I am working on a code that is similar to the Cahn-Hillard tutorial. At each time iteration when the solution is obtain:
while (t < T):
u0.vector()[:] = u.vector()
solver.solve(problem, u.vector())
file << (u.split()[0], t)
So u is a solution of two coupled equations, instead of exporting u, I wanted to do some operation on the solution and output that result. For example, if I want to do result = u12 + u22, where u1 and u2 are the the part of u (solution the the two couple equations respectively), and “result” is the output I want to send to .pvd file to use in Paraview, how should I make this work?
I tried this:
a, b =u.split()
result = a2 + b2
file << (posit)
And the error was on the last line mentioning that ‘Sum’ object has no attribute ‘_cpp_object’
There was a “typo” on my second attempt,
result = ( a 2 ).vector() + ( b 2 ).vector() somehow the stars for powers didn’t show, should be result = ( a star star 2 ).vector() + ( b star star 2 ).vector()
I also made a couple more attempts like, using dot() and inner() to replace power of 2, didn’t work. I also tried to project the operation to the same function space, it says something like finite element object has no attribute mesh
If you want to post code blocks as you did, write triple back ticks ``` before and after the code. Inline code works with single back ticks, `.
Anyways, you want to assign the result of your computation to a new Function. Your result (if **2 worked) would only be a vector, without function space information etc.
See what @dokken wrote. You have to define that result function.
For instance, if u is a function of FunctionSpace V, you could do so with
a, b = u.split(deepcopy=True) # note deepcopy
result = Function(a.function_space())
c = a.vector()*a.vector() + b.vector()*b.vector()
result.vector()[:] = c
