Hi, I see that in the following snippet there is an MPI failure:
from typing import Any
import dolfinx_mpc
def test_broken() -> None:
def myfun() -> Any:
mesh = dolfinx.mesh.create_unit_square(MPI.COMM_WORLD, 5, 5)
mpc = dolfinx_mpc.MultiPointConstraint(V)
mpc.finalize()
base = ufl.TestFunction(V) * ufl.dx
return dolfinx_mpc.assemble_vector(dolfinx.fem.form(base), mpc)
vec = myfun()
assert vec is not None
vec1 = vec.duplicate()
assert vec1 is not None
The failure happen in the duplicate(), and is related to the fact that mpc is released after myfun():
[0]PETSC ERROR: or see FAQ — PETSc 3.23.2 documentation and FAQ — PETSc 3.23.2 documentation
MPI_ABORT was invoked on rank 0 in communicator MPI_COMM_WORLD
Proc: [[7410,1],0]
Errorcode: 59
NOTE: invoking MPI_ABORT causes Open MPI to kill all MPI processes.
You may or may not see output from other processes, depending on
exactly when Open MPI kills them.
prterun has exited due to process rank 0 with PID 0 on node Ideapad-Lenovo calling
“abort”. This may have caused other processes in the application to be
terminated by signals sent by prterun (as reported here).
If I keep the mpc instance alive, the duplication works fine.
Is this expected? Or should the petscvec own its communicator?
Thanks,
Mattia
