I want to implement a model in FEniCS which uses a so called “local newton iteration”, where the equation for the internal (tensor-valued) variable \boldsymbol{a} is to be solved at the Gaus point level. From the example of plasticity from Jeremy Bleyer I understand that I should use Quadrature-Elements for the representation at the Gauss-Points.
The equation has the form \boldsymbol{a} = \exp{\boldsymbol{b}} \cdot \boldsymbol{c} where \boldsymbol{b} = \boldsymbol{b}(\boldsymbol{a}) is a non-linear function of \boldsymbol{a} and \boldsymbol{c} = \boldsymbol{c}(\boldsymbol{a} ,\boldsymbol{u}) a nonlinear function of \boldsymbol{a} and the displacement \boldsymbol{u}.
What I do not know is how to solve equations in FEniCS at the Gauss points without defining a weak form. Is this possible?
Hi, currently there is no way of doing this easily with high-level FEniCS syntax. With the latest developments in dolfin-x this should hopefully be easier in the near future.
Currently, I suggest mimicking the demo which uses the MFront code generator at the Gauss point level and replacing it with your own local Newton at the Gauss point level using Numpy for instance.
Alternatively, if your example comes from a nonlinear mechanics constitutive law, it would be even more interesting to implement and solve it with MFront directly using then mgis.fenics.
I have a question regarding the installation of MFront.
I downloaded the install.sh - file which was referenced at the site you linked, changed the prefix variable to
PREFIX=MFront
and started the script with bash install.sh
It downloads the files from github and create the directories tfel and mgis but when the script reaces the line 86 I get the error
install.sh: line 86: MFront/codes/tfel/master/install-10362d221b7cbeaef3855b4c24d7581f49dcc963/env.sh: file or directory not found
do I have to make more changes in the install-script or is there an update?
Hi, I was working on a similar problem which required a local newton solver at the Gauss point level. I implemented it by using the dolfinx-external-operators library, which allows you to make numerical computations at the Gauss point. Take a look at the demos here: Plasticity of von Mises and Plasticity of Mohr-Coulomb with apex-smoothing.
In the first tutorial, Numba library is used, here one can use a standard “for loop” to implement a local newton solver inside the return_mapping function.
In the second tutorial, JAX library is used. In the tutorial, a local newton solver is implemented using jax.lax.while_loop.
