Periodic Boundary Condition for Elasticity Equation
Dear FEniCS Users,
I do hope you are doing great, and Happy Canada Day.
I would like to implement the periodic boundary condition for a simple 2D elasticity equation, then calculating the averaged-volume stress and compare it with the analytical solution. A minimal of my code implementation has been given below for your consideration:
        return bool((near(x[0], 0) or near(x[1], 0)) and on_boundary)
    def map(self, x, y):
        if near(x[0], 1) and near(x[1], 1):
            y[0] = x[0] - 1.0
            y[1] = x[1] - 1.0
        elif near(x[0], 1):
            y[0] = x[0] - 1.0
            y[1] = x[1]
            y[0] = x[0]
            y[1] = x[1] - 1.0
# Create the periodic boundary condition
periodic_bc = PeriodicBoundary()
W = 1.0
nFEx = 1
nFEy = nFEx
NFE = nFEx*nFEy
NFE *= 4 #if crossed, else *2
E=1.0
nu = 0.0
mu = Constant(E/(2*(1+nu)))
lambda_ = Constant(E*nu/((1+nu)*(1-2*nu)))
mesh = RectangleMesh(Point(0.0, 0.0), Point(W, W), nFEx, nFEy, "crossed")
V = VectorFunctionSpace(mesh, 'P', 1, constrained_domain=periodic_bc)
subdomains = MeshFunction("size_t", mesh, mesh.topology().dim())
subdomains.set_all(0)
bc = []
boundaries = MeshFunction("size_t", mesh, 1)
boundaries.set_all(0)
ds = Measure("ds", domain = mesh, subdomain_data=boundaries)
dx = Measure("dx", domain = mesh)
def point(x, on_boundary):
    tol = DOLFIN_EPS
    return (abs(x[0]) < tol) and (abs(x[1]) < tol)
# Define strain and stress
#return sym(nabla_grad(u))
def sigma(u):
    return lambda_*div(u)*Identity(d) + 2*mu*epsilon(u)
d = u.geometric_dimension() # space dimension
f = Constant((0, 0))
L = dot(f, v)*dx
# Define time stepping parameters
t = 1.0
num_steps = 1
dt = t/num_steps
for n in range(num_steps):
    # Update BCs
    bc.append(DirichletBC(V.sub(0), Constant((0.)), point, method="pointwise"))
    bc.append(DirichletBC(V.sub(1), Constant((0.)), point, method="pointwise"))
    # Solve variational problem
    solve(a == L, u, bc)
    sigmaTensor = project(sigma(u),S)
    epsTensor = project(epsilon(u),S)
    # Compute volume averages
    for i in range(4):
        sigmaAVG[n+1,i] = assemble(sigmaTensor.sub(i)*dx)/W
        epsAVG[n+1,i] = assemble(epsTensor.sub(i)*dx)/W
    sigmaGP[n+1] = sigmaTensor.vector().get_local().reshape(-1,4)
    epsGP[n+1] = epsTensor.vector().get_local().reshape(-1,4)
    # sig
    # Write result file
    xdmffile.write(u,n)
    # # Update time
However, the results are not correct in terms of using periodic boundary conditions. Any help regarding this would be highly appreciated.
Regards,
Benhour
Refer to Periodic BC Problem in 3D - #6 by conpierce8.
It looks like you need to modify your inside function so that it returns False for the points marked 2 and 4 in my illustrations, and that you need to add a fourth condition to map which handles all points that are not part of the periodic boundary.
