MPI in fenics 2019.1.0 docker container
Hey guys,
I was testing a dolfin script for MPI and sadly it did not work the way I expected it to. Any help would be appreciated!
A minimal example script named mpi_test.py
mpi_rank = MPI.rank(MPI.comm_world)
mpi_size = MPI.size(MPI.comm_world)
print("rank / size: ", mpi_rank, "/", mpi_size)
Running mpirun -n 4 python3 mpi_test.py in Fenics 2018.1.0 container gives the following output
rank / size:  2 / 4
rank / size:  1 / 4
rank / size:  0 / 4
rank / size:  3 / 4
but the same script in the Fenics 2019.1.0 container gives
rank / size:  0 / 1
rank / size:  0 / 1
rank / size:  0 / 1
rank / size:  0 / 1
Has anything changed in the newer container? I couldnot find anything in the Changelog.
I cannot reproduce this behaviour.
Hello Jack,
Thanks a lot for your reply! I think it was an issue with the build. I used a fenics 2019.1.0 docker image with SHA256 : f99661bca19762194d64c9fdf7ba341490bed9c6eb508c5ea37fb25febb5378d .
I pulled a newer image and then it worked as expected!
(Should’ve updated it here! My bad!)
Cheers.
