Hi everybody,
I’m trying to generate highly sparse matrix for my eigenvalue problem. My script is running perfectly for serial case. Furthermore, it is also running okay up to 4 cores.
However when I try -np>4, e.g. [mpirun -np 6 python3 mwe.py], it throws an error;
ValueError: size(I) is 1131, expected 905
File "PETSc/petscmat.pxi", line 961, in petsc4py.PETSc.matsetvalues_csr
File "PETSc/petscmat.pxi", line 923, in petsc4py.PETSc.matsetvalues_ijv
ValueError: size(I) is 1131, expected 871
ValueError: size(I) is 1131, expected 889
ValueError: size(I) is 1131, expected 907
ValueError: size(I) is 1131, expected 891
Here is my MWE:
import dolfin as dolf
import time
start_time = time.time()
mesh = dolf.Mesh()
with dolf.XDMFFile('rijke.xdmf') as infile:
infile.read(mesh)
degree = 2
CG = dolf.FiniteElement('CG', mesh.ufl_cell(), degree)
W = dolf.FunctionSpace(mesh, dolf.MixedElement([CG, CG]))
function_space = W
global_size = function_space.dim()
istart, iend = function_space.dofmap().ownership_range()
local_size = iend - istart # local size
D_kj = dict()
for k in range(2):
for j in range(2):
row = [1019, 1019, 1019, 1029, 1029, 1029, 1031, 1031, 1031, 1033, 1033,
1033, 1035, 1035, 1035, 1041, 1041, 1041, 1043, 1043, 1043, 1045,
1045, 1045, 1047, 1047, 1047, 1049, 1049, 1049, 1051, 1051, 1051,
1053, 1053, 1053, 1055, 1055, 1055, 1057, 1057, 1057, 1059, 1059,
1059, 1061, 1061, 1061, 1063, 1063, 1063, 1065, 1065, 1065, 1067,
1067, 1067, 1069, 1069, 1069, 1071, 1071, 1071, 1073, 1073, 1073,
1075, 1075, 1075, 1077, 1077, 1077, 1079, 1079, 1079, 1081, 1081,
1081, 1083, 1083, 1083, 1085, 1085, 1085, 1087, 1087, 1087, 1089,
1089, 1089, 1091, 1091, 1091, 1093, 1093, 1093, 1095, 1095, 1095,
1097, 1097, 1097, 1099, 1099, 1099, 1101, 1101, 1101, 1103, 1103,
1103, 1105, 1105, 1105, 1107, 1107, 1107, 1113, 1113, 1113, 1115,
1115, 1115, 1117, 1117, 1117, 1119, 1119, 1119, 1129, 1129, 1129]
col = [1163, 1151, 1149, 1163, 1151, 1149, 1163, 1151, 1149, 1163, 1151,
1149, 1163, 1151, 1149, 1149, 1163, 1151, 1163, 1151, 1149, 1163,
1151, 1149, 1163, 1151, 1149, 1149, 1163, 1151, 1149, 1151, 1163,
1149, 1151, 1149, 1163, 1163, 1151, 1149, 1163, 1151, 1149, 1151,
1163, 1149, 1163, 1151, 1149, 1151, 1149, 1163, 1151, 1149, 1163,
1163, 1149, 1163, 1151, 1149, 1151, 1149, 1163, 1149, 1163, 1151,
1149, 1149, 1163, 1151, 1163, 1151, 1149, 1163, 1151, 1149, 1163,
1151, 1149, 1151, 1163, 1149, 1151, 1163, 1149, 1151, 1163, 1149]
val = [-0.99487415, -0.07232158, 1.06719573, -1.52841215, -0.11110669,
1.63951884, -1.38100109, -0.10039076, 1.48139185, -2.3082298 ,
-0.16779491, 2.47602471, -1.6869314 , -0.12263012, 1.80956152,
1.58222925, -1.47500495, -0.1072243 , -1.62432548, -0.11807903,
1.74240451, -2.97269167, -0.21609743, 3.18878909, -2.69805372,
-0.19613284, 2.89418656, 4.23912078, -3.95184461, -0.28727616,
2.19057301, -0.14845046, -2.04212256, -1.01884757, -0.0740643 ,
1.09291187, -2.37983601, -0.17300026, 2.55283627, -3.17011761,
-0.23044915, 3.40056675, -3.60327431, -0.26193713, 3.86521144,
-0.23383981, 3.45060021, -3.2167604 , -2.28580025, -0.16616441,
2.45196466, -4.02181434, -0.29236256, 4.3141769 , -0.14901075,
-2.04983008, 2.19884083, -1.68775348, -0.12268988, 1.81044337,
-0.29771 , 4.3930851 , -4.0953751 , -0.18359276, 2.70914188,
-2.52554912, -2.30055344, -0.16723688, 2.46779032, -3.37568394,
-0.24539263, 3.62107657, -4.03339481, -0.29320439, 4.3265992 ,
-1.69607425, -0.12329475, 1.819369 , -0.14557236, 2.1481031 ,
-2.00253074, -3.83564025, -0.27882878, 4.11446903, -4.861238 ,
-0.35338379, 5.21462179, -0.18475935, -2.54159701, 2.72635635,
-2.74115057, -0.19926574, 2.94041631, -0.16786457, 2.47705273,
-2.30918815, 1.03134417, -0.96145218, -0.06989199, -1.84270365,
-0.13395386, 1.97665751, -3.51037475, -0.25518387, 3.76555862,
-3.29470161, -0.23950568, 3.53420729, -3.2573685 , -0.23679178,
3.49416028, 1.63611565, -1.52523958, -0.11087606, -1.35084021,
-0.09819824, 1.44903845, -1.4815967 , -0.10770348, 1.58930018,
-2.17569276, -0.15816023, 2.333853 , -0.10098036, -1.38911177,
1.49009214, -0.11618485, -1.59826857, 1.71445342, -0.06687615,
-0.91996547, 0.98684162]
# Getting index pointer for CSR matrix
indptr = np.bincount(row, minlength=local_size)
indptr = np.insert(indptr, 0, 0).cumsum()
indptr = indptr.astype(dtype='int32')
# Matrix Generation
mat = PETSc.Mat().create()
mat.setSizes([(local_size, global_size), (local_size, global_size)])
mat.setType('aij')
mat.setUp()
mat.setValuesCSR(indptr, col, val)
mat.assemblyBegin()
mat.assemblyEnd()
D_kj['{0}{1}'.format(k + 1, j + 1)] = mat
end_time = time.time()
print("Total execution time is: ",end_time-start_time)
D = [D_kj['11'], D_kj['12'], D_kj['21'], D_kj['22']]
The mesh file also can be obtained by this github link.
Somehow, the indexpointer(indptr) for CSR matrix is calculating wrongly when I run it in parallel. It is working greatly for built-in mesh generators for any number of cores.
I have no clue about how to proceed. Any help would be much appreciated.
Thanks for your replies in advance.
