I just updated dolfinx and everything else in my conda environment. They’re now 0.10.0 and 2.9.2, respectively. Previous versions were installed this summer. With them, the following C++ code, applied to the _cpp_object inside the Python-side Function, used to work:
typedef Function<double> Function_f64;
const Function_f64* cast_Function_f64(const PyObject* obj) {
auto handle = nanobind::handle(obj);
return nanobind::cast<const Function_f64*>(handle);
Now, after the update, it throws std::bad_cast.
Anybody have an idea what has changed? Is there any other way to get the C++ object pointer to use in my code.
The following code, added to the above function, confirms that obj is a Function_float64.
const char* cstr = PyUnicode_AsUTF8(PyType_GetName(obj->ob_type));
std::cout << cstr << std::endl;
I’m using direct PyObjects here, because my own bindings are Python ← pyo3 → Rust – cxx → C++, with the main part of my own abstract code written in Rust, and some fenics-extensibility in Python. But I also need some higher performance parts that need the C++ pointer.
