Hi, I’m currently creating a 3D grid with three materials, top, middle and bottom. In my code, if it seems impossible to separate three materials cleanly, because it requires quite a lot of grids, is there a better solution?For example, create a grid in different areas.
length = 1
width = 0.5
height = 1
radius = 0.2
domain_1 = Box(Point(0, 0, 0), Point(length, width, 0.7))
domain_2 = Box(Point(0, 0, 0.7), Point(length, width, 0.8))
domain_3 = Box(Point(0, 0, 0.8), Point(length, width, height))
domain = domain_1 + domain_2 + domain_3
cylinder_hole = Cylinder(Point(1, 0, 0.5), Point(1, 0.5, 0.5), radius, radius)
domain_with_hole = domain - cylinder_hole
mesh = generate_mesh(domain_with_hole, 50)
tol = 1E-14
class Omega_0(SubDomain):
return x[2] <= 0.7 + tol
class Omega_1(SubDomain):
return 0.8 + tol >= x[2] >= 0.7 - tol
class Omega_2(SubDomain):
return 1 + tol >= x[2] >= 0.8 - tol
materials = MeshFunction('size_t', mesh, mesh.topology().dim())
subdomain_0 = Omega_0()
subdomain_1 = Omega_1()
subdomain_2 = Omega_2()
subdomain_0.mark(materials, 0)
subdomain_1.mark(materials, 1)
subdomain_2.mark(materials, 2)
print("Number of vertices: ", mesh.num_vertices())
print("Number of cells: ", mesh.num_cells())
#Save materials to VTK file
vtkfile = File("mesh.pvd")
vtkfile << mesh
# Save materials to VTK file
vtkfile = File("materials.pvd")
vtkfile << materials
