Periodic boundary condition not giving periodic solution
Hello All,
I am trying to solve the following non linear equation with Periodic boundary condition.
u" = u + 25/(1+exp(u)) on x ∈ [0, 2*pi].
I want the solution to be periodic with periodicity pi. Here is the code for the same
L = 2*np.pi
c0 = 1
Pe = 25
D = 1
gamma = 1
l = L/(2*np.pi)
n = (l**2)*gamma
U = 25/l
stress_const = U*np.sqrt(gamma*n)
mesh_size = 1000
mesh = IntervalMesh(mesh_size, 0, L)
plot(mesh)
        return bool(x[0] > -DOLFIN_EPS and x[0] <= L+DOLFIN_EPS)
    def map(self, x, y):
        y[0] = x[0] - L/2
pbc = PeriodicBoundary()
V = FunctionSpace(mesh, "CG", 1, constrained_domain=pbc)
u = project(Constant(2), V)
F = dot(grad(u), grad(v))*dx - (1/l**2)*u*v*dx - (1/(D*n))*stress_const*(1 - ((exp(u)/(1+exp(u)))))*v*dx
J = derivative(F,u)
problem = NonlinearVariationalProblem(F, u, J=J)
stype = 'newton'
solver.parameters['nonlinear_solver']=stype
sprms = solver.parameters[stype+'_solver']
sprms['maximum_iterations'] = 10000
solver.solve()
Please help me figure out the issue
You should just solve your problem in the domain [0,\pi] if your problem is periodic, i.e.
L = 2*np.pi
c0 = 1
Pe = 25
D = 1
gamma = 1
l = L/(2*np.pi)
n = (l**2)*gamma
U = 25/l
mesh_size = 1000
mesh = IntervalMesh(mesh_size, 0, np.pi)
        """Left boundary"""
        return near(x[0], 0)
        """ map from right to left boundary"""
        y[0] = x[0] - np.pi
J = derivative(F,u)
stype = 'newton'
solver.solve()
File("u.pvd") << u
You should just solve on the half interval, as dolfin relies on the mesh spacing macthing your mapping perfectly, which is really hard when you use numbers such as pi to describe its length.
I don’t think the domain necessarily needs to be [0,\pi] explicitly. I think the problem is more that
y[0] = x[0] - L/2
was being used instead of
y[0] = x[0] - L
when the domain was defined as [0,L]. Perhaps the domain should be [0,L/2].
(of course, L/2=\pi so it’s an equivalent resolution)
Thank you for your valuable input @dokken and @dparsons. I just have one question.
In the code you have mapped left boundary to the right boundary. Shouldn’t we map the a period of the function to the domain?
I mean something like this
        y[0] = x[0] - L/2
Where L is the domain.
I dont understand why you would do that. You are saying that your solution is periodic, that means that any point x\in[0,\pi] maps to y=x+pi\in[\pi,2\pi]. This means that you only need to solve an equation on [0,\pi] but that u(0)=u(\pi)
Thanks a lot for the clarification. I misunderstood the implementation of PBC in fenics which led to this confusion.
