Hello ! I’m running the legacy 2019 fenics code, and am trying to get a code snipped I found to work. I’ll be hones, I have very little experience with fenics. I’m trying to do the calculations on two volumes (a cube inside a cube) with a single boundary between them, which I made and exported from gmsh. I would appreciate any help you could give me … thank you kindly!
Code:
#Import geometry
xml_file="text.xml"
mesh=Mesh(xml_file)
cd=MeshFunction("size_t",mesh,"text_physical_region.xml")
fd=MeshFunction("size_t",mesh,"text_facet_region.xml")
# Function space of the mesh
# Set up test and trail functions
# Bilinear form
mu_r=1.0
mu_m=2.0
dx = Measure("dx", subdomain_data=cd)
a = inner(grad(u), grad(v))*dx(62) + mu_m*inner(grad(u), grad(v))*dx(63)
# Air domain +Hard magnetic domain
#magnetization vector
M_0=Constant((0.,0.,1.))
# Linear form
L = inner(M_0, grad(v))*dx(63)
# Create Dirichlet boundary condition
bc = DirichletBC(V, Constant(0.0), fd,61)
# Compute solution
solve(a == L, u, bc, solver_parameters={'linear_solver': 'gmres'})
# Save solution to file in VTK format
vtkfile = File('solution.pvd')
vtkfile << u
Make sure that the code is formatted with 3x` encapsulation, i.e.
```python
def f(x):
return x
This makes sure that the code can be copy-pasted by others.
Supply the error message, including the traceback, i.e.:
fenics@c6fbe02d4e9a:/root/shared$ python3 mwe2.py
File "mwe2.py", line 40, in <module>
File "/usr/local/lib/python3.6/dist-packages/dolfin/fem/solving.py", line 233, in solve
File "/usr/local/lib/python3.6/dist-packages/dolfin/fem/solving.py", line 247, in _solve_varproblem
= _extract_args(*args, **kwargs)
File "/usr/local/lib/python3.6/dist-packages/dolfin/fem/solving.py", line 383, in _extract_args
u = _extract_u(args[1])
File "/usr/local/lib/python3.6/dist-packages/dolfin/fem/solving.py", line 436, in _extract_u
raise RuntimeError("Expecting second argument to be a Function.")
RuntimeError: Expecting second argument to be a Function.
Make sure that the example can be reproduced by others. A good idea is to use one of the built in meshes for this, as we do not have access to the following xml files:
To your question;
Note that you have defined your variational form with a TrialFunction
This indicates to DOLFIN that you want to assemble a matrix.
As the output of
Thank you very much, that seems to have solved it ! and thank you for the explanations on how to post better questions, I will try to do a better job in future.
