PETSC Error when creating functionspace using custom element
Hello everyone,
I created a custom hexahedron Lagrange element with degree 1 on the x, y direction and degree 2 on the z direction. When I tabulated the values of the points on the reference cell, everything seemed ok. However, when I created a functionspace using the custom element, like:
NX, NY, NZ = 1, 1, 1
points=[np.array([0, 0, 0]), np.array([NX, NY, NZ])]
domain=mesh.create_box(
    comm,
    points,
    [NX, NY, NZ],
    cell_type=mesh.CellType.hexahedron,
    dtype=default_scalar_type,
    ghost_mode=mesh.GhostMode.shared_facet,
custom_element = create_custom_element(1, 2, dim=1)
V = fem.functionspace(domain, custom_element)
I got errors:
[0]PETSC ERROR: or see https://petsc.org/release/faq/#valgrind and https://petsc.org/release/faq/
Abort(59) on node 0 (rank 0 in comm 0): application called MPI_Abort(MPI_COMM_WORLD, 59) - process 0
What I wonder is whether it is just mathematically forbidden or technically forbidden to create such an element. If not, I can check my code more specifically. Thank you all.
We would need to see the implementation of the custom element to comment further on this. In theory, nothing in particular happens with a custom element when compared to a «built in» element.
Thank you. Here is my implementation and comments:
def create_custom_element(degree_p, degree_t, dim=3):
    #degree_t: degree on the z direction
    #degree_p: degree on the x,y direction
    #assume degree_t is larger than degree_p
    assert degree_t >= degree_p
    #get the quadrature points, legendre polys, and function values on the three directions
    pts_p, wts_p = basix.make_quadrature(CellType.interval, degree_p*2)
    pts_t, wts_t = basix.make_quadrature(CellType.interval, degree_t*2)
    poly_p = basix.tabulate_polynomials(PolynomialType.legendre, CellType.interval, degree_p, pts_p)
    poly_t = basix.tabulate_polynomials(PolynomialType.legendre, CellType.interval, degree_t, pts_t)
    lagrange_p = basix.create_element(ElementFamily.P, CellType.interval, degree_p, LagrangeVariant.equispaced)
    lagrange_t = basix.create_element(ElementFamily.P, CellType.interval, degree_t, LagrangeVariant.equispaced)
    f_p = lagrange_p.tabulate(0, pts_p)[0, :, :, 0]
    f_t = lagrange_t.tabulate(0, pts_t)[0, :, :, 0]
    #calculate the coefficients on the three directions
    wcoeffs_p = f_p.T@((poly_p*wts_p).T)
    wcoeffs_t = f_t.T@((poly_t*wts_t).T)
    #because degree_t>=degree_p, some columns of wcoeffs_x/y will be zeros
    wcoeffs_x = np.zeros((degree_p+1, degree_t+1))
    wcoeffs_x[:, :degree_p+1] = wcoeffs_p
    wcoeffs_y = np.zeros((degree_p+1, degree_t+1))
    wcoeffs_y[:, :degree_p+1] = wcoeffs_p
    wcoeffs_z = wcoeffs_t
    #kron product
    #the shape of the coefficients matrix will be ((degree_p+1)^2*(degree_t+1), (degree_t+1)^3)
    wcoeffs = np.kron(np.kron(wcoeffs_x, wcoeffs_y), wcoeffs_z)
    geometry = basix.geometry(basix.CellType.hexahedron)
    topology = basix.topology(basix.CellType.hexahedron)
    x = [[], [], [], []]
    M = [[], [], [], []]
    #vertexes
    for v in topology[0]:
        x[0].append(np.array(geometry[v]))
        M[0].append(np.array([[[[1.0]]]]))
    pts_p = basix.create_lattice(CellType.interval, degree_p, LatticeType.equispaced, False)
    pts_t = basix.create_lattice(CellType.interval, degree_t, LatticeType.equispaced, False)
    #edges
    for e in topology[1]:
        v0 = geometry[e[0]]
        v1 = geometry[e[1]]
        if np.abs(v1-v0)[2] < 1e-3: #x,y direction
            edge_pts = np.array([v0 + p * (v1-v0) for p in pts_p]).reshape(pts_p.shape[0],3)
            mat = np.eye(pts_p.shape[0], pts_p.shape[0]).reshape(pts_p.shape[0], 1, pts_p.shape[0], 1)
        else: #z-direction
            edge_pts = np.array([v0 + p * (v1-v0) for p in pts_t]).reshape(pts_t.shape[0], 3)
            mat = np.eye(pts_t.shape[0], pts_t.shape[0]).reshape(pts_t.shape[0], 1, pts_t.shape[0], 1)
        x[1].append(edge_pts)
        M[1].append(mat)
    #facets
    for f in topology[2]:
        v0 = geometry[f[0]]
        v1 = geometry[f[1]]
        v2 = geometry[f[2]]
        if np.abs(v1-v0)[2] < 1e-3 and np.abs(v2-v0)[2] < 1e-3: #x,y direction
            face_pts = np.array([v0 + px * (v1-v0) + py * (v2-v0) for py in pts_p for px in pts_p]).reshape(pts_p.shape[0]**2,3)
            mat = np.eye(pts_p.shape[0]**2, pts_p.shape[0]**2).reshape(pts_p.shape[0]**2, 1, pts_p.shape[0]**2, 1)
        else: #z direction
            face_pts = np.array([v0 + pp * (v1-v0) + pt * (v2-v0) for pt in pts_t for pp in pts_p]).reshape(pts_p.shape[0]*pts_t.shape[0],3)
            mat = np.eye(pts_p.shape[0]*pts_t.shape[0], pts_p.shape[0]*pts_t.shape[0]).reshape(pts_p.shape[0]*pts_t.shape[0], 1, pts_p.shape[0]*pts_t.shape[0], 1)
        x[2].append(face_pts)
        M[2].append(mat)
    #body
    for b in topology[3]:
        v0 = geometry[b[0]]
        v1 = geometry[b[1]]
        v2 = geometry[b[2]]
        v3 = geometry[b[4]]
        body_pts = np.array([v0 + px * (v1-v0) + py * (v2-v0) + pz * (v3-v0) for pz in pts_t for py in pts_p for px in pts_p]).reshape(pts_p.shape[0]**2*pts_t.shape[0],3)
        mat = np.eye(pts_p.shape[0]**2*pts_t.shape[0], pts_p.shape[0]**2*pts_t.shape[0]).reshape(pts_p.shape[0]**2*pts_t.shape[0], 1, pts_p.shape[0]**2*pts_t.shape[0], 1)
        x[3].append(body_pts)
        M[3].append(mat)
    #create the element
    if dim > 1:
        custom_element = basix.ufl.blocked_element(basix.ufl.custom_element(
            wcoeffs,
            x,
            M,
            0,
            MapType.identity,
            SobolevSpace.H1,
            False,
            degree_p,
            degree_t,
            PolysetType.standard,
        ), (dim,))
        custom_element = basix.ufl.custom_element(
            wcoeffs,
            x,
            M,
            0,
            MapType.identity,
            SobolevSpace.H1,
            False,
            degree_p,
            degree_t,
    return custom_element
Here are more tests:
When degree_p and degree_t are both 1:
plate_element = create_plate_element(1, 1, dim=1)
V = fem.functionspace(domain, plate_element)
No errors.
When degree_p is 1 and degree_t > 1:
plate_element = create_plate_element(1, 2/3/4/5..., dim=1)
Report:
When degree_p > 1 and degree_t > degree_p:
plate_element = create_plate_element(2, 3/4/5..., dim=1)
Report:
  File ..., line 23, in <module>
  File ..., line 630, in functionspace
    cpp_dofmap = _cpp.fem.create_dofmap(mesh.comm, mesh.topology._cpp_object, cpp_element)
RuntimeError: Incompatible elements detected.
When degree_p = degree_t:
plate_element = create_plate_element(2, 2, dim=1)
No errors.
So the error may come from the incompatible degree_p and degree_t?
I think I have figured out the reason. This kind of ‘anisotropic Lagrange element’ with different numbers of dofs on entities of the same dimension is not supported by dolfinx and will lead to an ‘incompatible mesh’ error:
(line 222-228 in dolfinx/cpp/dolfinx/fem/dofmapbuilder.cpp)
 else
            std::size_t k
                = std::distance(required_dim_et.begin(), required_entity_it);
            if (num_entity_dofs_et[k] != (int)entity_dofs_d[e].size())
              throw std::runtime_error("Incompatible elements detected.");
This piece of code will check the previously recorded number of dofs on the entities of a certain dimension and compare it with the current one. For entities with no dofs, this piece of code will not be executed and the ‘incompatible mesh’ error will not be triggered, but this will cause a segmentation fault later (like the (1,2) case).
