Dear community,
I would like to solve a variational problem with terms of the form:
where \Gamma is a part of the boundary, u and v are real valued functions.
It is a multiplication of two integrals.
My DOLFINx version is 0.9.0. It was installed from conda-forge. I am working in a computer with ubuntu 22.04.
Below a “minimum working code example” to illustrate the problem:
from dolfinx import mesh
from dolfinx.fem import functionspace
print(f"DOLFINx version: {dolfinx.__version__}")
domain = mesh.create_unit_square(MPI.COMM_WORLD, 8, 8, mesh.CellType.quadrilateral)
def left(x):
return np.isclose(x[0], 0.)
def right(x):
return np.isclose(x[0], 1.)
marked_values = np.hstack([np.full_like(left_facets, 1), np.full_like(right_facets, 2)])
facet_tag = mesh.meshtags(domain, fdim, marked_facets[sorted_facets], marked_values[sorted_facets])
ds = ufl.Measure('ds', domain=domain, subdomain_data=facet_tag)
V = functionspace(domain, ("Lagrange", 1))
u = ufl.TrialFunction(V)
a = ufl.dot(ufl.grad(u), ufl.grad(v)) * ufl.dx + \
(u*v*ds(1) - (u*ds(1))*(v*ds(1))) + (u*v*ds(2) - (u*ds(2))*(v*ds(2)))
L = v*ds(1) - v*ds(2)
problem = LinearProblem(a, L)
uh = problem.solve()
The full error message is the following:
DOLFINx version: 0.9.0
File "/home/josue/Documents/MisTrabajos/Regularization_all-at-once_EIT/test.py", line 34, in <module>
TypeError: unsupported operand type(s) for *: 'Form' and 'Form'
I guess that this multiplication is not supported.
Do you know another way to write these kinds of terms?
