TypeError: __init__(): incompatible function arguments. [...]
Hi everyone!
I am using the following conda env:
channels:
  - conda-forge
  - defaults
  - anaconda
variables:
  PYTHONNOUSERSITE: '1'
  LANG: 'C'
  LC_ALL: 'C'
  LC_NUMERIC: 'C'
  PYTHONIOENCODING: 'utf-8'
dependencies:
  - python 3.11
  - fenics-dolfinx 0.8.0
  - mpich 4.2.1
  - pyvista 0.39.0
  - gmsh 4.11.1
  - python-gmsh 4.11.1
  - numpy=1.24.3
  - scipy 1.10.1
  - matplotlib 3.7.1
  - pyqt 5.15.7
  - flake8 6.0.0
  - black 23.3.0
  - sphinx 7.0.1
  - sphinx-gallery 0.13.0
  - pytest 7.3.1
  - jupyter 1.0.0
  - trame 2.3.2
  - tqdm 4.65.0
  - backports.tempfile 1.0
  - treelib 1.6.4
  - meshio 5.3.4
  - shapely 2.0.1
  - numba 0.58.1
I should mention that I installed and used this environment until very recently without any problems. Today, I also tried to run this simple script:
from dolfinx.io.gmshio import model_to_mesh
GDIM = 2
MODEL_RANK = 0
MESH_COMM = MPI.COMM_WORLD
ri = 0.01  # Inner radius of wire
rc = 5  # Outer radius of wire
R = 100  # Radius of domain
nwire = 20  # number of wire divisions
lwire = 0.1  # mesh characteristic length for each segment
nenclo = 20  # number of external enclosure divisions
lenclo = 1  # mesh characteristic length for each segment
# create enclosure points (D-shape)
theta1 = np.linspace(np.pi / 2, -np.pi / 2, nenclo)
xenclo = R * np.cos(theta1)
yenclo = R * np.sin(theta1)
# create wire points (circular cross-section)
theta2 = np.linspace(0, 2 * np.pi, nwire)
xwire = rc + ri * np.cos(theta1)
ywire = ri * np.sin(theta1)
enclo_pts = []
enclo_lns = []
for i, (r, z) in enumerate(zip(xenclo, yenclo)):
    enclo_pts.append(gmsh.model.occ.addPoint(r, z, 0.0, lenclo))
    if i > 0:
        enclo_lns.append(gmsh.model.occ.addLine(enclo_pts[i - 1], enclo_pts[i]))
enclo_lns.append(gmsh.model.occ.addLine(enclo_pts[-1], enclo_pts[0]))
wire_pts = []
wire_lns = []
for i, (r, z) in enumerate(zip(xwire, ywire)):
    wire_pts.append(gmsh.model.occ.addPoint(r, z, 0.0, lenclo))
    if i > 0:
        wire_lns.append(gmsh.model.occ.addLine(wire_pts[i - 1], wire_pts[i]))
wire_lns.append(gmsh.model.occ.addLine(wire_pts[-1], wire_pts[0]))
gmsh.model.occ.addCurveLoop(enclo_lns, 0)
gmsh.model.occ.addCurveLoop(wire_lns, 1)
gmsh.model.occ.addPlaneSurface([1], 1)
gmsh.model.occ.addPlaneSurface([0, 1], 0)
gmsh.model.occ.synchronize()
gmsh.model.addPhysicalGroup(GDIM, [0], 0)
gmsh.model.addPhysicalGroup(GDIM, [1], 1)
# mesh generation options
gmsh.option.setNumber("Mesh.Algorithm", 2)
gmsh.option.setNumber("Mesh.CharacteristicLengthMin", lwire)
gmsh.option.setNumber("Mesh.CharacteristicLengthMax", lenclo)
# generate 2D mesh
gmsh.model.mesh.set_order(1)
gmsh.model.mesh.generate(GDIM)
mesh, ct, ft = model_to_mesh(gmsh.model, MESH_COMM, MODEL_RANK, GDIM)
gmsh.finalize()
I get the following errors:
  File "/home/mnotazio/mambaforge/envs/test_env/lib/python3.11/site-packages/dolfinx/fem/element.py", line 91, in _
    return CoordinateElement(_cpp.fem.CoordinateElement_float32(e._e))
TypeError: __init__(): incompatible function arguments. The following argument types are supported:
    1. __init__(self, celltype: dolfinx.cpp.mesh.CellType, degree: int) -> None
    2. __init__(self, element: basix::FiniteElement<float>) -> None
    3. __init__(self, celltype: dolfinx.cpp.mesh.CellType, degree: int, variant: int) -> None
Invoked with types: dolfinx.cpp.fem.CoordinateElement_float32, basix._basixcpp.FiniteElement_float64
  File "/home/mnotazio/PhD/pecan/git_local/pecan/mattenotazio/example_mesh.py", line 65, in <module>
  File "/home/mnotazio/mambaforge/envs/test_env/lib/python3.11/site-packages/dolfinx/io/gmshio.py", line 293, in model_to_mesh
    mesh = create_mesh(comm, cells, x[:, :gdim].astype(dtype, copy=False), ufl_domain, partitioner)
  File "/home/mnotazio/mambaforge/envs/test_env/lib/python3.11/site-packages/dolfinx/mesh.py", line 407, in create_mesh
    cmap = _coordinate_element(e_ufl.basix_element)  # type: ignore
  File "/home/mnotazio/mambaforge/envs/test_env/lib/python3.11/functools.py", line 909, in wrapper
  File "/home/mnotazio/mambaforge/envs/test_env/lib/python3.11/site-packages/dolfinx/fem/element.py", line 93, in _
    return CoordinateElement(_cpp.fem.CoordinateElement_float64(e._e))
    2. __init__(self, element: basix::FiniteElement<double>) -> None
Invoked with types: dolfinx.cpp.fem.CoordinateElement_float64, basix._basixcpp.FiniteElement_float64
Is anyone able to help me? Thank you in advance
Those sort of errors typically happens if you upgrade nanobind to a version which is different from the one used when building dolfinx, e.g. via pip or because some other conda package required a newer nanobind version. Did you possibly do that at some point in recent time?
Thank you very much for your prompt reply.
To my knowledge, I have not done any nanobind upgrades. Incidentally, this problem is also encountered on two other PCs, also without having done any nanobind upgrades.
In contrary, looking through the various conda env packages, nanobind is not even present. Is this normal? I apologise in advance in case I’m talking nonsense.
It may be something else then, cc @minrk
This is almost certainly the mismatch in nanobind abi for basix and dolfinx. What matters is the version of nanobind and the c compiler at build time of those packages, not your environment, so it can be hard to tell. Can you share conda env export? I thought I had fixed this, so it shouldn’t happen for fresh installs, but if you share your environment I’ll see if I missed something.
Thank you @minrk for the reply.
Here is the conda env export for my env:
channels:
  - conda-forge
dependencies:
  - _libgcc_mutex=0.1=conda_forge
  - _openmp_mutex=4.5=2_gnu
  - _sysroot_linux-64_curr_repodata_hack=3=h69a702a_16
  - aiohappyeyeballs=2.4.0=pyhd8ed1ab_0
  - aiohttp=3.10.5=py311h9ecbd09_1
  - aiosignal=1.3.1=pyhd8ed1ab_0
  - alabaster=0.7.16=pyhd8ed1ab_0
  - alsa-lib=1.2.12=h4ab18f5_0
  - anyio=4.6.0=pyhd8ed1ab_1
  - aom=3.9.1=hac33072_0
  - argon2-cffi=23.1.0=pyhd8ed1ab_0
  - argon2-cffi-bindings=21.2.0=py311h9ecbd09_5
  - arrow=1.3.0=pyhd8ed1ab_0
  - asttokens=2.4.1=pyhd8ed1ab_0
  - async-lru=2.0.4=pyhd8ed1ab_0
  - attr=2.5.1=h166bdaf_1
  - attrs=24.2.0=pyh71513ae_0
  - babel=2.14.0=pyhd8ed1ab_0
  - backports=1.0=pyhd8ed1ab_4
  - backports.tempfile=1.0=py_0
  - backports.weakref=1.0.post1=pyhd8ed1ab_1003
  - beautifulsoup4=4.12.3=pyha770c72_0
  - binutils_impl_linux-64=2.40=ha1999f0_7
  - binutils_linux-64=2.40=hb3c18ed_3
  - black=23.3.0=py311h38be061_1
  - bleach=6.1.0=pyhd8ed1ab_0
  - blosc=1.21.6=hef167b5_0
  - brotli=1.1.0=hb9d3cd8_2
  - brotli-bin=1.1.0=hb9d3cd8_2
  - brotli-python=1.1.0=py311hfdbb021_2
  - bzip2=1.0.8=h4bc722e_7
  - c-ares=1.33.1=heb4867d_0
  - c-blosc2=2.14.4=hb4ffafa_1
  - ca-certificates=2024.8.30=hbcca054_0
  - cached-property=1.5.2=hd8ed1ab_1
  - cached_property=1.5.2=pyha770c72_1
  - cairo=1.18.0=hebfffa5_3
  - certifi=2024.8.30=pyhd8ed1ab_0
  - cffi=1.17.1=py311hf29c0ef_0
  - cftime=1.6.4=py311h9f3472d_1
  - charset-normalizer=3.3.2=pyhd8ed1ab_0
  - click=8.1.7=unix_pyh707e725_0
  - colorama=0.4.6=pyhd8ed1ab_0
  - comm=0.2.2=pyhd8ed1ab_0
  - contourpy=1.3.0=py311hd18a35c_1
  - cycler=0.12.1=pyhd8ed1ab_0
  - dav1d=1.2.1=hd590300_0
  - dbus=1.13.6=h5008d03_3
  - debugpy=1.8.5=py311hfdbb021_1
  - decorator=5.1.1=pyhd8ed1ab_0
  - defusedxml=0.7.1=pyhd8ed1ab_0
  - docutils=0.20.1=py311h38be061_3
  - double-conversion=3.3.0=h59595ed_0
  - eigen=3.4.0=h00ab1b0_0
  - entrypoints=0.4=pyhd8ed1ab_0
  - exceptiongroup=1.2.2=pyhd8ed1ab_0
  - executing=2.1.0=pyhd8ed1ab_0
  - expat=2.6.3=h5888daf_0
  - fenics-basix=0.8.0=py311h1feab5d_3
  - fenics-dolfinx=0.8.0=py311hc8b80c1_103
  - fenics-ffcx=0.8.0=pyh4af843d_0
  - fenics-libbasix=0.8.0=h7cb7ce6_3
  - fenics-libdolfinx=0.8.0=hf0bfe3a_103
  - fenics-ufcx=0.8.0=h22f594c_0
  - fenics-ufl=2024.1.0=pyhd8ed1ab_0
  - ffmpeg=6.1.2=gpl_h8657690_705
  - fftw=3.3.10=mpi_mpich_hbcf76dd_10
  - flake8=6.0.0=pyhd8ed1ab_0
  - fltk=1.3.9=h9305793_1
  - font-ttf-dejavu-sans-mono=2.37=hab24e00_0
  - font-ttf-inconsolata=3.000=h77eed37_0
  - font-ttf-source-code-pro=2.038=h77eed37_0
  - font-ttf-ubuntu=0.83=h77eed37_2
  - fontconfig=2.14.2=h14ed4e7_0
  - fonts-conda-ecosystem=1=0
  - fonts-conda-forge=1=0
  - fonttools=4.54.0=py311h9ecbd09_0
  - fqdn=1.5.1=pyhd8ed1ab_0
  - freeimage=3.18.0=h4bd6248_21
  - freetype=2.12.1=h267a509_2
  - fribidi=1.0.10=h36c2ea0_0
  - frozenlist=1.4.1=py311h9ecbd09_1
  - gcc_impl_linux-64=12.4.0=hb2e57f8_1
  - gcc_linux-64=12.4.0=h6b7512a_3
  - geos=3.12.0=h59595ed_0
  - gettext=0.22.5=he02047a_3
  - gettext-tools=0.22.5=he02047a_3
  - gl2ps=1.4.2=hae5d5c5_1
  - glew=2.1.0=h9c3ff4c_2
  - glib=2.80.3=h315aac3_2
  - glib-tools=2.80.3=h8fdd7da_2
  - gmp=6.3.0=hac33072_2
  - gmsh=4.11.1=h6b98cf8_6
  - graphite2=1.3.13=h59595ed_1003
  - gst-plugins-base=1.24.7=h0a52356_0
  - gstreamer=1.24.7=hf3bb09a_0
  - gxx_impl_linux-64=12.4.0=h613a52c_1
  - gxx_linux-64=12.4.0=h8489865_3
  - h11=0.14.0=pyhd8ed1ab_0
  - h2=4.1.0=pyhd8ed1ab_0
  - h5py=3.11.0=nompi_py311h439e445_102
  - harfbuzz=9.0.0=hda332d3_1
  - hdf4=4.2.15=h2a13503_7
  - hdf5=1.14.3=mpi_mpich_h0f54ddc_5
  - hpack=4.0.0=pyh9f0ad1d_0
  - httpcore=1.0.5=pyhd8ed1ab_0
  - httpx=0.27.2=pyhd8ed1ab_0
  - hyperframe=6.0.1=pyhd8ed1ab_0
  - hypre=2.31.0=mpi_mpich_hd1da18f_1
  - icu=75.1=he02047a_0
  - idna=3.10=pyhd8ed1ab_0
  - imagesize=1.4.1=pyhd8ed1ab_0
  - imath=3.1.12=h7955e40_0
  - importlib-metadata=8.5.0=pyha770c72_0
  - importlib_metadata=8.5.0=hd8ed1ab_0
  - importlib_resources=6.4.5=pyhd8ed1ab_0
  - iniconfig=2.0.0=pyhd8ed1ab_0
  - ipykernel=6.29.5=pyh3099207_0
  - ipython=8.27.0=pyh707e725_0
  - ipywidgets=8.1.5=pyhd8ed1ab_0
  - isoduration=20.11.0=pyhd8ed1ab_0
  - jedi=0.19.1=pyhd8ed1ab_0
  - jinja2=3.1.4=pyhd8ed1ab_0
  - json5=0.9.25=pyhd8ed1ab_0
  - jsoncpp=1.9.6=h84d6215_0
  - jsonpointer=3.0.0=py311h38be061_1
  - jsonschema=4.23.0=pyhd8ed1ab_0
  - jsonschema-specifications=2023.12.1=pyhd8ed1ab_0
  - jsonschema-with-format-nongpl=4.23.0=hd8ed1ab_0
  - jupyter=1.0.0=pyhd8ed1ab_10
  - jupyter-lsp=2.2.5=pyhd8ed1ab_0
  - jupyter_client=8.6.3=pyhd8ed1ab_0
  - jupyter_console=6.6.3=pyhd8ed1ab_0
  - jupyter_core=5.7.2=pyh31011fe_1
  - jupyter_events=0.10.0=pyhd8ed1ab_0
  - jupyter_server=2.14.2=pyhd8ed1ab_0
  - jupyter_server_terminals=0.5.3=pyhd8ed1ab_0
  - jupyterlab=4.2.5=pyhd8ed1ab_0
  - jupyterlab_pygments=0.3.0=pyhd8ed1ab_1
  - jupyterlab_server=2.27.3=pyhd8ed1ab_0
  - jupyterlab_widgets=3.0.13=pyhd8ed1ab_0
  - jxrlib=1.1=hd590300_3
  - kahip=3.16=h1143d03_3
  - kahip-python=3.16=py311hfdd914f_3
  - kernel-headers_linux-64=3.10.0=h4a8ded7_16
  - keyutils=1.6.1=h166bdaf_0
  - kiwisolver=1.4.7=py311hd18a35c_0
  - krb5=1.21.3=h659f571_0
  - lame=3.100=h166bdaf_1003
  - lcms2=2.16=hb7c19ff_0
  - ld_impl_linux-64=2.40=hf3520f5_7
  - lerc=4.0.0=h27087fc_0
  - libabseil=20240116.2=cxx17_he02047a_1
  - libadios2=2.10.0=mpi_mpich_h3e60829_3
  - libaec=1.1.3=h59595ed_0
  - libasprintf=0.22.5=he8f35ee_3
  - libasprintf-devel=0.22.5=he8f35ee_3
  - libass=0.17.3=h1dc1e6a_0
  - libblas=3.9.0=20_linux64_openblas
  - libboost=1.84.0=hb8260a3_6
  - libboost-devel=1.84.0=h1a2810e_6
  - libboost-headers=1.84.0=ha770c72_6
  - libbrotlicommon=1.1.0=hb9d3cd8_2
  - libbrotlidec=1.1.0=hb9d3cd8_2
  - libbrotlienc=1.1.0=hb9d3cd8_2
  - libcap=2.69=h0f662aa_0
  - libcblas=3.9.0=20_linux64_openblas
  - libclang-cpp15=15.0.7=default_h127d8a8_5
  - libclang-cpp19.1=19.1.0=default_hb5137d0_0
  - libclang13=19.1.0=default_h9c6a7e4_0
  - libcups=2.3.3=h4637d8d_4
  - libcurl=8.10.1=hbbe4b11_0
  - libdeflate=1.21=h4bc722e_0
  - libdrm=2.4.123=hb9d3cd8_0
  - libedit=3.1.20191231=he28a2e2_2
  - libegl=1.7.0=ha4b6fd6_0
  - libev=4.33=hd590300_2
  - libevent=2.1.12=hf998b51_1
  - libexpat=2.6.3=h5888daf_0
  - libffi=3.4.2=h7f98852_5
  - libflac=1.4.3=h59595ed_0
  - libgcc=14.1.0=h77fa898_1
  - libgcc-devel_linux-64=12.4.0=ha4f9413_101
  - libgcc-ng=14.1.0=h69a702a_1
  - libgcrypt=1.11.0=h4ab18f5_1
  - libgettextpo=0.22.5=he02047a_3
  - libgettextpo-devel=0.22.5=he02047a_3
  - libgfortran=14.1.0=h69a702a_1
  - libgfortran-ng=14.1.0=h69a702a_1
  - libgfortran5=14.1.0=hc5f4f2c_1
  - libgl=1.7.0=ha4b6fd6_0
  - libglib=2.80.3=h315aac3_2
  - libglu=9.0.0=ha6d2627_1004
  - libglvnd=1.7.0=ha4b6fd6_0
  - libglx=1.7.0=ha4b6fd6_0
  - libgomp=14.1.0=h77fa898_1
  - libgpg-error=1.50=h4f305b6_0
  - libhwloc=2.11.1=default_hecaa2ac_1000
  - libiconv=1.17=hd590300_2
  - libjpeg-turbo=3.0.0=hd590300_1
  - liblapack=3.9.0=20_linux64_openblas
  - libllvm14=14.0.6=hcd5def8_4
  - libllvm15=15.0.7=hb3ce162_4
  - libllvm19=19.1.0=ha7bfdaf_0
  - libnetcdf=4.9.2=nompi_h135f659_114
  - libnghttp2=1.58.0=h47da74e_1
  - libnsl=2.0.1=hd590300_0
  - libogg=1.3.5=h4ab18f5_0
  - libopenblas=0.3.25=pthreads_h413a1c8_0
  - libopenvino=2024.4.0=hac27bb2_0
  - libopenvino-auto-batch-plugin=2024.4.0=h4d9b6c2_0
  - libopenvino-auto-plugin=2024.4.0=h4d9b6c2_0
  - libopenvino-hetero-plugin=2024.4.0=h3f63f65_0
  - libopenvino-intel-cpu-plugin=2024.4.0=hac27bb2_0
  - libopenvino-intel-gpu-plugin=2024.4.0=hac27bb2_0
  - libopenvino-intel-npu-plugin=2024.4.0=hac27bb2_0
  - libopenvino-ir-frontend=2024.4.0=h3f63f65_0
  - libopenvino-onnx-frontend=2024.4.0=h56242b0_0
  - libopenvino-paddle-frontend=2024.4.0=h56242b0_0
  - libopenvino-pytorch-frontend=2024.4.0=h5888daf_0
  - libopenvino-tensorflow-frontend=2024.4.0=h358ae18_0
  - libopenvino-tensorflow-lite-frontend=2024.4.0=h5888daf_0
  - libopus=1.3.1=h7f98852_1
  - libpciaccess=0.18=hd590300_0
  - libpng=1.6.44=hadc24fc_0
  - libpq=16.4=h2d7952a_1
  - libprotobuf=4.25.3=hd5b35b9_1
  - libptscotch=7.0.4=h2376d02_5
  - libraw=0.21.3=hca62329_0
  - libsanitizer=12.4.0=h46f95d5_1
  - libscotch=7.0.4=h3055ed5_5
  - libsndfile=1.2.2=hc60ed4a_1
  - libsodium=1.0.20=h4ab18f5_0
  - libsqlite=3.46.1=hadc24fc_0
  - libssh2=1.11.0=h0841786_0
  - libstdcxx=14.1.0=hc0a3c3a_1
  - libstdcxx-devel_linux-64=12.4.0=ha4f9413_101
  - libstdcxx-ng=14.1.0=h4852527_1
  - libsystemd0=256.6=h2774228_0
  - libtheora=1.1.1=h4ab18f5_1006
  - libtiff=4.7.0=h6565414_0
  - libuuid=2.38.1=h0b41bf4_0
  - libva=2.22.0=h8a09558_1
  - libvorbis=1.3.7=h9c3ff4c_0
  - libvpx=1.14.1=hac33072_0
  - libwebp-base=1.4.0=hd590300_0
  - libxcb=1.16=hb9d3cd8_1
  - libxkbcommon=1.7.0=h2c5496b_1
  - libxml2=2.12.7=he7c6b58_4
  - libzip=1.11.1=hf83b1b0_0
  - libzlib=1.3.1=h4ab18f5_1
  - llvmlite=0.41.1=py311ha6695c7_0
  - loguru=0.7.2=py311h38be061_2
  - lz4-c=1.9.4=hcb278e6_0
  - markdown-it-py=3.0.0=pyhd8ed1ab_0
  - markupsafe=2.1.5=py311h9ecbd09_1
  - matplotlib=3.7.1=py311h38be061_0
  - matplotlib-base=3.7.1=py311h8597a09_0
  - matplotlib-inline=0.1.7=pyhd8ed1ab_0
  - mccabe=0.7.0=pyhd8ed1ab_0
  - mdurl=0.1.2=pyhd8ed1ab_0
  - meshio=5.3.4=pyhd8ed1ab_0
  - metis=5.1.0=h59595ed_1007
  - mistune=3.0.2=pyhd8ed1ab_0
  - more-itertools=10.5.0=pyhd8ed1ab_0
  - mpfr=4.2.1=h90cbb55_3
  - mpg123=1.32.6=h59595ed_0
  - mpi=1.0=mpich
  - mpi4py=3.1.6=py311h0b14fea_1
  - mpich=4.2.1=h63d650b_101
  - msgpack-python=1.1.0=py311hd18a35c_0
  - multidict=6.1.0=py311h9ecbd09_0
  - mumps-include=5.7.2=ha770c72_0
  - mumps-mpi=5.7.2=h09c71e5_0
  - munkres=1.1.4=pyh9f0ad1d_0
  - mypy_extensions=1.0.0=pyha770c72_0
  - mysql-common=9.0.1=h70512c7_0
  - mysql-libs=9.0.1=ha479ceb_0
  - nbclient=0.10.0=pyhd8ed1ab_0
  - nbconvert=7.16.4=hd8ed1ab_1
  - nbconvert-core=7.16.4=pyhd8ed1ab_1
  - nbconvert-pandoc=7.16.4=hd8ed1ab_1
  - nbformat=5.10.4=pyhd8ed1ab_0
  - ncurses=6.5=he02047a_1
  - nest-asyncio=1.6.0=pyhd8ed1ab_0
  - netcdf4=1.7.1=nompi_py311hae66bec_102
  - nlohmann_json=3.11.3=he02047a_1
  - notebook=7.2.2=pyhd8ed1ab_0
  - notebook-shim=0.2.4=pyhd8ed1ab_0
  - nspr=4.35=h27087fc_0
  - nss=3.104=hd34e28f_0
  - numba=0.58.1=py311h96b013e_0
  - numpy=1.24.3=py311h64a7726_0
  - occt=7.7.2=novtk_h130ccc2_101
  - ocl-icd=2.3.2=hd590300_1
  - openexr=3.2.2=h04e0de5_2
  - openh264=2.4.1=h59595ed_0
  - openjpeg=2.5.2=h488ebb8_0
  - openssl=3.3.2=hb9d3cd8_0
  - overrides=7.7.0=pyhd8ed1ab_0
  - packaging=24.1=pyhd8ed1ab_0
  - pandoc=3.4=ha770c72_0
  - pandocfilters=1.5.0=pyhd8ed1ab_0
  - parmetis=4.0.3=h583469f_1006
  - parso=0.8.4=pyhd8ed1ab_0
  - pathspec=0.12.1=pyhd8ed1ab_0
  - pcre2=10.44=hba22ea6_2
  - petsc=3.21.3=real_h7906ff3_100
  - petsc4py=3.21.3=py311h3fe0c0c_1
  - pexpect=4.9.0=pyhd8ed1ab_0
  - pickleshare=0.7.5=py_1003
  - pillow=10.4.0=py311h4aec55e_1
  - pip=24.2=pyh8b19718_1
  - pixman=0.43.2=h59595ed_0
  - pkg-config=0.29.2=h4bc722e_1009
  - pkgutil-resolve-name=1.3.10=pyhd8ed1ab_1
  - platformdirs=4.3.6=pyhd8ed1ab_0
  - pluggy=1.5.0=pyhd8ed1ab_0
  - ply=3.11=pyhd8ed1ab_2
  - pooch=1.8.2=pyhd8ed1ab_0
  - proj=9.5.0=h12925eb_0
  - prometheus_client=0.21.0=pyhd8ed1ab_0
  - prompt-toolkit=3.0.47=pyha770c72_0
  - prompt_toolkit=3.0.47=hd8ed1ab_0
  - psutil=6.0.0=py311h9ecbd09_1
  - pthread-stubs=0.4=hb9d3cd8_1002
  - ptscotch=7.0.4=h23d43cc_5
  - ptyprocess=0.7.0=pyhd3deb0d_0
  - pugixml=1.14=h59595ed_0
  - pulseaudio-client=17.0=hb77b528_0
  - pure_eval=0.2.3=pyhd8ed1ab_0
  - pycodestyle=2.10.0=pyhd8ed1ab_0
  - pycparser=2.22=pyhd8ed1ab_0
  - pyflakes=3.0.1=pyhd8ed1ab_0
  - pygments=2.18.0=pyhd8ed1ab_0
  - pyparsing=3.1.4=pyhd8ed1ab_0
  - pyqt=5.15.7=py311ha74522f_3
  - pyqt5-sip=12.11.0=py311hcafe171_3
  - pysocks=1.7.1=pyha2e5f31_6
  - pytest=7.3.1=pyhd8ed1ab_0
  - python=3.11.0=he550d4f_1_cpython
  - python-dateutil=2.9.0=pyhd8ed1ab_0
  - python-fastjsonschema=2.20.0=pyhd8ed1ab_0
  - python-gmsh=4.11.1=h57928b3_6
  - python-json-logger=2.0.7=pyhd8ed1ab_0
  - python_abi=3.11=5_cp311
  - pytz=2024.2=pyhd8ed1ab_0
  - pyvista=0.39.0=pyhd8ed1ab_0
  - pyyaml=6.0.2=py311h9ecbd09_1
  - pyzmq=26.2.0=py311h7deb3e3_2
  - qt-main=5.15.8=h3155989_26
  - qt6-main=6.7.2=hadfd74e_5
  - qtconsole-base=5.6.0=pyha770c72_0
  - qtpy=2.4.1=pyhd8ed1ab_0
  - rapidjson=1.1.0.post20240409=hac33072_1
  - readline=8.2=h8228510_1
  - referencing=0.35.1=pyhd8ed1ab_0
  - requests=2.32.3=pyhd8ed1ab_0
  - rfc3339-validator=0.1.4=pyhd8ed1ab_0
  - rfc3986-validator=0.1.1=pyh9f0ad1d_0
  - rich=13.8.1=pyhd8ed1ab_0
  - rpds-py=0.20.0=py311h9e33e62_1
  - scalapack=2.2.0=h417d24c_2
  - scipy=1.10.1=py311h64a7726_3
  - scooby=0.10.0=pyhd8ed1ab_0
  - scotch=7.0.4=h23d43cc_5
  - send2trash=1.8.3=pyh0d859eb_0
  - setuptools=74.1.2=pyhd8ed1ab_0
  - shapely=2.0.1=py311he06c224_3
  - sip=6.7.12=py311hb755f60_0
  - six=1.16.0=pyh6c4a22f_0
  - slepc=3.21.1=real_h97ad6bc_302
  - slepc4py=3.21.1=py311h1ce286c_102
  - snappy=1.2.1=ha2e4443_0
  - sniffio=1.3.1=pyhd8ed1ab_0
  - snowballstemmer=2.2.0=pyhd8ed1ab_0
  - soupsieve=2.5=pyhd8ed1ab_1
  - sphinx=7.0.1=pyhd8ed1ab_0
  - sphinx-gallery=0.13.0=pyhd8ed1ab_0
  - sphinxcontrib-applehelp=2.0.0=pyhd8ed1ab_0
  - sphinxcontrib-devhelp=2.0.0=pyhd8ed1ab_0
  - sphinxcontrib-htmlhelp=2.1.0=pyhd8ed1ab_0
  - sphinxcontrib-jsmath=1.0.1=pyhd8ed1ab_0
  - sphinxcontrib-qthelp=2.0.0=pyhd8ed1ab_0
  - sphinxcontrib-serializinghtml=1.1.10=pyhd8ed1ab_0
  - sqlite=3.46.1=h9eae976_0
  - stack_data=0.6.2=pyhd8ed1ab_0
  - suitesparse=7.7.0=hf4753ba_1
  - superlu=5.2.2=h00795ac_0
  - superlu_dist=9.0.0=h3feb4ed_1
  - svt-av1=2.2.1=h5888daf_0
  - sysroot_linux-64=2.17=h4a8ded7_16
  - tbb=2021.13.0=h84d6215_0
  - tbb-devel=2021.13.0=h94b29a5_0
  - terminado=0.18.1=pyh0d859eb_0
  - tinycss2=1.3.0=pyhd8ed1ab_0
  - tk=8.6.13=noxft_h4845f30_101
  - toml=0.10.2=pyhd8ed1ab_0
  - tomli=2.0.1=pyhd8ed1ab_0
  - tornado=6.4.1=py311h9ecbd09_1
  - tqdm=4.65.0=pyhd8ed1ab_1
  - traitlets=5.14.3=pyhd8ed1ab_0
  - trame=2.3.2=pyhd8ed1ab_0
  - trame-client=3.3.1=pyhd8ed1ab_0
  - trame-components=2.4.0=pyhd8ed1ab_0
  - trame-deckgl=2.0.3=pyhd8ed1ab_0
  - trame-markdown=3.0.2=pyhd8ed1ab_0
  - trame-matplotlib=2.0.2=pyhd8ed1ab_0
  - trame-plotly=3.0.2=pyhd8ed1ab_0
  - trame-rca=0.4.4=pyhd8ed1ab_0
  - trame-router=2.3.0=pyhd8ed1ab_0
  - trame-server=3.2.3=pyhd8ed1ab_0
  - trame-simput=2.4.3=pyhd8ed1ab_0
  - trame-vega=2.1.1=pyhd8ed1ab_0
  - trame-vtk=2.8.10=pyhd8ed1ab_0
  - trame-vuetify=2.7.1=pyhd8ed1ab_0
  - treelib=1.6.4=pyhd8ed1ab_0
  - types-python-dateutil=2.9.0.20240906=pyhd8ed1ab_0
  - typing-extensions=4.12.2=hd8ed1ab_0
  - typing_extensions=4.12.2=pyha770c72_0
  - typing_utils=0.1.0=pyhd8ed1ab_0
  - tzdata=2024a=h8827d51_1
  - uri-template=1.3.0=pyhd8ed1ab_0
  - urllib3=2.2.3=pyhd8ed1ab_0
  - utfcpp=4.0.5=ha770c72_0
  - vtk=9.3.1=qt_py311he5e186c_208
  - vtk-base=9.3.1=qt_py311h913fd79_208
  - vtk-io-ffmpeg=9.3.1=qt_py311hc8241c7_208
  - wayland=1.23.1=h3e06ad9_0
  - wayland-protocols=1.37=hd8ed1ab_0
  - wcwidth=0.2.13=pyhd8ed1ab_0
  - webcolors=24.8.0=pyhd8ed1ab_0
  - webencodings=0.5.1=pyhd8ed1ab_2
  - websocket-client=1.8.0=pyhd8ed1ab_0
  - wheel=0.44.0=pyhd8ed1ab_0
  - widgetsnbextension=4.0.13=pyhd8ed1ab_0
  - wslink=2.2.1=pyhd8ed1ab_0
  - x264=1!164.3095=h166bdaf_2
  - x265=3.5=h924138e_3
  - xcb-util=0.4.1=hb711507_2
  - xcb-util-cursor=0.1.5=hb9d3cd8_0
  - xcb-util-image=0.4.0=hb711507_2
  - xcb-util-keysyms=0.4.1=hb711507_0
  - xcb-util-renderutil=0.3.10=hb711507_0
  - xcb-util-wm=0.4.2=hb711507_0
  - xkeyboard-config=2.42=h4ab18f5_0
  - xorg-fixesproto=5.0=hb9d3cd8_1003
  - xorg-inputproto=2.3.2=hb9d3cd8_1003
  - xorg-kbproto=1.0.7=hb9d3cd8_1003
  - xorg-libice=1.1.1=hd590300_0
  - xorg-libsm=1.2.4=h7391055_0
  - xorg-libx11=1.8.9=hb711507_1
  - xorg-libxau=1.0.11=hb9d3cd8_1
  - xorg-libxdmcp=1.1.3=hb9d3cd8_1
  - xorg-libxext=1.3.4=h0b41bf4_2
  - xorg-libxfixes=5.0.3=h7f98852_1004
  - xorg-libxi=1.7.10=h4bc722e_1
  - xorg-libxmu=1.1.3=h4ab18f5_1
  - xorg-libxrender=0.9.11=hd590300_0
  - xorg-libxt=1.3.0=hd590300_1
  - xorg-libxtst=1.2.5=h4bc722e_0
  - xorg-libxxf86vm=1.1.5=hb9d3cd8_2
  - xorg-recordproto=1.14.2=hb9d3cd8_1003
  - xorg-renderproto=0.11.1=hb9d3cd8_1003
  - xorg-xextproto=7.3.0=hb9d3cd8_1004
  - xorg-xf86vidmodeproto=2.3.1=hb9d3cd8_1003
  - xorg-xproto=7.0.31=hb9d3cd8_1008
  - xz=5.2.6=h166bdaf_0
  - yaml=0.2.5=h7f98852_2
  - yarl=1.9.4=py311h9ecbd09_1
  - zeromq=4.3.5=ha4adb4c_5
  - zfp=0.5.5=h9c3ff4c_8
  - zipp=3.20.2=pyhd8ed1ab_0
  - zlib=1.3.1=h4ab18f5_1
  - zlib-ng=2.0.7=h0b41bf4_0
  - zstandard=0.23.0=py311hbc35293_1
  - zstd=1.5.6=ha6fb4c9_0
  - pip:
      - pecan==0.0.0
variables:
  LANG: C
  LC_ALL: C
  LC_NUMERIC: C
  PYTHONIOENCODING: utf-8
prefix: /home/mnotazio/mambaforge/envs/test_env
I look forward to your opinion. Thank you again
yes, indeed I messed up the exclusion, so you have this gcc 13 build of fenics-basix with this gcc 12 build of fenics-dolfinx. They should conflict, but don’t. I’m working on fixing that. But if you update fenics-dolfinx, (latest build is 106), it should be fixed; it’s only outdated builds of fenics-dolfinx that don’t properly exclude incompatible basix. You can also ensure the not-quite-right exclusion is applied properly if you install gxx=13 in the meantime:
mamba upgrade gxx=13 fenics-dolfinx
Thank you very much @minrk ! It works like a charm!
Thanks to all fenics team for the support!
Hello @minrk, I got the exactly same error. I freshly built fenics-basix and fenics-dolfinx with the same nanobind. Below is my conda env export:
channels:
  - conda-forge
dependencies:
  - _openmp_mutex=4.5=3_kmp_llvm
  - ca-certificates=2025.4.26=hbd8a1cb_0
  - ld_impl_linux-64=2.43=h712a8e2_4
  - libblas=3.9.0=31_hfdb39a5_mkl
  - libcblas=3.9.0=31_h372d94f_mkl
  - libexpat=2.7.0=h5888daf_0
  - libffi=3.4.6=h2dba641_1
  - libgcc=15.1.0=h767d61c_2
  - libgcc-ng=15.1.0=h69a702a_2
  - libgomp=15.1.0=h767d61c_2
  - libhwloc=2.11.2=default_h0d58e46_1001
  - libiconv=1.18=h4ce23a2_1
  - liblapack=3.9.0=31_hc41d3b0_mkl
  - liblzma=5.8.1=hb9d3cd8_1
  - libsqlite=3.50.0=hee588c1_0
  - libstdcxx=15.1.0=h8f9b012_2
  - libstdcxx-ng=15.1.0=h4852527_2
  - libxcrypt=4.4.36=hd590300_1
  - libxml2=2.13.8=h4bc477f_0
  - libzlib=1.3.1=hb9d3cd8_2
  - llvm-openmp=20.1.6=h024ca30_0
  - mkl=2024.2.2=ha957f24_16
  - ncurses=6.5=h2d0b736_3
  - numpy=2.2.6=py312h72c5963_0
  - openssl=3.5.0=h7b32b05_1
  - pip=25.1.1=pyh8b19718_0
  - python=3.12.10=h9e4cc4f_0_cpython
  - python_abi=3.12=7_cp312
  - readline=8.2=h8c095d6_2
  - setuptools=80.8.0=pyhff2d567_0
  - tbb=2021.13.0=hceb3a55_1
  - tk=8.6.13=noxft_hd72426e_102
  - tzdata=2025b=h78e105d_0
  - wheel=0.45.1=pyhd8ed1ab_1
  - pip:
      - cffi==1.16.0
      - fenics-basix==0.9.0
      - fenics-dolfinx==0.9.0
      - fenics-ffcx==0.9.0
      - fenics-ufl==2024.2.0
      - gmsh==4.13.1
      - mpi4py==4.0.3
      - nanobind==2.7.0
      - packaging==25.0
      - pathspec==0.12.1
      - petsc4py==3.23.2
      - pycparser==2.22
      - scikit-build-core==0.11.3
I built fenics-dolfinx from source but installed fenics-basix just from binary wheels. Should I build 'fenics-basix` from source to resolve this issue?
That’s definitely the issue. When you install it from a binary wheel you are not aware of which nanobind version was used to build it, it may be different from the one on your system.
Thanks for pointing this out. Then should I also build fenics-ffcx from source?
I rebuilt fenics-basix and fenics-ffcx from source and that solved the issue. Thank you.
