATIONAL PROBLEM
u_=ufl.TestFunction(U)
du=ufl.TrialFunction(U)
a=ufl.inner(density**PENAL*sigma(u_), eps(du))*ufl.dx
b=ufl.dot((WEIGHT/bottom_surf)*ufl.FacetNormal(domain), u_)*ds(1)
solver=PETSc.KSP().create(MPI.COMM_WORLD)
OPTIONS=PETSc.Options()
#DOES NOT WORK IN PARALLEL
#OPTIONS["ksp_type"]="cg"
#OPTIONS["ksp_atol"]=1.0e-10
#OPTIONS["pc_type"]="ilu"
solver.setFromOptions()
compliance_history=[]
compliance_old=1e30
B=fem.petsc.assemble_vector(fem.form(b))
fem.petsc.apply_lifting(B, [fem.form(a)], bcs=[[bc]])
B.ghostUpdate(addv=PETSc.InsertMode.ADD, mode=PETSc.ScatterMode.REVERSE)
fem.petsc.set_bc(B, [bc])
#OPTIMISATION LOOP
for i in range(NITER_TOTAL):
    #SOLVE
    A=fem.petsc.assemble_matrix(fem.form(a), bcs=[bc])
    solver.setOperators(A)
    iter_solve=solver.solve(B, u.vector)
    u.x.scatter_forward()
    #OPTIMISATION CRITERIA
    sensitivity=-PENAL*density**(PENAL-1)*dE(u,u)
    #LAGRANGE MULTIPLIER FINDER (DICHOTOMY)
    lmin, lmax=0, 1e8
    counter=0
    frac=0
    while np.abs(frac-frac_init)>1e-4:
        lmoy=(lmin+lmax)/2
        densitynew=fem.Function(T)
        densitynew.interpolate(fem.Expression((-sensitivity/lmoy)**0.5,
                                              T.element.interpolation_points))
        denv=density.vector.getArray()
        denvnew=densitynew.vector.getArray()
        criterion=np.maximum(0.001,
                             np.maximum(denv-np.full(len(denv), 0.2),
                                        np.minimum(1,
                                                   np.minimum(
                                                     denv+np.full(len(denv), 0.2),
                                                     denv*denvnew
        densitynew.vector.setArray(criterion)
        densitynew.vector.ghostUpdate(addv=PETSc.InsertMode.ADD,
        frac=MPI.COMM_WORLD.allreduce(
                 fem.assemble_scalar(fem.form(densitynew*ufl.dx))/VOL,
                 op=MPI.SUM
        if  frac-frac_init>0:
            lmin=lmoy
            lmax=lmoy
        counter+=1
    density.vector.setArray(densitynew.vector.getArray())
    density.vector.ghostUpdate(addv=PETSc.InsertMode.ADD,
    compliance=MPI.COMM_WORLD.allreduce(
                   fem.assemble_scalar(fem.form(ufl.action(b,u))),
                   op=MPI.SUM
    compliance_history.append(compliance)
    print("\n ***** Step {}: compliance=".format(i), compliance,
          " in : ", counter, "iterations",
          ", process #", domain.comm.rank, " ***** ")
print("ALL CLEAR PROCESS #", MPI.COMM_WORLD.rank)
No, the mesh is not gathered on a single process. It uses MPI neighbourhood communicators to communicate index numbers (local or ghost entities), see:https://github.com/FEniCS/dolfinx/blob/e85cf6d31a185d889f2bd480562c8b2d0d7e819a/cpp/dolfinx/mesh/topologycomputation.cpp#L168-L170
For linear elasticity I would suggest using GAMG, see: GitHub - FEniCS/performance-test: Mini App for FEniCSx performance testing
This operation does the ghost updates.
You should do so, if you use a DG formulation, where you might want information from a ghost cell. Rule of thumb is that you should use scatter_forward whenever you do an operation on a subset of cells.
Thanks a lot! Much appreciated :clap:
