Parallel code for extraction of submatrices
I am running in parallel for the solution of some PDE. After this, I have on every process a matrix, which I would like to partition accordingly for further use. See the code below to understand better.
import dolfinx, ufl
from ufl import inner, grad, dx
comm = MPI.COMM_WORLD
Lx, Ly = 1, 1
px, py = 2, 2
N = 50
assert comm.size == px * py
dim = 2
mesh, rank_bounds, primal_indices = partition_domain(comm, px, py, Lx, Ly, N, dim)
V = dolfinx.fem.VectorFunctionSpace(mesh, ('CG', 1))
E = 1
nu = 0.3
mu = E / (2.0 * (1.0 + nu))
lmbda = E * nu / ((1.0 + nu) * (1.0 - 2.0 * nu))
def epsilon(v):
    return ufl.sym(grad(v))
def sigma(v):
    return 2.0 * mu * epsilon(v) + lmbda * ufl.tr(epsilon(v)) * ufl.Identity(len(v))
boundaries = [(1, lambda x: np.isclose(x[0], 0)),
                       (2, lambda x: np.isclose(x[0], px*Lx))]
      facets = dolfinx.mesh.locate_entities(mesh, mesh.topology.dim-1, locator)
      facet_indices.append(facets)
facet_tag = dolfinx.mesh.meshtags(mesh, mesh.topology.dim-1, facet_indices[sorted_facets], facet_markers[sorted_facets])
ds = ufl.ds(subdomain_data=facet_tag, domain=mesh)
t = ufl.as_vector([0.0, -1.0])
a = inner(sigma(u), grad(v))
L = inner(t, v)
u_D = dolfinx.fem.Function(V)
facets = facet_tag.find(1)
clamped_edge = dolfinx.fem.locate_dofs_topological(V, mesh.topology.dim-1, facets)
zero_bc = dolfinx.fem.dirichletbc(np.array((0,) * mesh.geometry.dim, dtype=np.double), clamped_edge, V)
A = dolfinx.fem.petsc.assemble_matrix(dolfinx.fem.form(a * dx), bcs=[zero_bc])
## split dofs into some partition
A_ = PETSc.Mat().createAIJ(#some size#, comm=PETSc.COMM_SELF).setUp()
A_.setValues(range(A_.getSizes()[0][0]), range(A_.getSizes()[1][0]), A.getValues(.., ..))
However, the code below remains stuck on the setting of the values for the submatrix Arr. Any help is appreciated. If I stick to the global communicator then the code goes through but throws mistakes because of wrong sizes.
In the MPI.COMM_SELF case, I get the following error
Loguru caught a signal: SIGSEGV
Stack trace:
22      0x564b2db39245 _start + 37
21      0x7f4238b6ce40 __libc_start_main + 128
20      0x7f4238b6cd90 /lib/x86_64-linux-gnu/libc.so.6(+0x29d90) [0x7f4238b6cd90]
19      0x564b2db3934d Py_BytesMain + 45
18      0x564b2db630ae Py_RunMain + 702
17      0x564b2db71e33 _PyRun_AnyFileObject + 67
16      0x564b2db72138 _PyRun_SimpleFileObject + 424
15      0x564b2db72c55 python3(+0x265c55) [0x564b2db72c55]
14      0x564b2db6bd5b python3(+0x25ed5b) [0x564b2db6bd5b]
13      0x564b2db72f08 python3(+0x265f08) [0x564b2db72f08]
12      0x564b2db46456 PyEval_EvalCode + 134
11      0x564b2da4e766 python3(+0x141766) [0x564b2da4e766]
10      0x564b2da57e39 _PyEval_EvalFrameDefault + 25849
9       0x564b2da5f77c _PyObject_MakeTpCall + 508
8       0x564b2da73639 python3(+0x166639) [0x564b2da73639]
7       0x564b2da5e964 _PyObject_FastCallDictTstate + 196
6       0x564b2da5214a _PyEval_EvalFrameDefault + 2058
5       0x564b2da6a269 python3(+0x15d269) [0x564b2da6a269]
4       0x7f423861ce82 /usr/local/lib/python3.10/dist-packages/petsc4py/lib/linux-gnu-real-32/PETSc.cpython-310-x86_64-linux-gnu.so(+0x244e82) [0x7f423861ce82]
3       0x7f423861b207 /usr/local/lib/python3.10/dist-packages/petsc4py/lib/linux-gnu-real-32/PETSc.cpython-310-x86_64-linux-gnu.so(+0x243207) [0x7f423861b207]
2       0x7f4237468001 MatSetValues + 241
1       0x7f42375b35e4 /usr/local/petsc/linux-gnu-real-32/lib/libpetsc.so.3.17(+0x9195e4) [0x7f42375b35e4]
0       0x7f4238b85520 /lib/x86_64-linux-gnu/libc.so.6(+0x42520) [0x7f4238b85520]
2023-11-16 15:48:38.743 (   2.008s) [main            ]                       :0     FATL| Signal: SIGSEGV
Stack trace:
22      0x560c842b7245 _start + 37
21      0x7f66a59f3e40 __libc_start_main + 128
20      0x7f66a59f3d90 /lib/x86_64-linux-gnu/libc.so.6(+0x29d90) [0x7f66a59f3d90]
19      0x560c842b734d Py_BytesMain + 45
18      0x560c842e10ae Py_RunMain + 702
17      0x560c842efe33 _PyRun_AnyFileObject + 67
16      0x560c842f0138 _PyRun_SimpleFileObject + 424
15      0x560c842f0c55 python3(+0x265c55) [0x560c842f0c55]
14      0x560c842e9d5b python3(+0x25ed5b) [0x560c842e9d5b]
13      0x560c842f0f08 python3(+0x265f08) [0x560c842f0f08]
12      0x560c842c4456 PyEval_EvalCode + 134
11      0x560c841cc766 python3(+0x141766) [0x560c841cc766]
10      0x560c841d5e39 _PyEval_EvalFrameDefault + 25849
9       0x560c841dd77c _PyObject_MakeTpCall + 508
8       0x560c841f1639 python3(+0x166639) [0x560c841f1639]
7       0x560c841dc964 _PyObject_FastCallDictTstate + 196
6       0x560c841d014a _PyEval_EvalFrameDefault + 2058
5       0x560c841e8269 python3(+0x15d269) [0x560c841e8269]
4       0x7f66a54a3e82 /usr/local/lib/python3.10/dist-packages/petsc4py/lib/linux-gnu-real-32/PETSc.cpython-310-x86_64-linux-gnu.so(+0x244e82) [0x7f66a54a3e82]
3       0x7f66a54a2207 /usr/local/lib/python3.10/dist-packages/petsc4py/lib/linux-gnu-real-32/PETSc.cpython-310-x86_64-linux-gnu.so(+0x243207) [0x7f66a54a2207]
2       0x7f66a42ef001 MatSetValues + 241
1       0x7f66a443a5e4 /usr/local/petsc/linux-gnu-real-32/lib/libpetsc.so.3.17(+0x9195e4) [0x7f66a443a5e4]
0       0x7f66a5a0c520 /lib/x86_64-linux-gnu/libc.so.6(+0x42520) [0x7f66a5a0c520]
2023-11-16 15:48:38.743 (   2.015s) [main            ]                       :0     FATL| Signal: SIGSEGV
Stack trace:
22      0x55b79c03d245 _start + 37
21      0x7f396a6b7e40 __libc_start_main + 128
20      0x7f396a6b7d90 /lib/x86_64-linux-gnu/libc.so.6(+0x29d90) [0x7f396a6b7d90]
19      0x55b79c03d34d Py_BytesMain + 45
18      0x55b79c0670ae Py_RunMain + 702
17      0x55b79c075e33 _PyRun_AnyFileObject + 67
16      0x55b79c076138 _PyRun_SimpleFileObject + 424
15      0x55b79c076c55 python3(+0x265c55) [0x55b79c076c55]
14      0x55b79c06fd5b python3(+0x25ed5b) [0x55b79c06fd5b]
13      0x55b79c076f08 python3(+0x265f08) [0x55b79c076f08]
12      0x55b79c04a456 PyEval_EvalCode + 134
11      0x55b79bf52766 python3(+0x141766) [0x55b79bf52766]
10      0x55b79bf5be39 _PyEval_EvalFrameDefault + 25849
9       0x55b79bf6377c _PyObject_MakeTpCall + 508
8       0x55b79bf77639 python3(+0x166639) [0x55b79bf77639]
7       0x55b79bf62964 _PyObject_FastCallDictTstate + 196
6       0x55b79bf5614a _PyEval_EvalFrameDefault + 2058
5       0x55b79bf6e269 python3(+0x15d269) [0x55b79bf6e269]
4       0x7f396a167e82 /usr/local/lib/python3.10/dist-packages/petsc4py/lib/linux-gnu-real-32/PETSc.cpython-310-x86_64-linux-gnu.so(+0x244e82) [0x7f396a167e82]
3       0x7f396a166207 /usr/local/lib/python3.10/dist-packages/petsc4py/lib/linux-gnu-real-32/PETSc.cpython-310-x86_64-linux-gnu.so(+0x243207) [0x7f396a166207]
2       0x7f3968fb3001 MatSetValues + 241
1       0x7f39690fe5e4 /usr/local/petsc/linux-gnu-real-32/lib/libpetsc.so.3.17(+0x9195e4) [0x7f39690fe5e4]
0       0x7f396a6d0520 /lib/x86_64-linux-gnu/libc.so.6(+0x42520) [0x7f396a6d0520]
2023-11-16 15:48:38.744 (   2.030s) [main            ]                       :0     FATL| Signal: SIGSEGV
Stack trace:
22      0x55563f31a245 _start + 37
21      0x7f50d9d9fe40 __libc_start_main + 128
20      0x7f50d9d9fd90 /lib/x86_64-linux-gnu/libc.so.6(+0x29d90) [0x7f50d9d9fd90]
19      0x55563f31a34d Py_BytesMain + 45
18      0x55563f3440ae Py_RunMain + 702
17      0x55563f352e33 _PyRun_AnyFileObject + 67
16      0x55563f353138 _PyRun_SimpleFileObject + 424
15      0x55563f353c55 python3(+0x265c55) [0x55563f353c55]
14      0x55563f34cd5b python3(+0x25ed5b) [0x55563f34cd5b]
13      0x55563f353f08 python3(+0x265f08) [0x55563f353f08]
12      0x55563f327456 PyEval_EvalCode + 134
11      0x55563f22f766 python3(+0x141766) [0x55563f22f766]
10      0x55563f238e39 _PyEval_EvalFrameDefault + 25849
9       0x55563f24077c _PyObject_MakeTpCall + 508
8       0x55563f254639 python3(+0x166639) [0x55563f254639]
7       0x55563f23f964 _PyObject_FastCallDictTstate + 196
6       0x55563f23314a _PyEval_EvalFrameDefault + 2058
5       0x55563f24b269 python3(+0x15d269) [0x55563f24b269]
4       0x7f50d984fe82 /usr/local/lib/python3.10/dist-packages/petsc4py/lib/linux-gnu-real-32/PETSc.cpython-310-x86_64-linux-gnu.so(+0x244e82) [0x7f50d984fe82]
3       0x7f50d984e207 /usr/local/lib/python3.10/dist-packages/petsc4py/lib/linux-gnu-real-32/PETSc.cpython-310-x86_64-linux-gnu.so(+0x243207) [0x7f50d984e207]
2       0x7f50d869b001 MatSetValues + 241
1       0x7f50d87e65e4 /usr/local/petsc/linux-gnu-real-32/lib/libpetsc.so.3.17(+0x9195e4) [0x7f50d87e65e4]
0       0x7f50d9db8520 /lib/x86_64-linux-gnu/libc.so.6(+0x42520) [0x7f50d9db8520]
2023-11-16 15:48:38.743 (   2.023s) [main            ]                       :0     FATL| Signal: SIGSEGV
=   BAD TERMINATION OF ONE OF YOUR APPLICATION PROCESSES
=   PID 138 RUNNING AT b0b84aa4a907
=   EXIT CODE: 11
=   CLEANING UP REMAINING PROCESSES
=   YOU CAN IGNORE THE BELOW CLEANUP MESSAGES
YOUR APPLICATION TERMINATED WITH THE EXIT STRING: Segmentation fault (signal 11)
This typically refers to a problem with your application.
Please see the FAQ page for debugging suggestions
