Part 2- Trying to disguise sphere with the Navier-Stokes equations (State-Steady)
Previously solves the Navier-Stokes equations unsteady 3D [1]. Now, I need to solve the equations in steady state, I have implemented the following code, helping me with the following tutorials: [3D problem (sphere) Navier-Stokes], [Tutorial 02: Navier-Stokes problem], [Stokes equations using Taylor-Hood elements]
##NVSTK-SS-3D
import typing
from dolfinx.cpp.mesh import CellType
from dolfinx.io import (XDMFFile)
from dolfinx.fem import (Constant, Function, )
from dolfinx.fem.petsc import (apply_lifting, assemble_matrix, set_bc, assemble_vector, create_vector)
from ufl import (FacetNormal, Identity, Measure, TestFunction, TrialFunction,
                 as_vector, div, dot, ds, dx, inner, lhs, grad, nabla_grad, rhs, sym)
import basix
print(f"DOLFINx version: {dolfinx.__version__} is installed")
#Mesh
filename="sphere-4.xdmf"
with dolfinx.io.XDMFFile(MPI.COMM_WORLD, "sphere-4.xdmf", "r") as xdmf:
#Parameters
eps=1e-14
nu=0.01
#Boundaries
def Inflow(x):
    return np.abs(x[0] - 0.) < eps
def Outflow(x):
    return np.abs(x[0] - 10.0) < eps
def Walls(x):
    result = np.logical_or(np.abs(x[1] + 0.) < eps, np.abs(x[1] - 5.) < eps)
    result2 = np.logical_or(np.abs(x[2] - 0.) < eps, np.abs(x[2] - 5.) < eps)
    return np.logical_or(result, result2)
def Sphere(x):
    result = np.logical_and(x[0] > 2.0 - eps, x[0] < 4.0 + eps)
    result2 = np.logical_and(x[1] > 2.0 - eps, x[1] < 4.0 + eps)
    result3 = np.logical_and(x[2] > 2.0 - eps, x[2] < 4.0 + eps)
    return np.logical_and(np.logical_and(result, result2), result3)
def inflow_profile(x):
    values = np.zeros((3, x.shape[1]), dtype=PETSc.ScalarType)
    values[0, :] = 1.0
    return values
import dolfinx.fem as fem
V_element = basix.ufl.element("Lagrange", mesh.basix_cell(), 2, shape=(mesh.geometry.dim, ))
Q_element = basix.ufl.element("Lagrange", mesh.basix_cell(), 1)
def run_monolithic() -> dolfinx.fem.Function:
    """Run standard formulation using a mixed function space."""
    # Function spaces
    W_element = basix.ufl.mixed_element([V_element, Q_element])
    W = dolfinx.fem.functionspace(mesh, W_element)
    # Test and trial functions: monolithic
    vq = ufl.TestFunction(W)
    (v, q) = ufl.split(vq)
    dup = ufl.TrialFunction(W)
    up = dolfinx.fem.Function(W)
    (u, p) = ufl.split(up)
    print('After functions test and trial')
    # Variational forms
    F = (nu * ufl.inner(ufl.grad(u), ufl.grad(v)) * ufl.dx
         + ufl.inner(ufl.grad(u) * u, v) * ufl.dx
         - ufl.inner(p, ufl.div(v)) * ufl.dx
         + ufl.inner(ufl.div(u), q) * ufl.dx)
    J = ufl.derivative(F, up, dup)
    print('After Variational forms')
    # Boundary conditions
    W0 = W.sub(0)
    V, _ = W0.collapse()
    u_in = fem.Function(V)
    u_in.interpolate(inflow_profile)
    u_zero = fem.Function(V)
    u_zero.x.array[:] = 0
    #p_zero = fem.Function(Q)
    #p_zero.x.array[:] = 0
    inflow_boundary_dofs = fem.locate_dofs_geometrical(V, Inflow)
    #outflow_boundary_dofs = fem.locate_dofs_geometrical(Q, Outflow)
    walls_boundary_dofs = fem.locate_dofs_geometrical(V, Walls)
    sphere_boundary_dofs = fem.locate_dofs_geometrical(V, Sphere)
    bcu_inflow = fem.dirichletbc(u_in, inflow_boundary_dofs)
    #bcp_outflow = fem.dirichletbc(p_zero, outflow_boundary_dofs)
    bcu_walls = fem.dirichletbc(u_zero, walls_boundary_dofs)
    bcu_sphere = fem.dirichletbc(u_zero, sphere_boundary_dofs)
    bc = [bcu_inflow, bcu_walls, bcu_sphere]
    #bcp = [bcp_outflow]
    print('After boundaries')
    # Class for interfacing with SNES
    class NavierStokesProblem:
        """Define a nonlinear problem, interfacing with SNES."""
        def __init__(  # type: ignore[no-any-unimported]
            self, F: ufl.Form, J: ufl.Form, solution: dolfinx.fem.Function,
            bcs: list[dolfinx.fem.DirichletBC], P: typing.Optional[ufl.Form] = None
        ) -> None:
            self._F = dolfinx.fem.form(F)
            self._J = dolfinx.fem.form(J)
            self._obj_vec = dolfinx.fem.petsc.create_vector(self._F)
            self._solution = solution
            self._bcs = bcs
            self._P = P
            print('ending def init')
        def create_snes_solution(self) ->PETSc.Vec:  # type: ignore[no-any-unimported]
            Create a petsc4py.PETSc.Vec to be passed to petsc4py.PETSc.SNES.solve.
            The returned vector will be initialized with the initial guess provided in `self._solution`.
            x = self._solution.x.petsc_vec.copy()
            with x.localForm() as _x, self._solution.x.petsc_vec.localForm() as _solution:
                _x[:] = _solution
            print('ending def create_snes_solution')
            return x
        def update_solution(self, x: PETSc.Vec) -> None:  # type: ignore[no-any-unimported]
            """Update `self._solution` with data in `x`."""
            x.ghostUpdate(addv=PETSc.InsertMode.INSERT, mode=PETSc.ScatterMode.FORWARD)
                _solution[:] = _x
            print('ending def update_solution')
        def obj(  # type: ignore[no-any-unimported]
            self, snes: PETSc.SNES, x: PETSc.Vec
        ) -> np.float64:
            """Compute the norm of the residual."""
            self.F(snes, x, self._obj_vec)
            print('ending obj')
            return self._obj_vec.norm()  # type: ignore[no-any-return]
        def F(  # type: ignore[no-any-unimported]
            self, snes: PETSc.SNES, x: PETSc.Vec, F_vec: PETSc.Vec
        ) -> None:
            """Assemble the residual."""
            self.update_solution(x)
            with F_vec.localForm() as F_vec_local:
                F_vec_local.set(0.0)
            dolfinx.fem.petsc.assemble_vector(F_vec, self._F)
            dolfinx.fem.petsc.apply_lifting(F_vec, [self._J], [self._bcs], x0=[x], scale=-1.0)
            F_vec.ghostUpdate(addv=PETSc.InsertMode.ADD, mode=PETSc.ScatterMode.REVERSE)
            dolfinx.fem.petsc.set_bc(F_vec, self._bcs, x, -1.0)
            print('ending def F')
        def J(  # type: ignore[no-any-unimported]
            self, snes: PETSc.SNES, x: PETSc.Vec, J_mat: PETSc.Mat,
            P_mat: PETSc.Mat
        ) -> None:
            """Assemble the jacobian."""
            J_mat.zeroEntries()
            dolfinx.fem.petsc.assemble_matrix(  # type: ignore[misc]
                J_mat, self._J, self._bcs, diagonal=1.0)  # type: ignore[arg-type]
            J_mat.assemble()
            if self._P is not None:
                P_mat.zeroEntries()
                    P_mat, self._P, self._bcs, diagonal=1.0)  # type: ignore[arg-type]
                P_mat.assemble()
            print('ending def J')
    # Create problem
    problem = NavierStokesProblem(F, J, up, bc)
    F_vec = dolfinx.fem.petsc.create_vector(problem._F)
    J_mat = dolfinx.fem.petsc.create_matrix(problem._J)
    # Solve
    snes = PETSc.SNES().create(mesh.comm)
    snes.setTolerances(max_it=20)
    snes.getKSP().setType("preonly")
    snes.getKSP().getPC().setType("lu")
    snes.getKSP().getPC().setFactorSolverType("mumps")
    snes.setObjective(problem.obj)
    snes.setFunction(problem.F, F_vec)
    snes.setJacobian(problem.J, J=J_mat, P=None)
    snes.setMonitor(lambda _, it, residual: print(it, residual))
    up_copy = problem.create_snes_solution()
    snes.solve(None, up_copy)
    problem.update_solution(up_copy)  # TODO can this be safely removed?
    up_copy.destroy()
    snes.destroy()
    return up
up_m = run_monolithic()
(u_m, p_m) = (up_m.sub(0).collapse(), up_m.sub(1).collapse())
with XDMFFile(MPI.COMM_WORLD, "out_stokes/velocity.xdmf", "w") as ufile_xdmf:
    u_m.x.scatter_forward()
    P1 = element("Lagrange", mesh.basix_cell(), 1, shape=(mesh.geometry.dim,))
    u1 = Function(functionspace(mesh, P1))
    u1.interpolate(u_m)
    ufile_xdmf.write_mesh(mesh)
    ufile_xdmf.write_function(u1)
with XDMFFile(MPI.COMM_WORLD, "out_stokes/pressure.xdmf", "w") as pfile_xdmf:
    p_m.x.scatter_forward()
    pfile_xdmf.write_mesh(mesh)
    pfile_xdmf.write_function(p_m)
However, I don’t get any results as seen in the images:
In the following link you can obtain all the files that were used for the simulation [Drive]
Could you please advise me on what went wrong and I can’t see any results. Please and thank you very much
The filenames in your drive are not correct, as inspecting sphere-4 yields:
<?xml version="1.0"?>
<Xdmf Version="3.0">
  <Domain>
    <Grid Name="Grid">
      <Geometry GeometryType="XYZ">
        <DataItem DataType="Float" Dimensions="92988 3" Format="HDF" Precision="4">sphere-2.h5:/data0</DataItem>
      </Geometry>
      <Topology TopologyType="Tetrahedron" NumberOfElements="531599" NodesPerElement="4">
        <DataItem DataType="Int" Dimensions="531599 4" Format="HDF" Precision="4">sphere-2.h5:/data1</DataItem>
      </Topology>
    </Grid>
where sphere-2.h5 is not defined.
Secondly, have you tried using the Newton-solver of DOLFINx (it would make the code way easier to parse, and highlight if it is the snes solver that is the issue)?
Thirdly, please clean up your code, there are tons of unused imports and commented out code.
Thank you for your reply. I still haven’t found a solution, so I was thinking of creating the mesh within the same code and using Newton’s solver.
That would be a fist step towards reproducibility
Good day, Dokken. I need to ask you something related to this same topic. I have already managed to obtain consistent results, created a good mesh, refined the mesh, and set up the Newton Solver. However, the only thing that separates me from my goal is that when the kinematic viscosity is very low, such as that of water or air, I get strange results. I read in one of your previous responses that you mentioned the need to scale the equation. So, I followed the process to scale, and then I obtained a variational form almost identical to the image (without the time dependence). But now, for flows with very high Reynolds numbers, the solutions behave strangely, and I can’t simulate a box where air enters and flows around the object. So, my question is: How do I know which units I am applying, or is there an additional step? Because I need to compare the solutions with Ansys and COMSOL. Regards.
# Variational forms
#Problem nu
    F = (nu * ufl.inner(ufl.grad(u),...
Scale Equation
If the Reynolds number is very large there may be no point in solving the steady equation, as the physical phenomenon is unsteady.
