Point Sources (Redux)
As a prelude to something more complex, I’d like to solve
-\nabla^2 u = \delta(\mathbf{x}- \mathbf{x}_0) \tag{1}
on the unit circle. Given a finite-dimensional space of test functions V_h = \mathrm{span}(\{\phi_i| i = 1,...,n\}), it seems like the most accurate way to solve (1) would be to take its weak-form of and write the rhs as follows -
\int_{\Omega}\nabla u\cdot\nabla \phi_i dx = \int_{\Omega}\delta \phi_idx \\ = \phi_i(\mathbf{x}_0).
From what I’ve seen, older versions of dolfin had a built-in `PointSource’ function that performed just this (or something exactly analogous). Has any such functionality been added to dolfinx or is my best bet simply to use a Gaussian approximation? I worry that in using the latter, numerical quadrature of \int_{\Omega} \delta \phi_i\,dx over the appropriate cell may not yield something sufficiently-close to \phi_i(x).
If my only hope is a Gaussian approximation, is there any standard way to choose the width parameter (commonly referred to as \sigma)?
Have you used the search button? This question was discused serveral times, and as of December 2023 there is a solution. I’ll leave you to find it, but once you do please post a reply with the link.
For anyone who may have a similar question, a solution was given here - Delta Implementation - by dokken (post 4). Given a rhs function \delta(\mathbf{x} - \mathbf{x}_0), the solution provided allows one to evaluate the basis functions \phi_i st \mathbf{x}_0 \in \mathrm{supp}(\phi_i).
As an addendum, would anyone mind pointing me towards some method for inserting values into a rhs vector corresponding to specific mesh cells?
Following my post above, with a minor adaptations, a point source can be implemented as follows:
# Create a point source for Poisson problem
# Author: Jørgen S. Dokken
# SPDX-License-Identifier: MIT
import dolfinx.fem.petsc
def compute_cell_contributions(V, points):
    # Determine what process owns a point and what cells it lies within
    mesh = V.mesh
    _, _, owning_points, cells = dolfinx.cpp.geometry.determine_point_ownership(
        mesh._cpp_object, points, 1e-6)
    owning_points = np.asarray(owning_points).reshape(-1, 3)
    # Pull owning points back to reference cell
    mesh_nodes = mesh.geometry.x
    cmap = mesh.geometry.cmaps[0]
    ref_x = np.zeros((len(cells), mesh.geometry.dim),
                     dtype=mesh.geometry.x.dtype)
    for i, (point, cell) in enumerate(zip(owning_points, cells)):
        geom_dofs = mesh.geometry.dofmap[cell]
        ref_x[i] = cmap.pull_back(point.reshape(-1, 3), mesh_nodes[geom_dofs])
    # Create expression evaluating a trial function (i.e. just the basis function)
    u = ufl.TrialFunction(V)
    num_dofs = V.dofmap.dof_layout.num_dofs * V.dofmap.bs
    if len(cells) > 0:
        # NOTE: Expression lives on only this communicator rank
        expr = dolfinx.fem.Expression(u, ref_x, comm=MPI.COMM_SELF)
        values = expr.eval(mesh, np.asarray(cells, dtype=np.int32))
        # Strip out basis function values per cell
        basis_values = values[:num_dofs:num_dofs*len(cells)]
        basis_values = np.zeros(
            (0, num_dofs), dtype=dolfinx.default_scalar_type)
    return cells, basis_values
N = 80
domain = dolfinx.mesh.create_unit_square(MPI.COMM_WORLD, N, N)
domain.name = "mesh"
domain.topology.create_connectivity(1, 2)
V = dolfinx.fem.functionspace(domain, ("Lagrange", 1))
facets = dolfinx.mesh.exterior_facet_indices(domain.topology)
if domain.comm.rank == 0:
    points = np.array([[0.68, 0.36, 0]], dtype=domain.geometry.x.dtype)
    points = np.zeros((0, 3), dtype=domain.geometry.x.dtype)
a = ufl.inner(ufl.grad(u), ufl.grad(v)) * ufl.dx
a_compiled = dolfinx.fem.form(a)
dofs = dolfinx.fem.locate_dofs_topological(V, 1, facets)
u_bc = dolfinx.fem.Constant(domain, 0.)
bc = dolfinx.fem.dirichletbc(u_bc, dofs, V)
b = dolfinx.fem.Function(V)
b.x.array[:] = 0
cells, basis_values = compute_cell_contributions(V, points)
for cell, basis_value in zip(cells, basis_values):
    dofs = V.dofmap.cell_dofs(cell)
    b.x.array[dofs] += basis_value
dolfinx.fem.petsc.apply_lifting(b.vector, [a_compiled], [[bc]])
b.x.scatter_reverse(dolfinx.la.InsertMode.add)
dolfinx.fem.petsc.set_bc(b.vector, [bc])
b.x.scatter_forward()
A = dolfinx.fem.petsc.assemble_matrix(a_compiled, bcs=[bc])
ksp = PETSc.KSP().create(domain.comm)
ksp.setOperators(A)
ksp.setType(PETSc.KSP.Type.PREONLY)
ksp.getPC().setType(PETSc.PC.Type.LU)
ksp.getPC().setFactorSolverType("mumps")
uh = dolfinx.fem.Function(V)
ksp.solve(b.vector, uh.vector)
uh.x.scatter_forward()
with dolfinx.io.VTXWriter(domain.comm, "uh.bp", [uh], engine="BP4") as bp:
    bp.write(0.0)
Reference solution made in legacy fenics:
N = 80
mesh = UnitSquareMesh(N, N)
a = inner(grad(u), grad(v))*dx
b = assemble(Constant(0.0)*v*dx)
point = Point(0.68, 0.36)
if mesh.mpi_comm().rank == 0:
    ps = PointSource(V, point, 1.0)
    ps = PointSource(V, [])
ps.apply(b)
bc = DirichletBC(V, Constant(0.0), "on_boundary")
A = assemble(a)
[bc.apply(A, b) for bc in [bc]]
uh = Function(V)
solve(A, uh.vector(), b)
File("uh.pvd") << uh
Copied and pasted program and get this error
AttributeError: ‘dolfinx.cpp.mesh.Geometry_float64’ object has no attribute ‘cmaps’. Did you mean: ‘cmap’?
running dolfinx in fenicsx-env on a Mac.
DOLFINx version: 0.8.0 based on GIT commit: of GitHub - FEniCS/dolfinx: Next generation FEniCS problem solving environment
Hope you had a great meeting this year!
The api slightly changed. Try to change it ss the error message suggests.
For dolfinx 0.8.0, simply use cmap = mesh.geometry.cmap.
For dolfinx main branch (future 0.9.0), a few further changes in the call to dolfinx.cpp.geometry.determine_point_ownership are required due to Make standalone function for interpolation over non-matching meshes (… · FEniCS/dolfinx@ab79530 · GitHub. I copy the updated code below
    mesh = V.mesh
    point_ownership_data = dolfinx.cpp.geometry.determine_point_ownership(
    owning_points = np.asarray(point_ownership_data.dest_points).reshape(-1, 3)
    cells = point_ownership_data.dest_cells
    if len(cells) > 0:
N = 80
b.x.array[:] = 0
ksp.setOperators(A)
    bp.write(0.0)
mesh.geometry.cmap worked! Thank you!
I am still making sure I understand how code works, so I may be back later!
Is it possible to adapt this solution for Helmholtz equation? I just executed it with complex fenics (0.8, conda) and got the following error:
	"name": "TypeError",
	"message": "apply_lifting(): incompatible function arguments. The following argument types are supported:
    1. apply_lifting(b: ndarray[dtype=float32, shape=(*), order='C'], a: list[dolfinx.cpp.fem.Form_float32], constants: list[ndarray[dtype=float32, writable=False, shape=(*), order='C']], coeffs: list[dict[tuple[dolfinx.cpp.fem.IntegralType, int], ndarray[dtype=float32, writable=False, shape=(*, *), order='C']]], bcs1: list[list[dolfinx.cpp.fem.DirichletBC_float32]], x0: list[ndarray[dtype=float32, writable=False, shape=(*), order='C']], scale: float) -> None
    2. apply_lifting(b: ndarray[dtype=float64, shape=(*), order='C'], a: list[dolfinx.cpp.fem.Form_float64], constants: list[ndarray[dtype=float64, writable=False, shape=(*), order='C']], coeffs: list[dict[tuple[dolfinx.cpp.fem.IntegralType, int], ndarray[dtype=float64, writable=False, shape=(*, *), order='C']]], bcs1: list[list[dolfinx.cpp.fem.DirichletBC_float64]], x0: list[ndarray[dtype=float64, writable=False, shape=(*), order='C']], scale: float) -> None
    3. apply_lifting(b: ndarray[dtype=complex64, shape=(*), order='C'], a: list[dolfinx.cpp.fem.Form_complex64], constants: list[ndarray[dtype=complex64, writable=False, shape=(*), order='C']], coeffs: list[dict[tuple[dolfinx.cpp.fem.IntegralType, int], ndarray[dtype=complex64, writable=False, shape=(*, *), order='C']]], bcs1: list[list[dolfinx.cpp.fem.DirichletBC_complex64]], x0: list[ndarray[dtype=complex64, writable=False, shape=(*), order='C']], scale: complex) -> None
    4. apply_lifting(b: ndarray[dtype=complex128, shape=(*), order='C'], a: list[dolfinx.cpp.fem.Form_complex128], constants: list[ndarray[dtype=complex128, writable=False, shape=(*), order='C']], coeffs: list[dict[tuple[dolfinx.cpp.fem.IntegralType, int], ndarray[dtype=complex128, writable=False, shape=(*, *), order='C']]], bcs1: list[list[dolfinx.cpp.fem.DirichletBC_complex128]], x0: list[ndarray[dtype=complex128, writable=False, shape=(*), order='C']], scale: complex) -> None
Invoked with types: ndarray, list, list, list, list, list, float",
	"stack": "---------------------------------------------------------------------------
TypeError                                 Traceback (most recent call last)
Cell In[1], line 77
     75     dofs = V.dofmap.cell_dofs(cell)
     76     b.x.array[dofs] += basis_value
---> 77 dolfinx.fem.petsc.apply_lifting(b.vector, [a_compiled], [[bc]])
     78 b.x.scatter_reverse(dolfinx.la.InsertMode.add)
     79 dolfinx.fem.petsc.set_bc(b.vector, [bc])
File ~/miniconda3/envs/fenics-complex/lib/python3.12/site-packages/dolfinx/fem/petsc.py:651, in apply_lifting(b, a, bcs, x0, scale, constants, coeffs)
    649 x0_r = [x.array_r for x in x0]
    650 b_local = stack.enter_context(b.localForm())
--> 651 _assemble.apply_lifting(b_local.array_w, a, bcs, x0_r, scale, constants, coeffs)
File ~/miniconda3/envs/fenics-complex/lib/python3.12/site-packages/dolfinx/fem/assemble.py:348, in apply_lifting(b, a, bcs, x0, scale, constants, coeffs)
    346 _a = [None if form is None else form._cpp_object for form in a]
    347 _bcs = [[bc._cpp_object for bc in bcs0] for bcs0 in bcs]
--> 348 _cpp.fem.apply_lifting(b, _a, constants, coeffs, _bcs, x0, scale)
TypeError: apply_lifting(): incompatible function arguments. The following argument types are supported:
Simply change
to
u_bc = dolfinx.fem.Constant(domain, dolfinx.default_scalar_type(0.0))
Hello! I try to run your code in Version0.9 but there are still some errors.
 in <module>
    dolfinx.fem.petsc.apply_lifting(b, [a_compiled], [[bc]])
  in apply_lifting
AttributeError: 'Function' object has no attribute 'localForm'
The code can be updated with:
    mesh = V.mesh
    if len(cells) > 0:
N = 80
b.x.array[:] = 0
dolfinx.fem.petsc.apply_lifting(b.x.petsc_vec, [a_compiled], [[bc]])
dolfinx.fem.petsc.set_bc(b.x.petsc_vec, [bc])
ksp.setOperators(A)
ksp.solve(b.x.petsc_vec, uh.x.petsc_vec)
    bp.write(0.0)
however, please note that a tested and improved version of this code is available in scifem: Point sources in DOLFINx — scifem
Thanks! The tutorial is fantastic!
