Nanobind related issues in my local dolfinx build
I am building dolfinx from source for creating my own docker image. On my laptop, dolfinx and nanobind work just fine. But in docker (where I have followed the same sequence), there seems to be an error. e,g,
mesh = dolfinx.mesh.create_unit_cube(MPI.COMM_WORLD, 10, 10, 10)
Vv = dolfinx.fem.functionspace(mesh, ("CG", 1))
print(f"Type: {type(Vv.element.interpolation_points)}")
I get
Type: <class 'numpy.ndarray'>
instead of
Type: <class 'nanobind.nb_bound_method'>
I have installed nanobind before compiling FEniCSx and also building locally HDF5 and ADIOS2 (with MPI support) correctly.
Thanks in advance,
~anoop
This is an API update on the main branch. interpolation_points is now a property of the element, not a call to the underlying C++ function for generating them.
Oh okay. Thank you. I will revert to older version of dolfinx then (as it depends on another open source package which I am using).
Thanks again
~anoop
