Poisson with variable co-efficient
I am writting the poisson code with variable co-efficient in fenicsx
a\Delta u=f(x)
where a=a(x) variable coefficient. Could you please suggest something
See How to implement a varying coefficient in the bilinear form?
Can there be any simple case where a(x)= x?
In Expression this was working
a = Expression(x[0], degree=1)
It is resolved, right ?
No, this I was using in fenics. Now I am writting in fenicsx. So, this Expression is not working there.
Could you please help?
This is covered many times in the dolfinx demos and the dolfinx tutorial The FEniCSx tutorial — FEniCSx tutorial
A simple edit of https://github.com/FEniCS/dolfinx/blob/main/python/demo/demo_poisson.py adding the lines
A = x[0] + 1
a = inner(A * grad(u), grad(v)) * dx
fulfils your example.
msh = mesh.create_rectangle(comm=MPI.COMM_WORLD,
                            points=((0.0, 0.0), (2.0, 1.0)), n=(32, 16),
                            cell_type=mesh.CellType.triangle)
V = fem.FunctionSpace(msh, ("Lagrange", 1))
facets = mesh.locate_entities_boundary(msh, dim=(msh.topology.dim - 1),
                                       marker=lambda x: np.logical_or(np.isclose(x[0], 0.0),
        np.isclose(x[0], 2.0)))
dofs = fem.locate_dofs_topological(V=V, entity_dim=1, entities=facets)
bc = fem.dirichletbc(value=ScalarType(0), dofs=dofs, V=V)
u = ufl.TrialFunction(V)
f = 10 * ufl.exp(-((x[0] - 0.5) ** 2 + (x[1] - 0.5) ** 2) / 0.02)
g = ufl.sin(5 * x[0])
A = x[0] + 1
L = inner(f, v) * dx + inner(g, v) * ds
uh = problem.solve()
with io.XDMFFile(msh.comm, "out_poisson/poisson.xdmf", "w") as file:
    file.write_mesh(msh)
    file.write_function(uh)
try:
    import pyvista
    cells, types, x = plot.create_vtk_mesh(V)
    grid = pyvista.UnstructuredGrid(cells, types, x)
    grid.point_data["u"] = uh.x.array.real
    grid.set_active_scalars("u")
    plotter = pyvista.Plotter()
    warped = grid.warp_by_scalar()
    plotter.add_mesh(warped)
    if pyvista.OFF_SCREEN:
        pyvista.start_xvfb(wait=0.1)
        plotter.screenshot("uh_poisson.png")
        plotter.show()
except ModuleNotFoundError:
    print("'pyvista' is required to visualise the solution")
    print("Install 'pyvista' with pip: 'python3 -m pip install pyvista'")
If you want something not so easily expressible in symbolic algebra you can interpolate that function in an appropriate finite element space, e.g.,
def my_interesting_function(x):
    value = ... # Do interesting things
    return value
V_coefficient = dolfinx.fem.FunctionSpace(mesh, ("DG", 1))  # Choose appropriate space
A = dolfinx.fem.Function(V_coefficient)
A.interpolate(my_interesting_function)
I have tried both the ways that you suggest. This is the minimal 1D code I have written to compute L2 norm. For constant coefficient I am getting results. But not for variable. Could you please check?
from dolfinx import mesh
from math import *
from dolfinx.mesh import (CellType, compute_midpoints, create_unit_cube,
                          create_unit_square, meshtags)
from ufl import (Circumradius, FacetNormal, SpatialCoordinate, TrialFunction, TestFunction,
                 div, dx, ds, grad, inner)
from dolfinx.fem import Function, FunctionSpace, assemble_scalar, form
def poisson(N):
    msh = mesh.create_interval(comm=MPI.COMM_WORLD, points=(xL, xR),nx = N )
    hm = 1/N
    from dolfinx.fem import FunctionSpace
    V = FunctionSpace(msh, ("CG", 1))
    f = fem.Function(V)
    # f.interpolate(lambda x:  (pi**2)*np.sin(pi*x[0]) ) #### with constant coefficient                    \nabla u
    f.interpolate(lambda x:  (x[0] + 1)* ((pi**2)*np.sin(pi*x[0]) ) ) #### with variable coefficient      A*\nabla u
    import numpy
    # Create facet to cell connectivity required to determine boundary facets
    tdim = msh.topology.dim
    fdim = tdim - 1
    boundary_facets = mesh.exterior_facet_indices(msh.topology)
    dofs = fem.locate_dofs_topological(V, fdim, boundary_facets)
    # A =  1 #### with constant coefficient
    A = x[0] + 1      #### with variable coefficient
    ##### or
    # def my_interesting_function(x):
    #     return x[0] + 1
    # V_coefficient = dolfinx.fem.FunctionSpace(msh, ("DG", 1))  # Choose appropriate space
    # A = dolfinx.fem.Function(V_coefficient)
    # A.interpolate(my_interesting_function)
    a = inner(A * grad(u), grad(v)) * dx #### with variable coefficient
    L = f * v * ufl.dx
    problem = fem.petsc.LinearProblem(a, L, bcs=[bc], petsc_options={"ksp_type": "preonly", "pc_type": "lu"})
    V2 = fem.FunctionSpace(msh, ("CG", 2))
    u_exact = fem.Function(V2)
    u_exact.interpolate(lambda x:  np.sin(pi*x[0]) )
    L2_error = fem.form(ufl.inner(uh - u_exact, uh - u_exact) * ufl.dx)
    error_local = fem.assemble_scalar(L2_error)
    error_L2 = numpy.sqrt(msh.comm.allreduce(error_local, op=MPI.SUM))
    return  error_L2, hm
if __name__ == '__main__':
    from math import log as ln
    # Run the convergence test
    for N in [4, 8, 16, 24, 48]:
        e, h = poisson(N)
        if N != 4:
            rate = ln(e/e_)/ln(h/h_)
            print(rate)
        e_, h_ = e, h
see, e.g., Error control: Computing convergence rates — FEniCSx tutorial
Thank you. It is working now with variable coefficient, but my doubt is in 2D coefficient A has be to be in matrix form. How to define that A as matrix here?
from dolfinx.fem import (Expression, Function, FunctionSpace,
                         assemble_scalar, dirichletbc, form, locate_dofs_topological)
from dolfinx.mesh import create_unit_square, locate_entities_boundary
from ufl import SpatialCoordinate, TestFunction, TrialFunction, div, dot, dx, grad, inner
def u_ex(mod):
    return lambda x: mod.cos(2*mod.pi*x[0])*mod.cos(2*mod.pi*x[1])
u_numpy = u_ex(np)
u_ufl = u_ex(ufl)
def solve_poisson(N=10, degree=1):
    mesh = create_unit_square(MPI.COMM_WORLD, N, N)
    x = SpatialCoordinate(mesh)
    V = FunctionSpace(mesh, ("CG", degree))
    A = x[0]
    f = -div(A*grad(u_ufl(x)))
    a = inner(A*grad(u), grad(v)) * dx
    L = f * v * dx
    u_bc = Function(V)
    u_bc.interpolate(u_numpy)
    facets = locate_entities_boundary(mesh, mesh.topology.dim -1, lambda x: np.full(x.shape[1], True))
    dofs = locate_dofs_topological(V, mesh.topology.dim-1, facets)
    bcs = [dirichletbc(u_bc, dofs)]
    default_problem = LinearProblem(a, L, bcs=bcs, petsc_options={"ksp_type": "preonly", "pc_type": "lu"})
    return default_problem.solve(), u_ufl(x)
uh, u_ex = solve_poisson(10)
def error_L2(uh, u_ex, degree_raise=3):
    # Create higher order function space
    degree = uh.function_space.ufl_element().degree()
    family = uh.function_space.ufl_element().family()
    mesh = uh.function_space.mesh
    W = FunctionSpace(mesh, (family, degree+ degree_raise))
    # Interpolate approximate solution
    u_W = Function(W)
    u_W.interpolate(uh)
    # Interpolate exact solution, special handling if exact solution
    # is a ufl expression or a python lambda function
    u_ex_W = Function(W)
    if isinstance(u_ex, ufl.core.expr.Expr):
        u_expr = Expression(u_ex, W.element.interpolation_points)
        u_ex_W.interpolate(u_expr)
        u_ex_W.interpolate(u_ex)
    # Compute the error in the higher order function space
    e_W = Function(W)
    e_W.x.array[:] = u_W.x.array - u_ex_W.x.array
    # Integrate the error
    error = form(ufl.inner(e_W, e_W) * ufl.dx)
    error_local = assemble_scalar(error)
    error_global = mesh.comm.allreduce(error_local, op=MPI.SUM)
    return np.sqrt(error_global)
Ns = [4, 8, 16, 32, 64]
Es = np.zeros(len(Ns), dtype=PETSc.ScalarType)
hs = np.zeros(len(Ns), dtype=np.float64)
for i, N in enumerate(Ns):
    uh, u_ex = solve_poisson(N, degree=1)
    comm = uh.function_space.mesh.comm
    # One can send in either u_numpy or u_ex
    # For L2 error estimations it is reccommended to send in u_numpy
    # as no JIT compilation is required
    Es[i] = error_L2(uh, u_numpy)
    hs[i] = 1./Ns[i]
    if comm.rank == 0:
        print(f"h: {hs[i]:.2e} Error: {Es[i]:.2e}")
rates = np.log(Es[1:]/Es[:-1])/np.log(hs[1:]/hs[:-1])
if comm.rank == 0:
    print(f"Rates: {rates}")
Consider User-defined expression for tensor coefficient.
As you are using dolfinx, consider for instance Speeding up time-dependent diffusion equation - #4 by dokken
