No module named 'gmsh'
Sorry to bother you! I want to ask about the download of Gmsh. Recently, I was going to use gmsh to draw a grid, when I called it, it would display No module named 'gmsh', but I have installed gmsh under fenicsx-env using conda install -c conda-forge gmsh command, and the interpreter in pycharm showed that gmsh already exists, I would like to ask what is wrong?
Remarks Version:
fenics-dolfinx: 0.9.0
gmsh: 4.13.1
I look forward to your reply, thank you!
  File "/mnt/d/femcode/fem/Mesh/demo_gmsh.py", line 25, in <module>
ModuleNotFoundError: No module named 'gmsh'
ERROR conda.cli.main_run:execute(124): `conda run python /mnt/d/femcode/fem/Mesh/demo_gmsh.py` failed. (See above for error)
Try pygmsh instead of gmsh:
pip install pygmsh
After I deleted gmsh, I used the command you recommended to download it again, and there will be a new error. Thank you!
  File "/home/zqaixj1234/miniconda3/envs/fenicsx-env/lib/python3.13/site-packages/gmsh.py", line 87, in <module>
    lib = CDLL(libpath)
  File "/home/zqaixj1234/miniconda3/envs/fenicsx-env/lib/python3.13/ctypes/__init__.py", line 390, in __init__
    self._handle = _dlopen(self._name, mode)
OSError: libXft.so.2: cannot open shared object file: No such file or directory
Your info is not completed. How did you install your dependencies? How did you run your code? It seems that you run with
Try to run with
This problem is only gmsh-related. If problem is still unresolved, then you should consult to gmsh forum.
As stated by other users, this is a pure GMSH question.
I would google this error message:
and note that the appropriate conda package for GMSH is: python-gmsh: Python Gmsh | Anaconda.org
Thank you very much for your help, it is very helpful to me!
Yes, this is very inspiring to me, I am trying to solve the problem, thank you!
