Poisson adjoint solution is the same for both : solution & solution + noise
I am currently working on resolving a poisson equation for both forward and ajdoint problem. Here is my code :
from dolfin_adjoint import *
mesh = UnitSquareMesh ( 50 , 50 )
V = FunctionSpace ( mesh , "Lagrange" , 1 )
# Define basis functions and parameters
u = TrialFunction ( V )
v = TestFunction ( V )
f = interpolate(Expression("10*exp(-(pow(x[0] - 0.5, 2) + pow(x[1] - 0.5, 2)) / 0.02)", degree=2), V)
a = inner ( grad ( u ) , grad ( v ) ) * dx
L = f * v * dx
bc = DirichletBC (V , 0.0 , "on_boundary" )
# Solve variational problem
u = Function ( V )
solve ( a == L , u , bc )
plt.colorbar (plot(u))
ud = Function(V)
j = inner ( u - ud , u - ud ) * dx
J = assemble(j)
fc = Control(f)
dJdf = compute_gradient (J , fc)
# solution of the adjoint problem
tape = get_working_tape()
solve_block = tape.get_blocks()[1]
adj_u = solve_block.adj_sol.vector()[:]
adj_u_func = Function(V)
adj_u_func.assign(u)
adj_u_func.vector()[:]= adj_u
plot(adj_u_func)
plt.colorbar(plot(adj_u_func))
noise_level = 2
u_noise = Function(V)
u_noise.assign(u)
MAX = u_noise.vector().norm("linf")
noise_rand = noise_level * MAX * np.random.normal(0, 1, len(u_noise.vector().get_local()))
for i in range(len(u_noise.vector())):
    u_noise.vector()[i] = u_noise.vector()[i] + noise_rand[i]*u_noise.vector()[i]
plot(u_noise)
plt.colorbar(plot(u_noise))
j = inner ( u_noise - ud , u_noise - ud ) * dx
J = assemble(j)
fc = Control(f)
adj_u_func_noise = Function(V)
adj_u_func_noise.assign(u_noise)
adj_u_func_noise.vector()[:]= adj_u
plot(adj_u_func_noise)
plt.colorbar(plot(adj_u_func_noise))
It’s weird that both the adjoint solution with and without noise are the same.
Am I misunderstaing something ?
PS : I think the tape call always get back to the adjoint solution without noise, even though we specify the noisy adjoint solution.
Adding some plots for better understanding.
Solution of the forward problem without noise :
Solution of the adjoint problem without noise :
Adding noise to the forward solution :
Adjoint solution for the noisy part (exactly the same as solution of the adjoint problem without noise):
You are assigning noise to the solution after solving the variational problem, thus the adjoint of the forward problem sees no noise and should be unaffected.
Thank you, that was indeed the mistake !
Hello dokken,
I thought I’ve figured it out, but before going to the adjoint, I couldn’t see a change by adding noise before solving the variational problem.
L = f * v * dx
u = Function ( V )
##### add noise to u ####
noise_level = 2
MAX = u.vector().norm("linf")
noise_rand = noise_level * MAX * np.random.normal(0, 1, len(u.vector().get_local()))
for i in range(len(u.vector())):
    u.vector()[i] = u.vector()[i] + noise_rand[i]*u.vector()[i]
Removing or leaving this part of the code, doesn’t make a difference in the u plot :
noise_level = 2
Is there something I am not understanding ? (Maybe I should add noise to u when I call it as TrialFunction(V) ? I couldn’t do that since there is no way to access its values).
Thank you.
