HI!
I have been messing around with this page Multiphysics: Solving PDEs on subdomains — FEniCS Workshop
And when I copied and pasted the second part where it graphs the boundaries, I do not get the same graph as yours. wondering if it has to do with my mac book?
mesh = dolfinx.mesh.create_unit_square(MPI.COMM_WORLD, 40, 40)
def Omega1(x, tol=1e-14):
return x[0] <= 0.7 + tol
def Omega0(x, tol=1e-14):
return 0.7-tol <= x[0]
tdim = mesh.topology.dim
cell_map = mesh.topology.index_map(tdim)
num_cells_local = cell_map.size_local + cell_map.num_ghosts
marker = np.empty(num_cells_local, dtype=np.int32)
heat_marker = 1
stokes_marker = 3
marker[dolfinx.mesh.locate_entities(mesh, tdim, Omega0)] = heat_marker
marker[dolfinx.mesh.locate_entities(mesh, tdim, Omega1)] = stokes_marker
cell_tags = dolfinx.mesh.meshtags(mesh, mesh.topology.dim,
np.arange(num_cells_local, dtype=np.int32),
marker)
import sys, os
import pyvista
if sys.platform == "linux" and (os.getenv("CI") or pyvista.OFF_SCREEN):
pyvista.start_xvfb(0.05)
def plot_mesh(mesh: dolfinx.mesh.Mesh, tags: dolfinx.mesh.MeshTags=None):
plotter = pyvista.Plotter()
mesh.topology.create_connectivity(tdim-1, tdim)
if tags is None:
ugrid = pyvista.UnstructuredGrid(*dolfinx.plot.vtk_mesh(mesh))
# Exclude indices marked zero
exclude_entities = tags.find(0)
marker = np.full_like(tags.values, True, dtype=np.bool_)
marker[exclude_entities] = False
ugrid = pyvista.UnstructuredGrid(*dolfinx.plot.vtk_mesh(mesh, tags.dim, tags.indices[marker]))
print(tags.indices[marker], tags.values[marker])
ugrid.cell_data["Marker"] = tags.values[marker]
plotter.add_mesh(ugrid, show_edges=True, line_width=3)
plotter.show_axes()
plotter.view_xy()
plotter.show()
plot_mesh(mesh, cell_tags)
facet_map = mesh.topology.index_map(tdim-1)
num_facets_local = facet_map.size_local + facet_map.num_ghosts
facet_values = np.zeros(num_facets_local, dtype=np.int32)
outer_marker = 4
facet_values[dolfinx.mesh.exterior_facet_indices(mesh.topology)] = 4
def inlet(x, tol=1e-14):
return np.isclose(x[0], 0.0) & ((x[1] >= 0.4-tol) & (x[1]<=0.6+tol))
inlet_marker = 1
facet_values[dolfinx.mesh.locate_entities_boundary(mesh, tdim-1, inlet)] = inlet_marker
def outlets(x, tol=1e-14):
return ((np.isclose(x[1], 0.0) & ((0.4 - tol <= x[0]) & (x[0]<=0.6 + tol))) |
(np.isclose(x[1], 1.0) & ((0.2 - tol <= x[0]) & (x[0] <= 0.35 + tol))))
outlet_marker = 2
facet_values[dolfinx.mesh.locate_entities_boundary(mesh, tdim-1, outlets)] = outlet_marker
interface_marker = 3
facet_values[dolfinx.mesh.locate_entities(mesh, tdim-1, lambda x: np.isclose(x[0], 0.7))] = interface_marker
facet_tags = dolfinx.mesh.meshtags(mesh, tdim-1, np.arange(num_facets_local, dtype=np.int32), facet_values)
plot_mesh(mesh, facet_tags)
with dolfinx.io.XDMFFile(mesh.comm, "tags.xdmf", "w") as xdmf:
xdmf.write_mesh(mesh)
xdmf.write_meshtags(facet_tags, mesh.geometry)
