Hi, can i make mesh like that with mesh functions in fenics?
Please note that you have not specified if you are using legacy fenics or fenicsx.
As it seems like you already have the triangulation for this grid, you could simply read it in manually in DOLFINx, as show in Mesh generation — FEniCS Tutorial @ Sorbonne
Consider submesh. But this will not be optimal unless you redistribute the cells.
n_ele = 16
if n_ele % 2:
raise NotImplementedError("n_ele must be even")
mesh = dolfinx.mesh.create_unit_square(
MPI.COMM_WORLD, n_ele, n_ele,
diagonal=dolfinx.mesh.DiagonalType.left_right)
tol = 1e-9
discard_cells = dolfinx.mesh.locate_entities(
mesh, mesh.topology.dim,
lambda x: (x[0] >= 0.5 - tol) & (x[1] <= 0.5 + tol))
keep_cells = np.arange(mesh.topology.index_map(mesh.topology.dim).size_local,
dtype=np.int32)
keep_cells = np.setdiff1d(keep_cells, discard_cells)
mesh, _, _, _ = dolfinx.mesh.create_submesh(
mesh, mesh.topology.dim, keep_cells)
