PETSc NonlinearProblem running slow
You have also not specified any solver options and these might differ between DOLFIN (legacy) and DOLFINx.
Note that almost all of the time is spent inside your function update_fields.
This is because of how you create v_vec and u_vec, which are not sensible objects to assign to a function.
Instead of working on the array data, you are assigning ufl objects to a numpy array.
There are various things here that you need to carefully address here (specifically mapping all constants to floats).
The following code takes 2.4 seconds to run:
from dolfinx import fem, mesh, default_scalar_type
from dolfinx.io import XDMFFile
from dolfinx import *
import dolfinx.fem.petsc
import dolfinx.nls.petsc
import time
start_time = time.time()
# Create mesh and function space
L = 1.0  # Length of the rod
nx, ny, nz = 20, 5, 5  # Number of elements in x, y, and z directions
domain = mesh.create_box(MPI.COMM_WORLD, [np.array([0, 0, 0]), np.array(
    [L, 0.1, 0.1])], [nx, ny, nz], cell_type=mesh.CellType.hexahedron)
V = fem.VectorFunctionSpace(domain, ("CG", 1))
fdim = domain.topology.dim - 1
def clamped_boundary(x):
    return np.isclose(x[0], 0)  # |np.isclose(x[0], L)
boundary_facets = mesh.locate_entities_boundary(domain, fdim, clamped_boundary)
u_D = np.array([0, 0, 0], dtype=default_scalar_type)
bc = fem.dirichletbc(u_D, fem.locate_dofs_topological(
    V, fdim, boundary_facets), V)
# Elasticity constants
E = 1.0e6
nu = 0.3
mu = E / (2.0 * (1 + nu))
lmbda = E * nu / ((1.0 + nu) * (1.0 - 2.0 * nu))
# Time integration parameters
am = 0.2
af = 0.4
g = 0.5 + af - am
alpha_m = fem.Constant(domain, am)
alpha_f = fem.Constant(domain, af)
gamma = fem.Constant(domain, g)
beta = fem.Constant(domain, (g + 0.5)**2 / 4.0)
rho = 1.0
eta_m = 0.0
eta_k = 0.0
T = 1.0
Nsteps = 50
dt = fem.Constant(domain, T / Nsteps)
# Functions and fields
u_ = ufl.TestFunction(V)
u = fem.Function(V, name='Displacement')
u_old = fem.Function(V)
v_old = fem.Function(V)
a_old = fem.Function(V)
# External load
B = fem.Constant(domain, PETSc.ScalarType((0.0, 0.0, -1.0))
                 )  # Applied load in the z-direction
# Measures
dx = ufl.Measure("dx", domain=domain)
# GA method functions
def sigma(r):
    return lmbda*ufl.nabla_div(r)*ufl.Identity(len(r)) + 2*mu*ufl.sym(ufl.grad(r))
def m(u, u_):
    return rho*ufl.inner(u, u_)*dx
def k(u, u_):
    return ufl.inner(sigma(u), ufl.grad(u_))*dx
def c(u, u_):
    return eta_m*m(u, u_) + eta_k*k(u, u_)
# update variables
def update_a(u, u_old, v_old, a_old, ufl_=True):
    if ufl_:
        dt_ = dt
        beta_ = beta
        return (u-u_old-dt_*v_old)/beta_/dt_**2 - (1-2*beta_)/2/beta_*a_old
        dt_ = dt
        beta_ = beta.value
        return (u-u_old-float(dt_)*v_old)/float(beta_)/float(dt_)**2 - (1-2*float(beta_))/2/float(beta_)*a_old
def update_v(a, u_old, v_old, a_old, ufl_=True):
    if ufl_:
        return v_old + dt*((1-gamma)*a_old + gamma*a)
        return v_old + float(dt) * ((1 - float(gamma)) * a_old + float(gamma)*a)
def update_fields(u, u_old, v_old, a_old):
    u_vec, u0_vec = u.x.array[:], u_old.x.array[:]
    v0_vec, a0_vec = v_old.x.array[:], a_old.x.array[:]
    a_vec = update_a(u_vec, u0_vec, v0_vec, a0_vec, ufl_=False)
    v_vec = update_v(a_vec, u0_vec, v0_vec, a0_vec, ufl_=False)
    v_old.x.array[:] = v_vec
    a_old.x.array[:] = a_vec
    u_old.x.array[:] = u_vec
def avg(x_old, x_new, alpha):
    return alpha*x_old + (1-alpha)*x_new
a_new = update_a(u, u_old, v_old, a_old, ufl_=True)
v_new = update_v(a_new, u_old, v_old, a_old, ufl_=True)
# Problem setup
res = m(avg(a_old, a_new, alpha_m), u_) + c(avg(v_old, v_new, alpha_f), u_) + \
    k(avg(u_old, u, alpha_f), u_) - rho * \
    ufl.inner(B, u_)*dx  # residual to solve
problem = fem.petsc.NonlinearProblem(res, u, [bc])
# Solver setup
solver = nls.petsc.NewtonSolver(MPI.COMM_WORLD, problem)
solver.atol = 1e-8
solver.rtol = 1e-8
solver.convergence_criterion = "incremental"
# Quantities to track
times = np.linspace(0, T, Nsteps + 1)
# Create file
with XDMFFile(domain.comm, "rod_dbc0.xdmf", "w") as xdmf_file:
    xdmf_file.write_mesh(domain)
    xdmf_file.write_function(u, 0)
solve_time = 0
# Write function at each time step
for i in range(Nsteps):
    t = times[i + 1]
    print("Time = %s" % t)
    s = time.perf_counter()
    num_its, converged = solver.solve(u)
    e = time.perf_counter()
    solve_time += e-s
    assert converged
    u.x.scatter_forward()
    # Update old fields with new quantities
    # Write the function to the XDMF file
    xdmf_file.write_function(u, t)
print("--- %s seconds runtime ---" % (time.time() - start_time))
print(solve_time)
Also note that the mesh uses hexahedrons in your dolfinx code, while the legacy code uses tetrahedrons
