Hi everyone,
I’m using a mesh that I converted using meshio.
Available here: mesh.zip - Google Drive
When trying to solve a simple problem on it, I get this error:
No Jacobian form specified for nonlinear variational problem.
Differentiating residual form F to obtain Jacobian J = F'.
Newton iteration 0: r (abs) = 5.430e+01 (tol = 1.000e-10) r (rel) = 1.000e+00 (tol = 1.000e-09)
File "/home/remidm/Fusion-TES-Modeling/MWE.py", line 32, in <module>
solve(F == 0, u, bcs)
File "/home/remidm/miniconda3/envs/tes-model-env/lib/python3.11/site-packages/dolfin/fem/solving.py", line 220, in solve
File "/home/remidm/miniconda3/envs/tes-model-env/lib/python3.11/site-packages/dolfin/fem/solving.py", line 266, in _solve_varproblem
solver.solve()
RuntimeError:
*** Error: Unable to successfully call PETSc function 'MatSetValuesLocal'.
*** Reason: PETSc error code is: 63 (Argument out of range).
*** Where: This error was encountered inside /home/conda/feedstock_root/build_artifacts/fenics-pkgs_1696906506503/work/dolfin/dolfin/la/PETScMatrix.cpp.
*** Process: 0
*** DOLFIN version: 2019.1.0
*** Git changeset: 2e001bd1aae8e14d758264f77382245e6eed04b0
I have noticed that depending on how I use dx
in the formulation it does or doesn’t work.
I’m guessing it may be a tagging issue? Although when I inspect volume_markers
it only contains 6
and it has the same size as the mesh (141787 cells).
Here is my MWE:
inlet_id = 8
outlet_id = 7
fluid_id = 6
mesh = Mesh()
XDMFFile("mesh_cells.xdmf").read(mesh)
# create dx from the volume markers
volume_markers = MeshFunction("size_t", mesh, mesh.topology().dim())
XDMFFile("mesh_cells.xdmf").read(volume_markers)
dx = Measure("dx", domain=mesh, subdomain_data=volume_markers)
surface_markers = MeshValueCollection("size_t", mesh, mesh.topology().dim() - 1)
XDMFFile("mesh_facets.xdmf").read(surface_markers, "f")
surface_markers = MeshFunction("size_t", mesh, surface_markers)
inlet = DirichletBC(V, Constant(1), surface_markers, inlet_id)
outlet = DirichletBC(V, Constant(0), surface_markers, outlet_id)
bcs = [inlet, outlet]
F = dot(2 * grad(u), grad(v)) * dx(fluid_id) # doesn't work
# F = 2 * dot(grad(u), grad(v)) * dx(fluid_id) # doesn't works
# F = dot(grad(u), grad(v)) * dx(fluid_id) # works
# F = dot(2 * grad(u), grad(v)) * dx # works
XDMFFile("solution.xdmf").write(u)
Has anyone ever experienced this?
Cheers
Remi
This is what surface markers look like:
Volume markers:
