Using num_threads in fenics
Dear sir,
how to speed up the running time/parallelization in feincs by using fenics parameters. I tried with the following code but it is showing an error.
parameters["allow_extrapolation"] = True # for mesh mappings
parameters["form_compiler"]["optimize"] = True # optimise compiler pg 167 fenics boo
  File "try.py", line 8, in <module>
    parameters["num_threads"] = 6 # invoke multi-thread parallel support
RuntimeError: Parameter num_threads not found in Parameters object
error is
sorry sir I missed first line of code
Concurrent processing with threads was removed a long time ago, circa 2014 I believe.
Parallelism in FEniCS is achieved by partitioning problems to MPI processes. E.g. running a script in the following manner will employ 4 MPI processes:
mpirun -np 4 python3 demo_poisson.py
Thank you for your reply.
I used
mpirun -np 4 python3 demo_poisson.py  to run the code but its showing in different output with four processor
 Process 0: Solving linear variational problem.
Process 3: Solving linear variational problem.
Process 1: Solving linear variational problem.
Process 2: Solving linear variational problem.
That is the expected behavior. When you run in parallel, every task is divided between processes, so the output shows which task each process is doing. If you don’t want to see a lot of outputs, you can use something like this at the begining of your code:
# MPI parameters
comm = MPI.comm_world
rank = MPI.rank(comm)
# Sets log level for parallel runs
set_log_level(LogLevel.ERROR)
if rank == 0: set_log_level(LogLevel.PROGRESS)
For further information about the log level see this old but very useful post.
no change in output even after using provided code above. still am getting four output.
