Trouble running demos on dolfinx
Hey,
So I recently downloaded Dolfinx on Ubuntu WSL subsystem and I’m having an issue running any of the demos. I am met with the following error
[0]PETSC ERROR: or see FAQ — PETSc 3.19.3 documentation and FAQ — PETSc 3.19.3 documentation
Abort(59) on node 0 (rank 0 in comm 0): application called MPI_Abort(MPI_COMM_WORLD, 59) - process 0
I’m not too sure where to begin fixing this, any suggestions?
Hi, Can you please share the script you are trying to run ? Which environment are you using to run the code ?
There are some issues with PETSc 3.19. You might want to consider using the Ubuntu package system to provide PETSc.
Hey guys, thanks for your responses. I actually resolved it myself, the issue was due to my xserver not being correctly set up for anyone else who encounters this problem in the future :slight_smile:
Hello, could you please specify how exactly did you fix it.
EDIT: I found this post and it helped me to overcome this issue.
