Is there a way in Fenics to compute a partial integral? I need \rho(x)=\int f(x,y)dy, but I get a TypeError: “unsupported operand type(s) for *: ‘Expression’ and ‘Form’”. The problem is that the equation for c only involves the variable x but depends on \rho and not on f. In the following implementation I get the TypeError.
dolfin import *
# Sub domain for Dirichlet boundary condition
class NofluxBoundary(SubDomain):
return bool((x[0] < DOLFIN_EPS or x[0] > (1.0 - DOLFIN_EPS)) \
and on_boundary)
# Sub domain for Periodic boundary conditional
class PeriodicBoundaryC(SubDomain):
# Left boundary is "target domain" G
return bool(x[1] < DOLFIN_EPS and x[1] > -DOLFIN_EPS and on_boundary)
# Map right boundary (H) to left boundary (G)
def map(self, x, y):
y[1] = x[1] - 1.0
y[0] = x[0]
# Create mesh and finite element
mesh = UnitSquareMesh(32, 32)
pbc = PeriodicBoundaryC()
nofluxb = NofluxBoundary()
pb = PeriodicBoundary()
V = FunctionSpace(mesh, 'CG', 1, constrained_domain=pbc)
Q = FiniteElement("CG", triangle, 1)
domains = MeshFunction("size_t", mesh, mesh.topology().dim())
domains.set_all(0)
boundaries = MeshFunction("size_t", mesh, mesh.topology().dim()-1)
boundaries.set_all(0)
pb.mark(boundaries, 1)
nofluxb.mark(boundaries, 2)
W = FunctionSpace(mesh,MixedElement([Q,Q]), constrained_domain=pbc)
#system
u = Function(W)
u.interpolate(Expression(("cos(0.5*pi*x[0])*cos(0.5*pi*x[0])", "cos(0.5*pi*x[0])*cos(0.5*pi*x[0])"), degree=2))
f, c = split(u)
v, w = TestFunction(W)
r = Expression('x[0]',degree=2)
cospsi = Expression('cos(2*pi*x[1])',degree=2)
sinpsi = Expression('sin(2*pi*x[1])',degree=2)
#system
B = r*cospsi*grad(f)[0]*v*dx - sinpsi*grad(f)[1]*v*dx \
+ r*sinpsi*grad(c)[0]*f*grad(v)[1]*dx \
- r*grad(f)[0]*v*ds(1) \
+ r*grad(c)[0]*grad(w)[0]*dx -r*(f*dx(1))*w*dx - \
- grad(c)[0]*w*ds(1)
solve(B == 0, f)
