Hi, I seem to meet same problem with PETSC ERROR when running in mpi. When I change MPI.COMM_WORLD parameter to MPI.COMM_SELF, it still can not work.
msh = mesh.create_box(comm=MPI.COMM_SELF, points=((0, 0, 0), (1.0, 1.0, 1.0)), n=(10, 10, 10), cell_type=mesh.CellType.tetrahedron)
V = fem.functionspace(msh, ("Lagrange", 1))
marker_condition = lambda x: np.logical_or.reduce((np.isclose(x[0], 0), np.isclose(x[0], 1.0),
np.isclose(x[1], 0), np.isclose(x[1], 1.0),
np.isclose(x[2], 0), np.isclose(x[2], 1.0)))
facets = mesh.locate_entities_boundary(msh, dim=(msh.topology.dim - 1), marker=marker_condition)
dofs = fem.locate_dofs_topological(V=V, entity_dim=1, entities=facets)
bc = fem.dirichletbc(value=ScalarType(0), dofs=dofs, V=V)
u = ufl.TrialFunction(V)
f = 10 * ufl.exp(-((x[0] - 0.5) ** 2 + (x[1] - 0.5) ** 2 + (x[2] - 0.5) ** 2) / 0.02)
g = ufl.sin(5 * x[0])
L = inner(f, v) * dx + inner(g, v) * ds
uh = problem.solve()
[0]PETSC ERROR: or see https://petsc.org/release/faq/#valgrind and https://petsc.org/release/faq/
Abort(59) on node 0 (rank 0 in comm 0): application called MPI_Abort(MPI_COMM_WORLD, 59) - process 0
It seems that I will meet this problem, while using create_box.
