Physical region and facet not read by meshconvert
Hello, i’m doing a project that requires the legacy dolfin xml format and i’ve recently asked about dolfin-convert to create xml files from gmsh mesh file. I tried making a simple 2D box with a rectangular hole inside. I used the dolfin-convert on terminal.
It works as intended, except it didn’t read my physical and facet region. So it only produced the mesh .xml, no physical or facet xml produced. Here is the said .msh file :
Simple box mesh
Why is it not reading my physical and facet region? Thank you for your help!
Additional information
Mesh created on Gmsh 4.8.4
Fenics version 2019.2.0dev0
Please add the msh file directly to the question using 3x` encapsulation.
It would be even better if you could supply the geo file
Hi, dokken. Thanks for replying! I did try using the 3x` encapsulation but it was over the limit of characters allowed. Also .geo file :
// Gmsh project created on Tue Aug 03 16:46:33 2021
Point(1) = {10, 10, 0, 1.0};
Point(2) = {0, 0, 0, 1.0};
Point(3) = {10, 0, 0, 1.0};
Point(4) = {0, 10, 0, 1.0};
Line(1) = {4, 2};
Line(2) = {2, 3};
Line(3) = {3, 1};
Line(4) = {1, 4};
Curve Loop(1) = {4, 1, 2, 3};
Point(5) = {2.5, 2.5, 0, 1.0};
Point(6) = {2.5, 7.5, 0, 1.0};
Point(7) = {7.5, 7.5, 0, 1.0};
Point(8) = {7.5, 2.5, 0, 1.0};
Line(5) = {7, 6};
Line(6) = {6, 5};
Line(7) = {5, 8};
Line(8) = {8, 7};
Physical Curve("outer", 15) = {5, 8, 7, 6};
Physical Curve("inner", 16) = {1, 4, 3, 2};
Curve Loop(3) = {8, 5, 6, 7};
Plane Surface(1) = {1, 3};
Plane Surface(2) = {3};
Physical Surface("inner", 17) = {2};
Pardon the messiness of the GEO files because i am using the GUI for the test and it records anything i do in the GUI
EDIT : i simplified the GEO file from text editor
Have you tried not using strings for tagging your region and facets?
i.e.
Line(1) = {4, 2};
Line(2) = {2, 3};
Line(3) = {3, 1};
Line(4) = {1, 4};
Line(5) = {7, 6};
Line(6) = {6, 5};
Line(7) = {5, 8};
Line(8) = {8, 7};
Physical Curve(15) = {5, 8, 7, 6};
Physical Curve(16) = {1, 4, 3, 2};
Physical Surface(17) = {2};
I tried your configuration and it still doesn’t produce the physical and facet region xmls, i wonder what’s wrong
I have added another physical surface to the outer part of the mesh. Running the dolfin-convert command in the terminal now produces no error. Maybe this helps?
Line(1) = {4, 2};
Line(2) = {2, 3};
Line(3) = {3, 1};
Line(4) = {1, 4};
Line(5) = {7, 6};
Line(6) = {6, 5};
Line(7) = {5, 8};
Line(8) = {8, 7};
Physical Surface(18) = {1};
Thank you for your replies! It is indeed running with no errors, yet dolfin-convert still didn’t make any physical region or facet region xmls…
This is strange because those files were created when I ran the command on my computer. I’m out of ideas now, sorry.
No worries! Having people notice my thread is helpful enough.
Also, i read that the format for elements in gmsh .msh are :
element number - element type - number of tags - tag(s) - node(s)
And i checked with the exported .msh :
$MeshFormat
2.2 0 8
$EndMeshFormat
$Nodes
64
1 10 10 0
2 0 0 0
3 10 0 0
4 0 10 0
5 2.5 2.5 0
6 2.5 7.5 0
7 7.5 7.5 0
8 7.5 2.5 0
9 0 8.333333333333334 0
10 0 6.666666666666667 0
11 0 5 0
12 0 3.333333333333334 0
13 0 1.666666666666666 0
14 1.666666666664462 0 0
15 3.333333333326262 0 0
16 4.999999999992399 0 0
17 6.666666666661599 0 0
18 8.333333333330799 0 0
19 10 1.666666666664462 0
20 10 3.333333333326262 0
21 10 4.999999999992399 0
22 10 6.666666666661599 0
23 10 8.333333333330799 0
24 8.333333333333334 10 0
25 6.666666666666667 10 0
26 5 10 0
27 3.333333333333334 10 0
28 1.666666666666666 10 0
29 5.833333333333334 7.5 0
30 4.166666666666667 7.5 0
31 2.5 5.833333333333334 0
32 2.5 4.166666666666667 0
33 4.166666666666666 2.5 0
34 5.833333333333333 2.5 0
35 7.5 4.166666666666666 0
36 7.5 5.833333333333333 0
37 9.035714285714677 2.575396825392835 0
38 2.575396825392914 0.9642857142852637 0
39 4.166666666659331 1.1111111111112 0
40 8.8888888888888 4.166666666659331 0
41 1.220238095238095 7.159391534391533 0
42 2.575396825396826 9.035714285714285 0
43 7.1593915343916 8.779761904761854 0
44 5.765211640211653 9.033730158730149 0
45 4.166666666666669 8.888888888888889 0
46 0.9642857142851252 2.575396825396358 0
47 0.9662698412698414 5.76521164021164 0
48 1.111111111111111 4.166666666666667 0
49 5.833333333326999 1.111111111110688 0
50 8.88888888888931 5.833333333326999 0
51 8.77976190476204 7.159391534389162 0
52 7.159391534389552 1.220238095237467 0
53 1.210317460314515 1.210317460315119 0
54 1.240703967041952 8.758894322765279 0
55 8.758894322766613 1.240703967039182 0
56 8.747789905294024 8.747789905293287 0
57 5 6.024041468517416 0
58 4.999999999999999 3.974746876424108 0
59 6.262800408580524 4.999798057490253 0
60 3.737199591419476 4.999798057490253 0
61 6.28840122574157 6.288401225741572 0
62 3.711598774258427 3.711598774258428 0
63 3.711598774258426 6.288401225741571 0
64 6.288401225741574 3.711598774258428 0
$EndNodes
$Elements
146
1 15 2 0 1 1
2 15 2 0 2 2
3 15 2 0 3 3
4 15 2 0 4 4
5 15 2 0 5 5
6 15 2 0 6 6
7 15 2 0 7 7
8 15 2 0 8 8
9 1 2 0 1 4 9
10 1 2 0 1 9 10
11 1 2 0 1 10 11
12 1 2 0 1 11 12
13 1 2 0 1 12 13
14 1 2 0 1 13 2
15 1 2 0 2 2 14
16 1 2 0 2 14 15
17 1 2 0 2 15 16
18 1 2 0 2 16 17
19 1 2 0 2 17 18
20 1 2 0 2 18 3
21 1 2 0 3 3 19
22 1 2 0 3 19 20
23 1 2 0 3 20 21
24 1 2 0 3 21 22
25 1 2 0 3 22 23
26 1 2 0 3 23 1
27 1 2 0 4 1 24
28 1 2 0 4 24 25
29 1 2 0 4 25 26
30 1 2 0 4 26 27
31 1 2 0 4 27 28
32 1 2 0 4 28 4
33 1 2 0 5 7 29
34 1 2 0 5 29 30
35 1 2 0 5 30 6
36 1 2 0 6 6 31
37 1 2 0 6 31 32
38 1 2 0 6 32 5
39 1 2 0 7 5 33
40 1 2 0 7 33 34
41 1 2 0 7 34 8
42 1 2 0 8 8 35
43 1 2 0 8 35 36
44 1 2 0 8 36 7
45 2 2 0 1 42 6 45
46 2 2 0 1 6 30 45
47 2 2 0 1 29 43 44
48 2 2 0 1 31 6 41
49 2 2 0 1 29 7 43
50 2 2 0 1 5 32 48
51 2 2 0 1 46 5 48
52 2 2 0 1 31 41 47
53 2 2 0 1 31 47 48
54 2 2 0 1 29 44 45
55 2 2 0 1 32 31 48
56 2 2 0 1 30 29 45
57 2 2 0 1 7 36 51
58 2 2 0 1 8 34 52
59 2 2 0 1 36 50 51
60 2 2 0 1 34 49 52
61 2 2 0 1 8 37 40
62 2 2 0 1 5 38 39
63 2 2 0 1 33 39 49
64 2 2 0 1 35 40 50
65 2 2 0 1 34 33 49
66 2 2 0 1 36 35 50
67 2 2 0 1 35 8 40
68 2 2 0 1 33 5 39
69 2 2 0 1 38 5 53
70 2 2 0 1 37 8 55
71 2 2 0 1 5 46 53
72 2 2 0 1 8 52 55
73 2 2 0 1 2 14 53
74 2 2 0 1 28 4 54
75 2 2 0 1 6 42 54
76 2 2 0 1 41 6 54
77 2 2 0 1 4 9 54
78 2 2 0 1 23 1 56
79 2 2 0 1 3 19 55
80 2 2 0 1 43 7 56
81 2 2 0 1 1 24 56
82 2 2 0 1 7 51 56
83 2 2 0 1 13 2 53
84 2 2 0 1 18 3 55
85 2 2 0 1 20 21 40
86 2 2 0 1 15 16 39
87 2 2 0 1 37 20 40
88 2 2 0 1 38 15 39
89 2 2 0 1 39 16 49
90 2 2 0 1 40 21 50
91 2 2 0 1 19 20 37
92 2 2 0 1 14 15 38
93 2 2 0 1 21 22 50
94 2 2 0 1 16 17 49
95 2 2 0 1 50 22 51
96 2 2 0 1 49 17 52
97 2 2 0 1 27 42 45
98 2 2 0 1 43 25 44
99 2 2 0 1 47 11 48
100 2 2 0 1 12 13 46
101 2 2 0 1 24 25 43
102 2 2 0 1 12 46 48
103 2 2 0 1 27 28 42
104 2 2 0 1 41 10 47
105 2 2 0 1 11 12 48
106 2 2 0 1 26 27 45
107 2 2 0 1 10 11 47
108 2 2 0 1 25 26 44
109 2 2 0 1 9 10 41
110 2 2 0 1 44 26 45
111 2 2 0 1 22 23 51
112 2 2 0 1 17 18 52
113 2 2 0 1 14 38 53
114 2 2 0 1 19 37 55
115 2 2 0 1 46 13 53
116 2 2 0 1 52 18 55
117 2 2 0 1 9 41 54
118 2 2 0 1 42 28 54
119 2 2 0 1 51 23 56
120 2 2 0 1 24 43 56
121 2 2 0 2 57 58 59
122 2 2 0 2 58 57 60
123 2 2 0 2 33 34 58
124 2 2 0 2 29 30 57
125 2 2 0 2 35 36 59
126 2 2 0 2 31 32 60
127 2 2 0 2 36 7 61
128 2 2 0 2 7 29 61
129 2 2 0 2 5 33 62
130 2 2 0 2 30 6 63
131 2 2 0 2 32 5 62
132 2 2 0 2 6 31 63
133 2 2 0 2 34 8 64
134 2 2 0 2 8 35 64
135 2 2 0 2 57 30 63
136 2 2 0 2 58 34 64
137 2 2 0 2 29 57 61
138 2 2 0 2 33 58 62
139 2 2 0 2 60 57 63
140 2 2 0 2 57 59 61
141 2 2 0 2 58 60 62
142 2 2 0 2 59 58 64
143 2 2 0 2 59 36 61
144 2 2 0 2 35 59 64
145 2 2 0 2 60 32 62
146 2 2 0 2 31 60 63
$EndElements
So i wonder does this mean my exported .msh file somehow doesn’t recognize the physical entity from .geo file?
EDIT : i tried changing some of the zeros to one (manually) and it indeed being read as physical region by dolfin-convert, yet i still don’t know which part is being read as facet region by dolfin-convert and why does exporting the mesh to version 2 from gmsh doesn’t include the physical entity label. Also, which part of this mesh is supposed to be recognized as facets?
Using gmsh 4.6.0 and the following command:
 gmsh -3 dconvert.geo -format msh2
I am able to convert the msh file to xml (including physical and facet regions) using
 dolfin-convert dconvert.msh mesh.xml
when I tried converting your .msh file, I also get no physical or facet .xml files. What happens when you try the mesh I created from your .geo file? Here is my .msh file:
$MeshFormat
2.2 0 8
$EndMeshFormat
$Nodes
148
1 10 10 0
2 0 0 0
3 10 0 0
4 0 10 0
5 2.5 2.5 0
6 2.5 7.5 0
7 7.5 7.5 0
8 7.5 2.5 0
9 0 8.999999999999998 0
10 0 7.999999999999996 0
11 0 6.999999999999994 0
12 0 5.999999999999991 0
13 0 4.999999999999989 0
14 0 3.999999999999988 0
15 0 2.999999999999985 0
16 0 1.999999999999982 0
17 0 0.9999999999999911 0
18 0.9999999999991893 0 0
19 1.999999999996827 0 0
20 2.99999999999391 0 0
21 3.999999999991027 0 0
22 4.999999999992411 0 0
23 5.999999999993932 0 0
24 6.999999999995455 0 0
25 7.999999999996978 0 0
26 8.99999999999849 0 0
27 10 0.9999999999991893 0
28 10 1.999999999996827 0
29 10 2.99999999999391 0
30 10 3.999999999991027 0
31 10 4.999999999992411 0
32 10 5.999999999993932 0
33 10 6.999999999995455 0
34 10 7.999999999996978 0
35 10 8.99999999999849 0
36 8.999999999999998 10 0
37 7.999999999999996 10 0
38 6.999999999999994 10 0
39 5.999999999999991 10 0
40 4.999999999999989 10 0
41 3.999999999999988 10 0
42 2.999999999999985 10 0
43 1.999999999999982 10 0
44 0.9999999999999911 10 0
45 6.499999999999998 7.5 0
46 5.499999999999996 7.5 0
47 4.499999999999994 7.5 0
48 3.499999999999991 7.5 0
49 2.5 6.499999999999998 0
50 2.5 5.499999999999996 0
51 2.5 4.499999999999994 0
52 2.5 3.499999999999991 0
53 3.500000000000002 2.5 0
54 4.500000000000004 2.5 0
55 5.500000000000006 2.5 0
56 6.500000000000009 2.5 0
57 7.5 3.500000000000002 0
58 7.5 4.500000000000004 0
59 7.5 5.500000000000006 0
60 7.5 6.500000000000009 0
61 1.504237369278822 0.8437935400932353 0
62 9.09742746643666 1.569695173660743 0
63 1.552867838065872 9.052119733802147 0
64 8.447132161933904 9.052119733801668 0
65 9.076579026614752 3.383820427574388 0
66 3.499999999992468 0.8660254037819272 0
67 0.8159800986278851 2.565090298183414 0
68 3.03474995713471 8.35680591780779 0
69 1.666666666666666 4.013743614618013 0
70 1.654494632043742 6.995091566207847 0
71 6.958378235556266 8.344423902873896 0
72 5.499999999999991 9.158248672024422 0
73 0.8417513279755771 5.499999999999993 0
74 4.995091566207249 1.654494632044234 0
75 8.345505367955765 4.995091566207249 0
76 8.36602540378443 7.000000000000005 0
77 7.000000000000005 1.633974596215569 0
78 8.000000000000195 1.633974596215454 0
79 8.5280135313433 2.478031432660168 0
80 1.595786936293665 7.996871577694411 0
81 8.407633069677384 7.997689649992651 0
82 4.012663466831456 8.335760772628879 0
83 8.355940688887731 5.999582616174093 0
84 5.999582616174093 1.644059311112267 0
85 2.500183836993867 0.8608058739404227 0
86 4.499181927697194 0.836756758812976 0
87 9.153677312919802 4.479818665627514 0
88 2.556224730310485 9.170992753276439 0
89 1.647172480296117 3.063184458728557 0
90 6.499934846568384 9.162903098495264 0
91 4.502110577805235 9.165664821267526 0
92 0.8327110795112429 6.499181927701304 0
93 0.8347363324403732 4.502290602436327 0
94 7.515561400318028 9.15980918309279 0
95 1.987592630326773 1.622820510194944 0
96 2.997962744552185 1.672114167809891 0
97 3.517624788680309 9.171537377496771 0
98 0.8139389851218124 7.498524178600592 0
99 7.500000000000004 0.8169872981087116 0
100 9.192671652078284 7.499614941663805 0
101 9.183012701890823 6.500000000000005 0
102 6.500000000000013 0.8169872981091786 0
103 9.173022678609019 5.495748807999201 0
104 5.498976018344149 0.825383000013109 0
105 4.999999999999994 8.316966781059648 0
106 1.683033218940353 4.999999999999995 0
107 0.8207784241398899 3.508765122325445 0
108 5.993052180354105 8.330423742408872 0
109 1.668665043078486 5.999045582318189 0
110 8.300622590731656 4.014450749384793 0
111 4.000000000000003 1.683033218942056 0
112 0.9151917667330459 1.571564764439138 0
113 8.478377775904352 0.8169872981067847 0
114 9.220079603188935 8.470410843482869 0
115 0.7815921706727341 8.470092704257013 0
116 9.340404004878941 2.486309406777207 0
117 0.7320508075675562 0.7320508075677711 0
118 9.267949192432082 0.7320508075672936 0
119 8.181043029737941 3.17526052192387 0
120 9.273040735444042 9.273040735443628 0
121 0.7269592645550557 9.27304073544494 0
122 2.249730586662369 8.434018166156477 0
123 7.750269413337613 8.434018166156489 0
124 1.583421335422508 2.300272839569943 0
125 3.361306709865612 4.991826982387217 0
126 6.832457351945705 5.040259921725074 0
127 5.040166509861509 6.681505525181567 0
128 5.056674571293672 3.318533060241286 0
129 3.346485438282338 4.003740951787382 0
130 4.14632776580536 4.480799386379441 0
131 4.122340012567546 5.501052330063192 0
132 5.098076211353319 4.999999999999999 0
133 4.053355787589682 6.574015197191468 0
134 5.999432116976148 3.346910717383869 0
135 6.559544979888686 5.923825435843591 0
136 3.294842219598618 5.972473950345497 0
137 5.970165505392087 6.691284410818625 0
138 6.627398002285679 4.079450474660998 0
139 4.081792557862228 3.440948478543938 0
140 5.573102604629768 4.158111816510904 0
141 5.554099126398261 5.89960466597768 0
142 5.911515384252419 5.117019385819809 0
143 3.232050807568874 6.767949192431121 0
144 6.767949192431125 3.232050807568879 0
145 6.767949192431122 6.767949192431126 0
146 3.232050807568877 3.232050807568874 0
147 4.791009322085348 4.051515143830581 0
148 4.790616148109524 5.948751121073604 0
$EndNodes
$Elements
314
1 1 2 16 1 4 9
2 1 2 16 1 9 10
3 1 2 16 1 10 11
4 1 2 16 1 11 12
5 1 2 16 1 12 13
6 1 2 16 1 13 14
7 1 2 16 1 14 15
8 1 2 16 1 15 16
9 1 2 16 1 16 17
10 1 2 16 1 17 2
11 1 2 16 2 2 18
12 1 2 16 2 18 19
13 1 2 16 2 19 20
14 1 2 16 2 20 21
15 1 2 16 2 21 22
16 1 2 16 2 22 23
17 1 2 16 2 23 24
18 1 2 16 2 24 25
19 1 2 16 2 25 26
20 1 2 16 2 26 3
21 1 2 16 3 3 27
22 1 2 16 3 27 28
23 1 2 16 3 28 29
24 1 2 16 3 29 30
25 1 2 16 3 30 31
26 1 2 16 3 31 32
27 1 2 16 3 32 33
28 1 2 16 3 33 34
29 1 2 16 3 34 35
30 1 2 16 3 35 1
31 1 2 16 4 1 36
32 1 2 16 4 36 37
33 1 2 16 4 37 38
34 1 2 16 4 38 39
35 1 2 16 4 39 40
36 1 2 16 4 40 41
37 1 2 16 4 41 42
38 1 2 16 4 42 43
39 1 2 16 4 43 44
40 1 2 16 4 44 4
41 1 2 15 5 7 45
42 1 2 15 5 45 46
43 1 2 15 5 46 47
44 1 2 15 5 47 48
45 1 2 15 5 48 6
46 1 2 15 6 6 49
47 1 2 15 6 49 50
48 1 2 15 6 50 51
49 1 2 15 6 51 52
50 1 2 15 6 52 5
51 1 2 15 7 5 53
52 1 2 15 7 53 54
53 1 2 15 7 54 55
54 1 2 15 7 55 56
55 1 2 15 7 56 8
56 1 2 15 8 8 57
57 1 2 15 8 57 58
58 1 2 15 8 58 59
59 1 2 15 8 59 60
60 1 2 15 8 60 7
61 2 2 18 1 78 62 79
62 2 2 18 1 61 95 112
63 2 2 18 1 79 62 116
64 2 2 18 1 65 79 116
65 2 2 18 1 80 63 115
66 2 2 18 1 64 81 114
67 2 2 18 1 112 95 124
68 2 2 18 1 38 90 94
69 2 2 18 1 62 78 113
70 2 2 18 1 79 65 119
71 2 2 18 1 63 80 122
72 2 2 18 1 81 64 123
73 2 2 18 1 90 71 94
74 2 2 18 1 87 31 103
75 2 2 18 1 86 22 104
76 2 2 18 1 42 88 97
77 2 2 18 1 11 92 98
78 2 2 18 1 91 41 97
79 2 2 18 1 93 14 107
80 2 2 18 1 8 78 79
81 2 2 18 1 8 77 78
82 2 2 18 1 15 16 67
83 2 2 18 1 52 51 69
84 2 2 18 1 49 6 70
85 2 2 18 1 45 7 71
86 2 2 18 1 70 6 80
87 2 2 18 1 12 13 73
88 2 2 18 1 39 40 72
89 2 2 18 1 48 47 82
90 2 2 18 1 43 44 63
91 2 2 18 1 6 48 68
92 2 2 18 1 68 48 82
93 2 2 18 1 36 37 64
94 2 2 18 1 7 76 81
95 2 2 18 1 59 58 75
96 2 2 18 1 55 54 74
97 2 2 18 1 56 55 84
98 2 2 18 1 60 59 83
99 2 2 18 1 8 56 77
100 2 2 18 1 7 60 76
101 2 2 18 1 18 19 61
102 2 2 18 1 27 28 62
103 2 2 18 1 29 30 65
104 2 2 18 1 55 74 84
105 2 2 18 1 20 21 66
106 2 2 18 1 59 75 83
107 2 2 18 1 77 56 84
108 2 2 18 1 76 60 83
109 2 2 18 1 19 20 85
110 2 2 18 1 61 19 85
111 2 2 18 1 20 66 85
112 2 2 18 1 69 93 107
113 2 2 18 1 74 86 104
114 2 2 18 1 75 87 103
115 2 2 18 1 88 68 97
116 2 2 18 1 92 70 98
117 2 2 18 1 82 91 97
118 2 2 18 1 21 22 86
119 2 2 18 1 30 31 87
120 2 2 18 1 42 43 88
121 2 2 18 1 5 52 89
122 2 2 18 1 38 39 90
123 2 2 18 1 37 38 94
124 2 2 18 1 40 41 91
125 2 2 18 1 13 14 93
126 2 2 18 1 11 12 92
127 2 2 18 1 15 67 107
128 2 2 18 1 69 51 106
129 2 2 18 1 49 70 109
130 2 2 18 1 45 71 108
131 2 2 18 1 82 47 105
132 2 2 18 1 75 58 110
133 2 2 18 1 74 54 111
134 2 2 18 1 16 17 112
135 2 2 18 1 98 80 115
136 2 2 18 1 81 100 114
137 2 2 18 1 87 75 110
138 2 2 18 1 86 74 111
139 2 2 18 1 67 89 107
140 2 2 18 1 70 92 109
141 2 2 18 1 71 90 108
142 2 2 18 1 91 82 105
143 2 2 18 1 93 69 106
144 2 2 18 1 65 30 87
145 2 2 18 1 66 21 86
146 2 2 18 1 43 63 88
147 2 2 18 1 52 69 89
148 2 2 18 1 72 40 91
149 2 2 18 1 39 72 90
150 2 2 18 1 12 73 92
151 2 2 18 1 73 13 93
152 2 2 18 1 64 37 94
153 2 2 18 1 25 26 113
154 2 2 18 1 73 106 109
155 2 2 18 1 72 105 108
156 2 2 18 1 96 66 111
157 2 2 18 1 53 5 96
158 2 2 18 1 61 85 95
159 2 2 18 1 31 32 103
160 2 2 18 1 22 23 104
161 2 2 18 1 23 24 102
162 2 2 18 1 32 33 101
163 2 2 18 1 95 85 96
164 2 2 18 1 41 42 97
165 2 2 18 1 70 80 98
166 2 2 18 1 10 11 98
167 2 2 18 1 68 82 97
168 2 2 18 1 24 25 99
169 2 2 18 1 33 34 100
170 2 2 18 1 85 66 96
171 2 2 18 1 23 102 104
172 2 2 18 1 32 101 103
173 2 2 18 1 5 95 96
174 2 2 18 1 33 100 101
175 2 2 18 1 24 99 102
176 2 2 18 1 78 77 99
177 2 2 18 1 81 76 100
178 2 2 18 1 76 83 101
179 2 2 18 1 77 84 102
180 2 2 18 1 100 76 101
181 2 2 18 1 99 77 102
182 2 2 18 1 84 74 104
183 2 2 18 1 83 75 103
184 2 2 18 1 102 84 104
185 2 2 18 1 101 83 103
186 2 2 18 1 53 96 111
187 2 2 18 1 106 50 109
188 2 2 18 1 105 46 108
189 2 2 18 1 47 46 105
190 2 2 18 1 51 50 106
191 2 2 18 1 14 15 107
192 2 2 18 1 46 45 108
193 2 2 18 1 50 49 109
194 2 2 18 1 58 57 110
195 2 2 18 1 54 53 111
196 2 2 18 1 67 16 112
197 2 2 18 1 10 98 115
198 2 2 18 1 100 34 114
199 2 2 18 1 9 10 115
200 2 2 18 1 34 35 114
201 2 2 18 1 78 99 113
202 2 2 18 1 99 25 113
203 2 2 18 1 62 28 116
204 2 2 18 1 29 65 116
205 2 2 18 1 65 87 110
206 2 2 18 1 66 86 111
207 2 2 18 1 89 69 107
208 2 2 18 1 90 72 108
209 2 2 18 1 92 73 109
210 2 2 18 1 72 91 105
211 2 2 18 1 73 93 106
212 2 2 18 1 2 18 117
213 2 2 18 1 3 27 118
214 2 2 18 1 17 2 117
215 2 2 18 1 26 3 118
216 2 2 18 1 8 79 119
217 2 2 18 1 57 8 119
218 2 2 18 1 35 1 120
219 2 2 18 1 1 36 120
220 2 2 18 1 44 4 121
221 2 2 18 1 4 9 121
222 2 2 18 1 67 112 124
223 2 2 18 1 88 63 122
224 2 2 18 1 64 94 123
225 2 2 18 1 80 6 122
226 2 2 18 1 6 68 122
227 2 2 18 1 7 81 123
228 2 2 18 1 71 7 123
229 2 2 18 1 5 89 124
230 2 2 18 1 65 110 119
231 2 2 18 1 28 29 116
232 2 2 18 1 95 5 124
233 2 2 18 1 112 17 117
234 2 2 18 1 63 44 121
235 2 2 18 1 36 64 120
236 2 2 18 1 18 61 117
237 2 2 18 1 27 62 118
238 2 2 18 1 113 26 118
239 2 2 18 1 61 112 117
240 2 2 18 1 110 57 119
241 2 2 18 1 62 113 118
242 2 2 18 1 64 114 120
243 2 2 18 1 115 63 121
244 2 2 18 1 114 35 120
245 2 2 18 1 9 115 121
246 2 2 18 1 68 88 122
247 2 2 18 1 94 71 123
248 2 2 18 1 89 67 124
249 2 2 17 2 140 138 142
250 2 2 17 2 138 126 142
251 2 2 17 2 130 129 139
252 2 2 17 2 135 141 142
253 2 2 17 2 131 133 136
254 2 2 17 2 134 138 140
255 2 2 17 2 135 137 141
256 2 2 17 2 130 139 147
257 2 2 17 2 133 131 148
258 2 2 17 2 126 135 142
259 2 2 17 2 47 48 133
260 2 2 17 2 51 52 129
261 2 2 17 2 59 60 135
262 2 2 17 2 55 56 134
263 2 2 17 2 127 47 133
264 2 2 17 2 125 130 131
265 2 2 17 2 125 51 129
266 2 2 17 2 125 129 130
267 2 2 17 2 50 51 125
268 2 2 17 2 54 55 128
269 2 2 17 2 46 47 127
270 2 2 17 2 58 59 126
271 2 2 17 2 131 130 132
272 2 2 17 2 128 55 134
273 2 2 17 2 126 59 135
274 2 2 17 2 49 50 136
275 2 2 17 2 45 46 137
276 2 2 17 2 53 54 139
277 2 2 17 2 57 58 138
278 2 2 17 2 125 131 136
279 2 2 17 2 46 127 137
280 2 2 17 2 50 125 136
281 2 2 17 2 58 126 138
282 2 2 17 2 54 128 139
283 2 2 17 2 128 134 140
284 2 2 17 2 6 49 143
285 2 2 17 2 56 8 144
286 2 2 17 2 48 6 143
287 2 2 17 2 7 45 145
288 2 2 17 2 8 57 144
289 2 2 17 2 60 7 145
290 2 2 17 2 52 5 146
291 2 2 17 2 5 53 146
292 2 2 17 2 132 140 142
293 2 2 17 2 127 133 148
294 2 2 17 2 137 127 141
295 2 2 17 2 131 132 148
296 2 2 17 2 132 130 147
297 2 2 17 2 139 128 147
298 2 2 17 2 132 141 148
299 2 2 17 2 140 132 147
300 2 2 17 2 49 136 143
301 2 2 17 2 53 139 146
302 2 2 17 2 57 138 144
303 2 2 17 2 45 137 145
304 2 2 17 2 133 48 143
305 2 2 17 2 129 52 146
306 2 2 17 2 134 56 144
307 2 2 17 2 135 60 145
308 2 2 17 2 136 133 143
309 2 2 17 2 139 129 146
310 2 2 17 2 137 135 145
311 2 2 17 2 138 134 144
312 2 2 17 2 141 132 142
313 2 2 17 2 128 140 147
314 2 2 17 2 141 127 148
$EndElements
This does work. I guess the export function from the GUI is not as reliable as Ubuntu packages. I tried dokken’s method and it works. Huh, weird gmsh stuff i guess :laughing:
Thanks, it works! I guess i’ll just use terminal to export .geo files from now on instead of the GUI.
