Openmp in fenics
Hi, Dear fenics users:
I wonder how can I enable the multi-threading in the fenics? parameters[“num_threads”] does not work, export OMP_NUM_THREADS=8 does not speed up either.
Any advise would be appreciated!
Use of concurrent threads has been removed from DOLFIN. Parallelism is provided through separate MPI processes. Looks like you’ve found a legacy option which is no longer supported.
