I have been recently trying to use the adios4dolfinx library for checkpointing with FEniCSx.
To test the checkpointing functionality, I have done a completely fresh install of FEniCSx, PyVista and adios4dolfinx@v0.1.0 both on a MacOS laptop and on a Linux computer. On the MacOS laptop everything works flawless. However, on the Linux machine I have not been able to save any checkpoint since the function write_function of adios4dolfinx@v0.1.0 keeps throwing me the following segmentation error:
[0]PETSC ERROR: or see https://petsc.org/release/faq/#valgrind and https://petsc.org/release/faq/
MPI_ABORT was invoked on rank 0 in communicator MPI_COMM_WORLD
with errorcode 59.
NOTE: invoking MPI_ABORT causes Open MPI to kill all MPI processes.
You may or may not see output from other processes, depending on
exactly when Open MPI kills them.
I have also tried with different adios2 engines and adios4dolfinx versions but I continue getting the same error. Conversely, the function write_mesh of adios4dolfinx works perfectly on the Linux machine. Any idea of what may be causing this behavior of write_function?
Thank you,
Daniel
