I am running fenics on windows 10 through unbuntu 22.04 in wsl2. I installed it with ppa and then I tried to run the demo_poisson.py, I got the error as follows:
[0]PETSC ERROR: or see FAQ — PETSc 3.24.1 documentation
[0]PETSC ERROR: or try http://valgrind.org on GNU/linux and Apple Mac OS X to find memory corruption errors
MPI_ABORT was invoked on rank 0 in communicator MPI_COMM_WORLD
with errorcode 59.
NOTE: invoking MPI_ABORT causes Open MPI to kill all MPI processes.
You may or may not see output from other processes, depending on
exactly when Open MPI kills them.
I am a newbie to fenics. I have totally no idea how to fix this issue. can anyone give any hint for me?
thank you.
